Home » Eclipse Projects » Eclipse Titan » XML Decoder order problem
XML Decoder order problem [message #1764719] |
Thu, 01 June 2017 12:02  |
Hello everyone,
Today I was testing the XML codec for oneM2M and noted that it enforces strict order even if there is no specific order in the record declaration (or just something is simply wrong). Let me explain:
In the reference guide of Titan, Chapter 4.25.2 XML Encoder and Decoder, Attributes, there is a section for the attribute "useOrder" that explains that :
Quote:The encoding instruction designates that the encoder shall encode the values of the fields corresponding to the children elements of the all constructor according to the order identified by the elements of the order field. At decoding, the received values of the XML elements shall be placed in their corresponding record fields and a new record of element shall be inserted into the order field for each XML element processed (the final order of the record of elements shall reflect the order of the XML elements in the encoded XML document).
This is also confirmed by the TTCN-3 spec (ETSI ES 201 873-9, Annex B).
But there is no "record of (...) order" and "useOrder" inside the oneM2M Types module, and yet Titan doesn't decode certain elements (leaving them with "omit"). Let me show an example:
HTTP/1.1 201 Created\r
Content-Location: /in-cse/CAE178153928\r
X-M2M-RI: TC_CSE_DMR_CRE_BV_002_01-m_createAe661389\r
X-M2M-Origin: /in-cse\r
X-M2M-RSC: 2001\r
Content-Type: application/xml;charset=ISO-8859-1\r
Content-Length: 372\r
Server: Jetty(8.1.16.v20140903)\r
\r
<?xml version=\"1.0\" encoding=\"UTF-8\"?>
<m2m:ae xmlns:m2m=\"http://www.onem2m.org/xml/protocols\" rn=\"MyAe\">
<ty>2</ty>
<ri>/in-cse/CAE178153928</ri>
<pi>/in-cse</pi>
<ct>20170601T160956</ct>
<lt>20170601T160956</lt>
<acpi>/in-cse/acp-347340622</acpi>
<et>20180601T160956</et>
<api>myAppId</api>
<aei>CAE178153928</aei>
<rr>true</rr>
</m2m:ae>
will be converted to:
OneM2M_Types.MsgIn : {
primitive := {
responsePrimitive := {
responseStatusCode := int2001 (2001),
requestIdentifier := "TC_CSE_DMR_CRE_BV_002_01-m_createAe661389",
primitiveContent := {
any_1 := {
AE_optional := {
resourceName := "MyAe",
resourceType := int2 (2),
resourceID := "/in-cse/CAE178153928",
parentID := "/in-cse",
creationTime := "20170601T160956",
lastModifiedTime := "20170601T160956",
labels := omit,
accessControlPolicyIDs := {
"/in-cse/acp-347340622"
expirationTime := "20180601T160956",
dynamicAuthorizationConsultationIDs := omit,
announceTo := omit,
announcedAttribute := omit,
appName := omit,
app_ID := "myAppId",
aE_ID := "CAE178153928",
pointOfAccess := omit,
ontologyRef := omit,
nodeLink := omit,
requestReachability := true,
contentSerialization := omit,
e2eSecInfo := omit,
choice := omit
to_ := omit,
from_ := "/in-cse",
originatingTimestamp := omit,
resultExpirationTimestamp := omit,
eventCategory := omit,
contentStatus := omit,
contentOffset := omit,
assignedTokenIdentifiers := omit,
tokenRequestInformation := omit
but this one:
X-Powered-By: Express\r
Content-Location: /mobius-yt/MyAe\r
X-M2M-RI: TC_CSE_DMR_CRE_BV_002_01-m_createAe838176\r
X-M2M-RSC: 2001\r
Content-Type: application/xml\r
Date: Thu, 01 Jun 2017 14:15:06 GMT\r
Connection: keep-alive\r
Content-Length: 373\r
\r
<?xml version=\"1.0\" encoding=\"UTF-8\" standalone=\"yes\"?>
<m2m:ae xmlns:m2m=\"http://www.onem2m.org/xml/protocols\" xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" rn=\"MyAe\">
<ty>2</ty>
<pi>rJ1BZsp--</pi>
<ri>r1lQOZop-b</ri>
<ct>20170601T141506</ct>
<et>20190601T141506</et>
<lt>20170601T141506</lt>
<api>re.kr.keti.testSystem.Id</api>
<rr>true</rr>
<aei>Ctsae001-ae</aei>
</m2m:ae>
is decoded to this:
primitive := {
requestIdentifier := "TC_CSE_DMR_CRE_BV_002_01-m_createAe838176",
any_1 := {
AE_optional := {
resourceID := omit,
parentID := "rJ1BZsp--",
creationTime := omit,
lastModifiedTime := omit,
labels := omit,
accessControlPolicyIDs := omit,
expirationTime := omit,
announceTo := omit,
appName := omit,
app_ID := omit,
aE_ID := omit,
nodeLink := omit,
requestReachability := omit,
e2eSecInfo := omit,
choice := omit
to_ := omit,
from_ := omit,
with the following warnings:
Warning: While XER-decoding type '@OneM2M_Types.anytype': Alternative 'AE_optional': Unprocessed XML tag `resourceID'
Warning: While XER-decoding type '@OneM2M_Types.anytype': Alternative 'AE_optional': Unprocessed XML tag `creationTime'
Warning: While XER-decoding type '@OneM2M_Types.anytype': Alternative 'AE_optional': Unprocessed XML tag `expirationTime'
Warning: While XER-decoding type '@OneM2M_Types.anytype': Alternative 'AE_optional': Unprocessed XML tag `lastModifiedTime'
Warning: While XER-decoding type '@OneM2M_Types.anytype': Alternative 'AE_optional': Unprocessed XML tag `App-ID'
Warning: While XER-decoding type '@OneM2M_Types.anytype': Alternative 'AE_optional': Unprocessed XML tag `requestReachability'
Warning: While XER-decoding type '@OneM2M_Types.anytype': Alternative 'AE_optional': Unprocessed XML tag `AE-ID'
Is this a correct behaviour? And is there a possibility (a flag maybe) that can be set in order to not check the order of the elements? Because I don't see any other reason that will convert the first one, and not the second message.
Thanks in advance.
Naum
Re: XML Decoder order problem [message #1764763 is a reply to message #1764724] |
Fri, 02 June 2017 03:22   |
Hello Elemer,
The type in question is this (line 6544 in the OneM2M_Types module):
type record AE_optional {
XSD.NCName resourceName optional,
ResourceType resourceType optional,
XSD.ID resourceID optional,
NhURI parentID optional,
Timestamp creationTime optional,
Timestamp lastModifiedTime optional,
Labels labels optional,
AcpType accessControlPolicyIDs optional,
Timestamp expirationTime optional,
ListOfURIs dynamicAuthorizationConsultationIDs optional,
ListOfURIs announceTo optional,
record length(1 .. infinity) of XSD.NCName announcedAttribute optional,
XSD.String appName optional,
XSD.String app_ID optional,
XSD.ID aE_ID optional,
PoaList pointOfAccess optional,
XSD.AnyURI ontologyRef optional,
XSD.AnyURI nodeLink optional,
XSD.Boolean requestReachability optional,
Serializations contentSerialization optional,
E2eSecInfo e2eSecInfo optional,
union {
record length(1 .. infinity) of ChildResourceRef childResource_list,
record length(1 .. infinity) of union {
Container container,
Group group_,
AccessControlPolicy accessControlPolicy,
Subscription subscription,
PollingChannel pollingChannel,
Schedule schedule,
SemanticDescriptor semanticDescriptor,
TimeSeries timeSeries,
TrafficPattern trafficPattern,
Sg_flexContainerResource_group sg_flexContainerResource
} choice_list
} choice optional
with {
variant "element";
variant (resourceName) "attribute";
variant (announcedAttribute) "list";
variant (app_ID) "name as 'App-ID'";
variant (aE_ID) "name as 'AE-ID'";
//variant (requestReachability) "text 'true' as '1'";
//variant (requestReachability) "text 'false' as '0'";
variant (choice) "untagged";
variant (choice.childResource_list) "untagged";
variant (choice.childResource_list[-]) "name as 'childResource'";
variant (choice.choice_list) "untagged";
variant (choice.choice_list[-]) "untagged";
variant (choice.choice_list[-].group_) "name as 'group'";
I'm not interested in the outer data (request/responsePrimitive) because that is done manually (the HTTP part), only this. The decoder is called on the body element of the HTTP message (which, in this case is AE_optional). If you want, I can provide you the whole messages in octetstring, so you can verify on your side.
Naum
[Updated on: Fri, 02 June 2017 03:24] by Moderator
Re: XML Decoder order problem [message #1764964 is a reply to message #1764857] |
Mon, 05 June 2017 04:05   |
Hello Elemer,
I'm using the decvalue() function to decode the XML, like this:
decvalue(bitBodyString, pl_out.primitive.requestPrimitive.primitiveContent.any_1[0]);
I agree that the problem is on the SUT side. Because in this case we can't modify the TTCN-3 code (at least not without the approval of ETSI STF 531/oneM2M TF 001), the only thing that we can do, as you said, is to throw a warning/error in the decoder, but as I can see, the message shown in the console is that some elements are missing (not the correct message in this case). Is there a possibility to alter the codec from C++?
Naum
Re: XML Decoder order problem [message #1764991 is a reply to message #1764966] |
Mon, 05 June 2017 11:15   |
Yes, I understand that the test case serves to detect faults and incompatibilities with the specification, but in this case there isn't much space for manoeuvring (changing the verdict and the reason); I'll discuss in the STF about this problem and hope that we will find a proper solution.
Otherwise, I detected (I think) an error in the XML codec: the variant "name as uncapitalized" doesn't work. The oneM2M_Types.ttcn file is always the same.
The type in question is "ServiceSubscribedAppRule_optional" with the following structure:
type record ServiceSubscribedAppRule_optional
ListOfM2MID applicableCredIDs optional,
ListOfM2MID allowedApp_IDs optional,
ListOfM2MID allowedAEs optional,
union {
record length(1 .. infinity) of Subscription subscription_list
} choice optional
with {
variant "name as uncapitalized";
variant "element";
variant (allowedApp_IDs) "name as 'allowedApp-IDs'";
variant (choice.subscription_list) "untagged";
variant (choice.subscription_list[-]) "name as 'subscription'";
Here is an example of TTCN-3 data:
ServiceSubscribedAppRule_optional := {
resourceName := omit,
resourceType := omit,
resourceID := omit,
parentID := omit,
labels := omit,
applicableCredIDs := {
"None"
allowedApp_IDs := {
"myAppId"
allowedAEs := {
"C-AE-ID-STEM"
choice := omit
The codec doesn't take into account the first variant and translates it into:
<m2m:ServiceSubscribedAppRule_optional xmlns:m2m="http://www.onem2m.org/xml/protocols">
<applicableCredIDs>None</applicableCredIDs>
<allowedApp-IDs>myAppId</allowedApp-IDs>
<allowedAEs>C-AE-ID-STEM</allowedAEs>
</m2m:ServiceSubscribedAppRule_optional>
instead of "serviceSubscribedAppRule_optional".
Should I report this formally as a bug?
Naum
Re: XML Decoder order problem [message #1765106 is a reply to message #1764995] |
Tue, 06 June 2017 12:05   |
Hello Elemer,
Here is an example. I took the same type and data as above (ServiceSubscribedAppRule_optional). Normally, the XML should be "serviceSubscribedAppRule_optional", but it is "ServiceSubscribedAppRule_optional".
The test case file is test_codec.tc_codecTest().
And the logs are here:
MTC@egm-VirtualBox: Test case tc_codecTest started.
MTC@egm-VirtualBox: Initializing variables, timers and ports of component type OneM2M_TestSystem.CseTester inside testcase tc_codecTest.
MTC@egm-VirtualBox: Port acPort was started.
MTC@egm-VirtualBox: Port mcaPort was started.
MTC@egm-VirtualBox: Port mccPort was started.
MTC@egm-VirtualBox: Component type OneM2M_TestSystem.CseTester was initialized.
MTC@egm-VirtualBox: Function rnd() returned 0.685228.
MTC@egm-VirtualBox: { operation := int1 (1), to_ := "NotInitialized", from_ := "NotInitialized", requestIdentifier := "tc_codecTest-m_createServiceSubscribedAppRule685229", resourceType := int19 (19), primitiveContent := { any_1 := { { ServiceSubscribedAppRule_optional := { resourceName := omit, resourceType := omit, resourceID := omit, parentID := omit, creationTime := omit, lastModifiedTime := omit, labels := omit, accessControlPolicyIDs := omit, expirationTime := omit, dynamicAuthorizationConsultationIDs := omit, applicableCredIDs := { "None" }, allowedApp_IDs := { "myAppId" }, allowedAEs := { "C-AE-ID-STEM" }, choice := omit } } } }, roleIDs := omit, originatingTimestamp := omit, requestExpirationTimestamp := omit, resultExpirationTimestamp := omit, operationExecutionTime := omit, responseType := omit, resultPersistence := omit, resultContent := omit, eventCategory := omit, deliveryAggregation := omit, groupRequestIdentifier := omit, filterCriteria := omit, discoveryResultType := omit, tokens := omit, tokenIDs := omit, localTokenIDs := omit, tokenRequestIndicator := omit }
MTC@egm-VirtualBox: '3C6D326D3A536572766963655375627363726962656441707052756C655F6F7074696F6E616C20786D6C6E733A6D326D3D27687474703A2F2F7777772E6F6E656D326D2E6F72672F786D6C2F70726F746F636F6C73273E0A093C6170706C696361626C65437265644944733E4E6F6E653C2F6170706C696361626C65437265644944733E0A093C616C6C6F7765644170702D4944733E6D7941707049643C2F616C6C6F7765644170702D4944733E0A093C616C6C6F7765644145733E432D41452D49442D5354454D3C2F616C6C6F7765644145733E0A3C2F6D326D3A536572766963655375627363726962656441707052756C655F6F7074696F6E616C3E0A0A'O ("<m2m:ServiceSubscribedAppRule_optional xmlns:m2m='http://www.onem2m.org/xml/protocols'>\n\t<applicableCredIDs>None</applicableCredIDs>\n\t<allowedApp-IDs>myAppId</allowedApp-IDs>\n\t<allowedAEs>C-AE-ID-STEM</allowedAEs>\n</m2m:ServiceSubscribedAppRule_optional>\n\n")
MTC@egm-VirtualBox: Terminating component type OneM2M_TestSystem.CseTester.
MTC@egm-VirtualBox: Port acPort was stopped.
MTC@egm-VirtualBox: Port mcaPort was stopped.
MTC@egm-VirtualBox: Port mccPort was stopped.
MTC@egm-VirtualBox: Component type OneM2M_TestSystem.CseTester was shut down inside testcase tc_codecTest.
MTC@egm-VirtualBox: Waiting for PTCs to finish.
MTC@egm-VirtualBox: Setting final verdict of the test case.
MTC@egm-VirtualBox: Local verdict of MTC: none
MTC@egm-VirtualBox: No PTCs were created.
MTC@egm-VirtualBox: Test case tc_codecTest finished. Verdict: none
Naum
Current Time: Sun Jul 27 04:42:28 EDT 2025
Powered by FUDForum. Page generated in 0.06062 seconds
