Home » Modeling » EMF » XML serialization
XML serialization [message #1764385] Mon, 29 May 2017 06:06 Go to next message
Hello, I have a little problem with the XML serialization.
I want to deserialize and serialize the following xml.
  <spec>
        <customerAddress>asd</customerAddress>
        <OrderIDREF>k1</OrderIDREF>
        <OrderIDREFS>k1 k2</OrderIDREFS>
  </spec>
The orders that are referenced have the id (eType="ecore:EDataType http://www.eclipse.org/emf/2003/XMLType#//ID" iD="true")
The orderIDREF reference works fine with this annotation
  <eAnnotations source="http:///org/eclipse/emf/ecore/util/ExtendedMetaData">
        <details key="kind" value="element"/>
        <details key="name" value="OrderIDREF"/>
        <details key="namespace" value="##targetNamespace"/>
      </eAnnotations>
The issue is the orderIDREFS reference. I figured out that kind element only works with single references so i tried group and elementWildcard. They also work when loading the xml but when saving it, it always moves the entry into the spec tag like this
<spec OrderIDREFS="k1 k2">
</spec>
When i want to load this again it fails with "Feature 'OrderIDREFS' not found"
Is there any setting that I can make to force it to leave it in its own tag?
Thank you
[Updated on: Mon, 29 May 2017 07:00] by Moderator
Re: XML serialization [message #1764390 is a reply to message #1764385] Mon, 29 May 2017 06:34 Go to previous messageGo to next message
Did you try "simple" as the kind?
Re: XML serialization [message #1764391 is a reply to message #1764390] Mon, 29 May 2017 06:52 Go to previous messageGo to next message
With 'simple' the Feature not found exception occurs while loading the original xml.
Re: XML serialization [message #1764426 is a reply to message #1764391] Mon, 29 May 2017 11:26 Go to previous messageGo to next message
I tried defining an XSD that uses type IDREFS but the model that comes out is ugly and includes a "holder" EClass with a feature of simple kind... So unfortunately there isn't a way to get the serialization you want without making the model ugly. If you must deal with a given XML serialization, it's probably best to use the XML Schema for it, or define an XML Schema for it, and import that into an Ecore model.
Re: XML serialization [message #1764430 is a reply to message #1764426] Mon, 29 May 2017 12:14 Go to previous messageGo to next message
double post. sry
[Updated on: Mon, 29 May 2017 12:19] by Moderator
Re: XML serialization [message #1764432 is a reply to message #1764426] Mon, 29 May 2017 12:17 Go to previous messageGo to next message
Hi Ed,
thanks for the answer.
I actually have a xml schema. But IDREFS will only be a string attribute. I thought it would be great if they are represented as eReferences with the real Type. Then the resolving is done at load time and it also checks if the string refs are valid and so on. It actual works really well.
I have a URIHandler to deresolve and resolve the uris the right way.
If i store them in seperated tags it also works with the element kind.
<spec>
   <OrderIDREFS>k1</OrderIDREFS>
   <OrderIDREFS>k2</OrderIDREFS>
 </spec>
Just the space seperated multi references in a single tag. don't work.
I thought maybe I miss something. But maybe it is not possible.
Thanks for your help.
Re: XML serialization [message #1764436 is a reply to message #1764432] Mon, 29 May 2017 12:57 Go to previous message
You can use IDREFS as the type but also include ecore:reference="qname" to refer to the complex type you want it to really be. That should work, though the model will include an intermediate "holder" class. E.g., this sort of works but the ecore:eOpposite are invalid because holder class holds the reference...
<xsd:schema targetNamespace="http://www.example.eclipse.org/Library"
    xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore"
    xmlns:lib="http://www.example.eclipse.org/Library"
    xmlns:xsd="http://www.w3.org/2001/XMLSchema">
  <xsd:complexType name="Book">
    <xsd:sequence>
      <xsd:element name="title" type="xsd:string"/>
      <xsd:element name="pages" type="xsd:int"/>
      <xsd:element name="category" type="lib:BookCategory"/>
      <xsd:element name="author" type="xsd:IDREF"
          ecore:reference="lib:Writer" ecore:opposite="books"/>
    </xsd:sequence>
  </xsd:complexType>
  <xsd:complexType name="Writer">
    <xsd:sequence>
      <xsd:element name="name" type="xsd:string"/>
      <xsd:element maxOccurs="unbounded" minOccurs="0" name="books"
          type="xsd:IDREFS" ecore:reference="lib:Book" ecore:opposite="author"/>
    </xsd:sequence>
  </xsd:complexType>
  <xsd:complexType name="Library">
    <xsd:sequence>
          name="writers" type="lib:Writer"/>
          name="books" type="lib:Book"/>
    </xsd:sequence>
  </xsd:complexType>
  <xsd:simpleType name="BookCategory">
    <xsd:restriction base="xsd:NCName">
      <xsd:enumeration value="Mystery"/>
      <xsd:enumeration value="ScienceFiction"/>
      <xsd:enumeration value="Biography"/>
    </xsd:restriction>
  </xsd:simpleType>
</xsd:schema>
Previous Topic:Loading Xtext Resource Into EMF Editor Breaks on Save?
Next Topic:[CDO] IllegalStateException when saving custom Permission
Current Time: Fri Jul 25 23:04:32 EDT 2025
Powered by FUDForum. Page generated in 0.06776 seconds
