name may not be null xtext 2.12 [message #1764675] |
Thu, 01 June 2017 07:05  |
I upgraded my dsl from 2.11 2.12. With 2.11 it was ok but now it throws below:
Caused by: java.lang.IllegalStateException: name may not be null
at org.eclipse.xtext.xbase.compiler.AbstractXbaseCompiler.getFavoriteVariableName(AbstractXbaseCompiler.java:568)
at org.eclipse.xtext.xbase.compiler.AbstractXbaseCompiler.declareFreshLocalVariable(AbstractXbaseCompiler.java:627)
at org.eclipse.xtext.xbase.compiler.FeatureCallCompiler._toJavaStatement(FeatureCallCompiler.java:176)
at org.eclipse.xtext.xbase.compiler.FeatureCallCompiler.doInternalToJavaStatement(FeatureCallCompiler.java:111)
at org.eclipse.xtext.xbase.compiler.XbaseCompiler.doInternalToJavaStatement(XbaseCompiler.java:385)
at henkan.dsl.jvmmodel.HenkanCompiler.doInternalToJavaStatement(HenkanCompiler.java:55)
at org.eclipse.xtext.xbase.compiler.AbstractXbaseCompiler.internalToJavaStatement(AbstractXbaseCompiler.java:473)
at org.eclipse.xtext.xbase.compiler.FeatureCallCompiler.prepareExpression(FeatureCallCompiler.java:534)
at org.eclipse.xtext.xbase.compiler.FeatureCallCompiler._toJavaStatement(FeatureCallCompiler.java:151)
at org.eclipse.xtext.xbase.compiler.XbaseCompiler._toJavaStatement(XbaseCompiler.java:1060)
at org.eclipse.xtext.xbase.compiler.XbaseCompiler.doInternalToJavaStatement(XbaseCompiler.java:363)
at org.eclipse.xtext.xbase.compiler.XbaseCompiler._toJavaStatement(XbaseCompiler.java:394)
at org.eclipse.xtext.xbase.compiler.XbaseCompiler.doInternalToJavaStatement(XbaseCompiler.java:349)
at org.eclipse.xtext.xbase.compiler.AbstractXbaseCompiler.compile(AbstractXbaseCompiler.java:294)
at org.eclipse.xtext.xbase.compiler.XbaseCompiler.toAnonymousClass(XbaseCompiler.java:1660)
at org.eclipse.xtext.xbase.compiler.XbaseCompiler._toJavaStatement(XbaseCompiler.java:1600)
at org.eclipse.xtext.xbase.compiler.XbaseCompiler.doInternalToJavaStatement(XbaseCompiler.java:353)
at org.eclipse.xtext.xbase.compiler.FeatureCallCompiler._toJavaStatement(FeatureCallCompiler.java:154)
at org.eclipse.xtext.xbase.compiler.AbstractXbaseCompiler.compile(AbstractXbaseCompiler.java:274)
at org.eclipse.xtext.xbase.compiler.JvmModelGenerator.compile(JvmModelGenerator.java:1057)
at org.eclipse.xtext.xbase.compiler.JvmModelGenerator.generateExecutableBody(JvmModelGenerator.java:1034)
at org.eclipse.xtext.xbase.compiler.JvmModelGenerator._generateMember(JvmModelGenerator.java:798)
at org.eclipse.xtext.xbase.compiler.JvmModelGenerator.generateMember(JvmModelGenerator.java:1660)
at org.eclipse.xtext.xbase.compiler.JvmModelGenerator.lambda$generateMembersInBody$2(JvmModelGenerator.java:292)
at org.eclipse.xtext.xbase.lib.ObjectExtensions.operator_doubleArrow(ObjectExtensions.java:139)
at org.eclipse.xtext.xbase.compiler.LoopExtensions.forEach(LoopExtensions.java:35)
at org.eclipse.xtext.xbase.compiler.JvmModelGenerator.generateMembersInBody(JvmModelGenerator.java:295)
at org.eclipse.xtext.xbase.compiler.JvmModelGenerator._generateBody(JvmModelGenerator.java:269)
at org.eclipse.xtext.xbase.compiler.JvmModelGenerator.generateBody(JvmModelGenerator.java:1632)
at org.eclipse.xtext.xbase.compiler.JvmModelGenerator.generateType(JvmModelGenerator.java:226)
at org.eclipse.xtext.xbase.compiler.JvmModelGenerator._internalDoGenerate(JvmModelGenerator.java:213)
at org.eclipse.xtext.xbase.compiler.JvmModelGenerator.internalDoGenerate(JvmModelGenerator.java:1615)
at org.eclipse.xtext.xbase.compiler.JvmModelGenerator.doGenerate(JvmModelGenerator.java:196)
at org.eclipse.xtext.generator.GeneratorDelegate.doGenerate(GeneratorDelegate.java:45)
at org.eclipse.xtext.generator.GeneratorDelegate.generate(GeneratorDelegate.java:34)
at org.eclipse.xtext.build.IncrementalBuilder$InternalStatefulIncrementalBuilder.generate(IncrementalBuilder.java:309)
at org.eclipse.xtext.build.IncrementalBuilder$InternalStatefulIncrementalBuilder.lambda$launch$6(IncrementalBuilder.java:246)
at org.eclipse.xtext.build.ClusteringStorageAwareResourceLoader.lambda$executeClustered$1(ClusteringStorageAwareResourceLoader.java:77)
at org.eclipse.xtext.xbase.lib.internal.FunctionDelegate.apply(FunctionDelegate.java:42)
at com.google.common.collect.Lists$TransformingRandomAccessList$1.transform(Lists.java:617)
at com.google.common.collect.TransformedIterator.next(TransformedIterator.java:48)
at java.util.AbstractCollection.toArray(AbstractCollection.java:141)
at java.util.ArrayList.addAll(ArrayList.java:577)
at com.google.common.collect.Iterables.addAll(Iterables.java:352)
at org.eclipse.xtext.build.ClusteringStorageAwareResourceLoader.executeClustered(ClusteringStorageAwareResourceLoader.java:80)
at org.eclipse.xtext.build.BuildContext.executeClustered(BuildContext.java:55)
at org.eclipse.xtext.build.IncrementalBuilder$InternalStatefulIncrementalBuilder.launch(IncrementalBuilder.java:251)
at org.eclipse.xtext.build.IncrementalBuilder.build(IncrementalBuilder.java:399)
at org.eclipse.xtext.build.IncrementalBuilder.build(IncrementalBuilder.java:384)
at org.eclipse.xtext.ide.server.ProjectManager.doBuild(ProjectManager.java:115)
at org.eclipse.xtext.ide.server.BuildManager.internalBuild(BuildManager.java:171)
at org.eclipse.xtext.ide.server.BuildManager.doBuild(BuildManager.java:125)
at org.eclipse.xtext.ide.server.WorkspaceManager.doBuild(WorkspaceManager.java:153)
at org.eclipse.xtext.ide.server.WorkspaceManager.didOpen(WorkspaceManager.java:202)
at org.eclipse.xtext.ide.server.LanguageServerImpl.lambda$didOpen$4(LanguageServerImpl.java:263)
at org.eclipse.xtext.ide.server.concurrent.RequestManager.runWrite(RequestManager.java:71)
at org.eclipse.xtext.ide.server.LanguageServerImpl.didOpen(LanguageServerImpl.java:266)
... 17 more
Below is the xtext expression that throws this line
rows.forEach[row|
if(row.age>10)
emit("anil" + 1 named col1,row.age named name)
any idea why?
FUDForum. Page generated in 0.03934 seconds
