OOmph offline installation failing [message #1747271] |
Fri, 11 November 2016 08:24  |
I was trying to run the Oomph installer on a pure offline machine. Therefore I first installed eclipse on an online machine. then I transferred the bundlepool along with the <windows> user/.eclipse folder to the offline PC.
I can start the installer there but it fails on resolving depedencies showing:
Unable to connect to repository:
http://download.eclipse.org/technology/epp/packages/neon/content.xml
this is one of the added repositories. Sure it is not there, but I thought as everything should be available in the bundle pool, why is eclipse calling home during install?
Do I have to copy additional data to the offline machine?
thanks
Christian
Re: OOmph offline installation failing [message #1747328 is a reply to message #1747297] |
Sat, 12 November 2016 04:00   |
Well, I could start listing places that I think might be an issue, but in the end, I wonder what the overall goal here is? There's ~/.eclipse/org.eclipse.oomph.p2/cache where Oomph caches the things that p2 itself doesn't always cache so well. There's p2's own cache, but that's in the agent which you probably copied with the pool, I guess. There's the ~/.eclipse/org.eclipse.oomph.setup/cache where setup files are cached. But you suggest you've copied these. I assume you've selected the Offline check mark.
But what's the goal? Yes, I understand of course you want something to work offline, but why not just create an installation and copy it to the offline machine? I.e., there must be flexibility you're trying to achieve, that likely would be far better achieved if you created mirrors of the update sites and use those mirrors so that the full flexibility of being able to install anything would be possible...
FUDForum. Page generated in 0.30941 seconds
