Home » Modeling » TMF (Xtext) » MyDslDocumentProvider failed to save
MyDslDocumentProvider failed to save [message #1764684] Thu, 01 June 2017 07:37 Go to next message
I have a EMF metamodel (named DSL) (file extension mydsl)
I create an Xtext project from this metamodel. (file extension my)
When I create a myDsl model, the model can be opened using the textual editor or the EMF editor.
However it is saved a TEXT and not XMI.
For me, It must be an xmi file and saved as XMI
To do that, I add this code in my MyDslUiModule
class MyDslUiModule extends AbstractMyDslUiModule {
	def Class<? extends XtextDocumentProvider> bindXtextDocumentProvider() {
	override Class<? extends IResourceForEditorInputFactory> bindIResourceForEditorInputFactory() {
		return MyDslResourceForEditorInputFactory
and I add the following classes
public class MyDslDocumentProvider extends XtextDocumentProvider {
	static {
		MyDslStandaloneSetup.doSetup();
	protected void setDocumentContent(IDocument document, InputStream contentStream, String encoding)
			throws CoreException {
		ResourceSet resourceSet = createResourceSet();
		Resource xmiResource = resourceSet.createResource(URI.createURI("temp.xmi"));
		Resource xtextResource = resourceSet.createResource(URI.createURI("temp.mydsl"));
		ByteArrayOutputStream os = new ByteArrayOutputStream();
		try {
			xmiResource.load(contentStream, Collections.emptyMap());
			xtextResource.getContents().addAll(xmiResource.getContents());
			xtextResource.save(os, Collections.EMPTY_MAP);
		} catch (IOException e) {
			throw new CoreException(
					new Status(IStatus.ERROR, "org.xtext.example.mydsl.ui", "Failed to save", e));
		} finally {
			try {
				os.close();
				contentStream.close();
						new Status(IStatus.ERROR, "org.xtext.example.mydsl.ui", "Failed to load", e));
		document.set(new String(os.toByteArray()));
	protected void doSaveDocument(IProgressMonitor monitor, Object element, IDocument document, boolean overwrite)
		try {
			XtextResource xtextResource = (XtextResource) resourceSet.createResource(URI.createURI("temp.mydsl"));
			InputStream is = new ByteArrayInputStream(document.get().getBytes());
			xtextResource.load(is, Collections.EMPTY_MAP);
			is.close();
			URI uri = URI.createPlatformResourceURI(
					((org.eclipse.ui.part.FileEditorInput) element).getFile().getFullPath().toString(), true);
			resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put("*", new XMIResourceFactoryImpl());
			Resource xmiResource = resourceSet.getResource(uri, true);
			((XMLResource) xmiResource).getDefaultSaveOptions().put(XMLResource.OPTION_URI_HANDLER,
					new URIHandlerImpl.PlatformSchemeAware());
			xmiResource.getContents().clear();
			xmiResource.getContents().addAll(xtextResource.getContents());
			EcoreUtil.resolveAll(xmiResource);
			xmiResource.save(Collections.EMPTY_MAP);
	private ResourceSet createResourceSet() {
		ResourceSet resourceSet = new ResourceSetImpl();
		resourceSet.getPackageRegistry().put(MyDslPackage.eNS_URI, MyDslPackage.eINSTANCE);
		return resourceSet;
and
public class MyDslResourceForEditorInputFactory extends JavaClassPathResourceForIEditorInputFactory {
	@Inject
	private IStorage2UriMapper storageToUriMapper;
	@Inject
	private Provider<XtextResource> provider;
	protected Resource createResourceFor(IStorage storage) {
		ResourceSet resourceSet = getResourceSet(storage);
		URI uri = URI.createPlatformResourceURI(storage.getFullPath().toString(), true);
		configureResourceSet(resourceSet, uri);
		XtextResource resource = (XtextResource) resourceSet.getResource(uri, false);
		// Modified to interpret a null resource and
		//  so create an XtextResource for an ecore file
		if (resource == null) {
			resource = (XtextResource) new XtextResourceFactory(provider).createResource(uri);
			resourceSet.getResources().add(resource);
		resource.setValidationDisabled(false);
		return resource;
	protected Resource createResourceFor(IJarEntryResource storage) {
		URI uri = storageToUriMapper.getUri(storage);
		resource.setValidationDisabled(true);
		return resource;
From now on, hen I try to create mydsl model, I obtain this error and the model is empty
!ENTRY org.eclipse.ui 4 0 2017-06-01 13:31:39.326
!MESSAGE FileDocumentProvider.createElementInfo
!STACK 1
org.eclipse.core.runtime.CoreException: Failed to save
	at org.eclipse.cmf.occi.core.xtext.ui.OCCIDocumentProvider.setDocumentContent(OCCIDocumentProvider.java:48)
	at org.eclipse.ui.editors.text.FileDocumentProvider.setDocumentContent(FileDocumentProvider.java:425)
	at org.eclipse.xtext.ui.editor.model.XtextDocumentProvider.setDocumentContent(XtextDocumentProvider.java:183)
	at org.eclipse.ui.editors.text.StorageDocumentProvider.createDocument(StorageDocumentProvider.java:227)
	at org.eclipse.xtext.ui.editor.model.XtextDocumentProvider.createDocument(XtextDocumentProvider.java:141)
	at org.eclipse.ui.editors.text.FileDocumentProvider.createElementInfo(FileDocumentProvider.java:721)
	at org.eclipse.xtext.ui.editor.model.XtextDocumentProvider.createElementInfo(XtextDocumentProvider.java:262)
	at org.eclipse.ui.texteditor.AbstractDocumentProvider.connect(AbstractDocumentProvider.java:392)
	at org.eclipse.ui.texteditor.AbstractTextEditor.doSetInput(AbstractTextEditor.java:4178)
	at org.eclipse.ui.texteditor.StatusTextEditor.doSetInput(StatusTextEditor.java:229)
	at org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.doSetInput(AbstractDecoratedTextEditor.java:1466)
	at org.eclipse.ui.editors.text.TextEditor.doSetInput(TextEditor.java:150)
	at org.eclipse.xtext.ui.editor.XtextEditor.doSetInput(XtextEditor.java:247)
	at org.eclipse.ui.texteditor.AbstractTextEditor$5.run(AbstractTextEditor.java:3154)
	at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:437)
	at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:353)
	at org.eclipse.ui.internal.WorkbenchWindow$14.run(WorkbenchWindow.java:2184)
	at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow.java:2180)
	at org.eclipse.ui.texteditor.AbstractTextEditor.internalInit(AbstractTextEditor.java:3172)
	at org.eclipse.ui.texteditor.AbstractTextEditor.init(AbstractTextEditor.java:3197)
	at org.eclipse.xtext.ui.editor.XtextEditor.init(XtextEditor.java:288)
	at org.eclipse.ui.internal.EditorReference.initialize(EditorReference.java:362)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:318)
	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:55)
	at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:966)
	at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:931)
	at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:151)
	at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:375)
	at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:294)
	at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:105)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:74)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:56)
	at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:129)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:975)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:651)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:757)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$0(PartRenderingEngine.java:728)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:722)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:706)
	at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:1324)
	at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer$1.handleEvent(LazyStackRenderer.java:72)
	at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:40)
	at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:233)
	at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:145)
	at org.eclipse.swt.widgets.Display.syncExec(Display.java:4814)
	at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:211)
	at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:36)
	at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:201)
	at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
	at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
	at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
	at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
	at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
	at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:94)
	at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:60)
	at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
	at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:173)
	at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.showElementInWindow(ModelServiceImpl.java:617)
	at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.bringToTop(ModelServiceImpl.java:581)
	at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.delegateBringToTop(PartServiceImpl.java:770)
	at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.bringToTop(PartServiceImpl.java:401)
	at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.showPart(PartServiceImpl.java:1214)
	at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:3261)
	at org.eclipse.ui.internal.WorkbenchPage.access$25(WorkbenchPage.java:3176)
	at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:3158)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3153)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3117)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3107)
	at org.eclipse.ui.ide.IDE.openEditor(IDE.java:563)
	at org.eclipse.ui.ide.IDE.openEditor(IDE.java:518)
	at org.eclipse.ui.wizards.newresource.BasicNewFileResourceWizard.performFinish(BasicNewFileResourceWizard.java:103)
	at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:790)
	at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:423)
	at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:618)
	at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:249)
	at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4256)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1501)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1524)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1509)
	at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1313)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4080)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3706)
	at org.eclipse.jface.window.Window.runEventLoop(Window.java:818)
	at org.eclipse.jface.window.Window.open(Window.java:794)
	at org.eclipse.ui.internal.navigator.wizards.WizardShortcutAction.run(WizardShortcutAction.java:99)
	at org.eclipse.jface.action.Action.runWithEvent(Action.java:473)
	at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:565)
	at org.eclipse.jface.action.ActionContributionItem.lambda$4(ActionContributionItem.java:397)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1121)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1022)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:150)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:693)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:610)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:138)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1519)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1492)
Caused by: org.eclipse.emf.ecore.resource.Resource$IOWrappedException: Fin prématurée du fichier.
	at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:195)
	at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:261)
	at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1518)
	at org.eclipse.cmf.occi.core.xtext.ui.OCCIDocumentProvider.setDocumentContent(OCCIDocumentProvider.java:44)
	... 128 more
Caused by: org.xml.sax.SAXParseExceptionpublicId: temp.xmi; systemId: file:///Applications/Eclipse%20copie.app/Contents/MacOS/temp.xmi; lineNumber: 1; columnNumber: 1; Fin prématurée du fichier.
	at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.createSAXParseException(ErrorHandlerWrapper.java:203)
	at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.fatalError(ErrorHandlerWrapper.java:177)
	at com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.reportError(XMLErrorReporter.java:400)
	at com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.reportError(XMLErrorReporter.java:327)
	at com.sun.org.apache.xerces.internal.impl.XMLScanner.reportFatalError(XMLScanner.java:1472)
	at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$PrologDriver.next(XMLDocumentScannerImpl.java:1014)
	at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:602)
	at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:505)
	at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:841)
	at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:770)
	at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:141)
	at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1213)
	at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:643)
	at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl.parse(SAXParserImpl.java:327)
	at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:175)
	... 131 more
!SUBENTRY 1 org.occiware.clouddesigner.occi.xtext.ui 4 0 2017-06-01 13:31:39.328
!MESSAGE Failed to save
!STACK 0
	... 131 more
1    [Worker-12] ERROR org.eclipse.xtext.builder.impl.XtextBuilder  - Passed org.eclipse.xtext.builder.clustering.CurrentDescriptions is not based on a resource set
java.lang.IllegalStateException: Passed org.eclipse.xtext.builder.clustering.CurrentDescriptions is not based on a resource set
	at org.eclipse.xtext.resource.containers.ResourceSetBasedAllContainersStateProvider.getResourceSet(ResourceSetBasedAllContainersStateProvider.java:44)
	at org.eclipse.xtext.resource.containers.ResourceSetBasedAllContainersStateProvider.get(ResourceSetBasedAllContainersStateProvider.java:26)
	at org.eclipse.xtext.resource.containers.StateBasedContainerManager.getState(StateBasedContainerManager.java:81)
	at org.eclipse.xtext.resource.containers.StateBasedContainerManager.internalGetContainerHandle(StateBasedContainerManager.java:106)
	at org.eclipse.xtext.resource.containers.StateBasedContainerManager.getVisibleContainers(StateBasedContainerManager.java:59)
	at org.eclipse.xtext.resource.impl.DefaultResourceDescriptionManager.isAffected(DefaultResourceDescriptionManager.java:138)
	at org.eclipse.xtext.builder.clustering.ClusteringBuilderState.queueAffectedResources(ClusteringBuilderState.java:525)
	at org.eclipse.xtext.builder.clustering.ClusteringBuilderState.doUpdate(ClusteringBuilderState.java:300)
	at org.eclipse.xtext.builder.builderState.AbstractBuilderState.update(AbstractBuilderState.java:116)
	at org.eclipse.xtext.builder.impl.XtextBuilder.doBuild(XtextBuilder.java:287)
	at org.eclipse.xtext.builder.impl.XtextBuilder.incrementalBuild(XtextBuilder.java:267)
	at org.eclipse.xtext.builder.impl.XtextBuilder.build(XtextBuilder.java:161)
	at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:735)
	at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:206)
	at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:246)
	at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:301)
	at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:304)
	at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:360)
	at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:383)
	at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:144)
	at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:235)
!ENTRY org.apache.log4j 4 0 2017-06-01 13:31:39.450
!MESSAGE org.eclipse.xtext.builder.impl.XtextBuilder  - Passed org.eclipse.xtext.builder.clustering.CurrentDescriptions is not based on a resource set
!STACK 0
Any idea/suggestion/example please?
Re: MyDslDocumentProvider failed to save [message #1764687 is a reply to message #1764684] Thu, 01 June 2017 07:52 Go to previous messageGo to next message
what do you intend to do?
are you sure the xml you try to load is ok and not ""
besides this i have never seens this usecase done.
(have seens persistence as texual though)
[Updated on: Thu, 01 June 2017 07:55] by Moderator
Re: MyDslDocumentProvider failed to save [message #1764692 is a reply to message #1764687] Thu, 01 June 2017 08:13 Go to previous messageGo to next message
just gave it a try and it works fine with the greeting example
Re: MyDslDocumentProvider failed to save [message #1764693 is a reply to message #1764692] Thu, 01 June 2017 08:16 Go to previous messageGo to next message
Is it possible to share your example (a zip or another way) to compare with my case study?
best regards
Re: MyDslDocumentProvider failed to save [message #1764716 is a reply to message #1764693] Thu, 01 June 2017 11:21 Go to previous messageGo to next message
See here
and this is my test xmi
(create it, open with MyDsl Editor)
Re: MyDslDocumentProvider failed to save [message #1764718 is a reply to message #1764716] Thu, 01 June 2017 11:48 Go to previous messageGo to next message
Thanks Christian,
But it is not the same case study.
My case study is based on an existing emf metamodel (and not generated from the Xtext grammar).
I share with you my code if you can, please, reproduce it and help me to resolve this bug.
  • Attachment: xtext.zip
    (Size: 1.71MB, Downloaded 188 times)
Re: MyDslDocumentProvider failed to save [message #1764722 is a reply to message #1764718] Thu, 01 June 2017 12:13 Go to previous messageGo to next message
is it intended you use the same file extension for dsl and editor?
Re: MyDslDocumentProvider failed to save [message #1764723 is a reply to message #1764722] Thu, 01 June 2017 12:16 Go to previous messageGo to next message
No, they must be different.
Re: MyDslDocumentProvider failed to save [message #1764725 is a reply to message #1764723] Thu, 01 June 2017 12:30 Go to previous messageGo to next message
in your case they are the same.
=> you need to replace
plugin.xml with plugin.xml_gen content
same for the file extension in MyDslDocumentProvider
// System.out.println("toto "+convertStreamToString(contentStream));
the convertStreamToString reads the file to end
=> (1) comment it out
=> (2) wrapt string into StringInputStream
Re: MyDslDocumentProvider failed to save [message #1764784 is a reply to message #1764725] Fri, 02 June 2017 05:14 Go to previous messageGo to next message
Thanks Chrisitan. It works perfectly.
So, the main issue is not here.
I just wanted to create a framework that corresponds to my real case.
The problem concerns the dsl itself.
Let me explain:
I have this metamodel
package myDsl : myDsl = 'http://www.xtext.org/example/mydsl/MyDsl'
	class Model
		property greetings : Greeting[*|1] { ordered composes };
	class Greeting
		attribute name : String[?];
		attribute condition : Boolean[1] = 'true';
Just a small precision, in my genmodel, the Resource Type == XMI ("none" is the default value in the genmodel)
Then, I generate a Xtext grammar from this metamodel
// automatically generated by Xtext
grammar org.xtext.example.mydsl.MyDsl with org.eclipse.xtext.common.Terminals
import "http://www.xtext.org/example/mydsl/MyDsl"
Model returns Model:
	{Model}
	'(' greetings+=Greeting* ')'
Greeting returns Greeting:
	'Hello'
	name=ID
		(condition?='condition')?
The main problem concerns the condition attribute.
Two sub-problems exist:
1) when condition is false
When opening the resource with the textual editor, this error appears.
java.lang.RuntimeException: Could not serialize Greeting via backtracking.
Constraint: Greeting_Greeting returns Greeting: (name=ID condition?='condition'?);
Values: name(1), condition(1)
Semantic Object: Model.greetings[0]->Greeting'Eclipseee'
URI: temp.my
Context: Greeting returns Greeting
As explained previously here https://www.eclipse.org/forums/index.php?t=msg&th=1086278&goto=1763635&#msg_1763635
It is necessary to customize the MyDslTransientValueService by adding the following code.
class MyDslRuntimeModule extends AbstractMyDslRuntimeModule {
	override Class<? extends ITransientValueService> bindITransientValueService() {
public class MyDslTransientValueService extends DefaultTransientValueService {
	override boolean isTransient(EObject owner, EStructuralFeature feature, int index) {
		if (feature == MyDslPackage.Literals.GREETING__CONDITION) {
			var Boolean value = owner.eGet(feature) as Boolean;
			if (value === null) {
				return false;
			} else if (value == Boolean.FALSE) {
				return true;
		return super.isTransient(owner, feature, index);
Therefore, this sub-problem is resolved.
2) when condition is true
This is the real problem.
If condition is true (shown by the emf editor), the "condition" keyword doesn't appear in the textual model.
In addition, when I try to add it manually, It is hidden during the save.
I saw that in the xmi, the condition attribute doesn't appear when it is true.
As explained in the EMF forum, to serialize the default value, it is necessary to customize the MyDslResourceImpl by overriding the doSave method as shown in the following.
public class MyDslResourceImpl extends XMIResourceImpl {
	 * Creates an instance of the resource.
	 * <!-- begin-user-doc -->
	 * <!-- end-user-doc -->
	 * @param uri the URI of the new resource.
	 * @generated
	public MyDslResourceImpl(URI uri) {
		super(uri);
	public void doSave(OutputStream outputStream, Map<?,?> options) throws
	IOException {
	this.getDefaultSaveOptions().put(XMLResource.OPTION_KEEP_DEFAULT_CONTENT,
	Boolean.TRUE);
	super.doSave(outputStream, options);
} //MyDslResourceImpl
Consequently, the condition attribute is serialized when it is true.
However, the "condition" keyword doesn't appear in the textual model.
And, when I edit the textual model (add white space for example); during saving, the xmi is changed by removing condition="true" from the xmi.
To conclude, my questions are:
How can I show the "condition" keyword when the condition attribute is true?
How can I inhibit Xtext removing condition="true" from the xmi?
I added a demo in the attachment to more explain the issue.
I share Also the source code with an example project.
best regards,
  • Attachment: MyDslXtext.mov
    (Size: 13.14MB, Downloaded 109 times)
    (Size: 1.71MB, Downloaded 242 times)
Re: MyDslDocumentProvider failed to save [message #1764797 is a reply to message #1764784] Fri, 02 June 2017 05:56 Go to previous messageGo to next message
(1) i dont understand your org.xtext.example.mydsl.ui.MyDslDocumentProvider.doSaveDocument(IProgressMonitor, Object, IDocument, boolean)
(2) you may need to customize and bind
public class CustomLegacyTransientValueService extends LegacyTransientValueService {
	public ValueTransient isValueTransient(EObject semanticObject, EStructuralFeature feature) {
		//TODO
		return super.isValueTransient(semanticObject, feature);
	protected boolean defaultValueIsSerializeable(EStructuralFeature feature) {
		//TODO
		return super.defaultValueIsSerializeable(feature);
	def Class<? extends org.eclipse.xtext.serializer.sequencer.ITransientValueService> bindITransientValueServiceOld() {
Re: MyDslDocumentProvider failed to save [message #1764802 is a reply to message #1764797] Fri, 02 June 2017 06:27 Go to previous messageGo to next message
//resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put("*", new XMIResourceFactoryImpl());
=> without commenting out your factory is not used.
and i miss a customization of nothing => value = false
e.g. via
import org.eclipse.emf.ecore.EClassifier;
import org.eclipse.emf.ecore.EObject;
import org.eclipse.xtext.parser.DefaultEcoreElementFactory;
import myDsl.Greeting;
public class CustomDefaultEcoreElementFactory extends DefaultEcoreElementFactory {
public EObject create(EClassifier classifier) {
EObject created = super.create(classifier);
if (created instanceof Greeting) {
((Greeting) created).setCondition(false);
return created;
Re: MyDslDocumentProvider failed to save [message #1764809 is a reply to message #1764802] Fri, 02 June 2017 07:09 Go to previous messageGo to next message
and never do this:
static {
Re: MyDslDocumentProvider failed to save [message #1764862 is a reply to message #1764809] Fri, 02 June 2017 12:02 Go to previous messageGo to next message
I customize CustomLegacyTransientValueService like that
		if (feature.getName().equals("condition")) {
			if (((Greeting) semanticObject).isCondition())
				return ValueTransient.NO;
			else
				return ValueTransient.YES;
		} else {
I comment the following lines
and
// static {
// MyDslStandaloneSetup.doSetup();
the following class CustomDefaultEcoreElementFactory, where must be localized?
I put it in org.xtext.example.mydsl.
is it correct?
return created;
I am very near to resolve the issue.
Actually, when I change from the emf model, the changes are propagated to the textual model (changing condition to true, "condition" keyword appears, changing condition to false, "condition" keyword removed).
The only issue at this moment, it that, when I remove "condition" keyword from my textual model, it reappears when I save.
If you reproduced my case study, can you please share the code after your customizations please?
Re: MyDslDocumentProvider failed to save [message #1764863 is a reply to message #1764862] Fri, 02 June 2017 12:10 Go to previous messageGo to next message
this is what i meant !?!
did you bind the factory:
	override bindIAstFactory() {
			if ((boolean)semanticObject.eGet(feature)) {
			return true;
Re: MyDslDocumentProvider failed to save [message #1764922 is a reply to message #1764863] Sat, 03 June 2017 14:25 Go to previous message
Thanks Christian. It works perfectly ;-)
Previous Topic:Referencing to UML elements in Xtext Editor
Next Topic:Deleting first character
Current Time: Tue Sep 16 14:30:48 EDT 2025
Powered by FUDForum. Page generated in 0.05234 seconds
