Device SSL Certificate - Raspberry 3 [message #1764517] |
Tue, 30 May 2017 14:33  |
Hello there,
I've managed to build up a bundle that connects to ble devices and gets data from them, similar to the Bluetooth LE Example, and it works well.
Now, I want to publish the data to the cloud, using AWS. I've been following the step by step guide on how to connect an Eclipse Kura™ device to the Amazon AWS IoT platform, but in step 8.
I get the following error:
* Image attached below since I can't post external links *
I know I have followed the steps correctly since it works fine when doing it in Kura emulation mode (Im getting this error in the Raspberry 3).
Im using kura 2.1.0. I attach below the logs that appears when clicking on 'Apply'.
¿Can someone lend me a hand?
Thanks in advance,
Javi.
Re: Device SSL Certificate - Raspberry 3 [message #1764523 is a reply to message #1764521] |
Tue, 30 May 2017 16:17  |
Thanks Matteo for the fast answer. I have checked that and I have managed to solve the problem! The thing was that I had put as keystore '/opt/eclipse/kura/security/cacerts' instead of '/opt/eclipse/security/cacerts', I feel so dumb...
Thank you so much again for your help, really appreciate your work.
Javi.
FUDForum. Page generated in 0.06998 seconds
