Confusing Property Types [message #1764060] |
Wed, 24 May 2017 09:21  |
Hello everybody,
and thank you for your help.
I am trying to understand how to set class property types in Papyrus class diagrams.
I want something like this
List<E> Attribute1
Map<K> Attribute2
As you see in the picture, I created a new class with a property Attribute1 and already tried the same as with Attribute2 with type <<ModelLibrary>> Ecore Primitive Types -> List.
Next with Attribute2 I tried with Map
But somehow the type becomes E or likewise K not List<E> and Map<K>.
What I got to understand is, that when chosing a type, you can chose to set several properties (not in the sense of class diagrams) of the typed element.
So I don't have to chose one of the blue lined things under the type but can set all.
Appart from that, I didn't understand much, I can set the package and namespace like in object oriented languages, the owner is the element in which context the property appears, I guess, which seems somehow useless here since it already is a property of the class, so the context should be clear.
I guessed ownedElement is an Element in a bin of the Map as a key value pair,
but when I open it, the only thing I can only chose Redefinable Template Signature, no idea, what ownedElement is supposed to be now.
But what I wanted is to set a template signature anyway.
But I want the type to be the whole thing on the traversed tree, not just the template parameter.
What do I need to do to achieve that?
Thank you for your time and trouble.
Best regards
Philip.
Re: Confusing Property Types [message #1764358 is a reply to message #1764244] |
Mon, 29 May 2017 03:28   |
Sorry,
I see I was unclear concerning owned Element, what I ment was Map -> owned Element.
I would think since Map is a container for (key, value) pairs, one of those would be an owned Element of Map.
Concerning the main problem, instead of in my other thread, here I don't want something like Map<Int> or Map<String>, in this case here I want the template not be bound, it should remain variable in its template parameter like Map<E: Class> or something like that, do I still need a parameter substitution?
Best
Philip.
[Updated on: Mon, 29 May 2017 03:29] by Moderator
Re: Confusing Property Types [message #1764371 is a reply to message #1764358] |
Mon, 29 May 2017 05:31  |
HI Philip,
you can type properties of your template class with the formal template parameters, e.g. with the E, K (or T in my example). Map -> <Classifier Template Signature> -> <Classifier Template Parameter> T -> T. There is no need for the advanced model explorer.
HTH (not sure, if I understood the problem)
Ansgar
FUDForum. Page generated in 0.05908 seconds
