Home » Archived » BIRT » Error deploying Birt Viewer on Tomcat
Error deploying Birt Viewer on Tomcat [message #642249] Tue, 30 November 2010 10:07 Go to next message
I am having problems deploying the birt viewer on tomcat 6, on our Linux Server. I followed the instructions here:
http://www.eclipse.org/birt/phoenix/deploy/viewerSetup.php
I first tried it on a tomcat installed on my windows pc, and it worked as expected, I was able to see the sample report, no errors. Then I did the same on the server. here are the steps:
1. copied the WebViewerExample directory into the webapps folder in Tomcat
2.added the commons-logging.1.1.1.jar to the WebViewerExample/WEB-INF/lib directory
3. restarted Tomcat
4. Clicked on WebViewerExample in the Tomcat manager. This displayed the page where it says:
BIRT viewer has been installed.
Thank you for your choosing BIRT (Business Intelligence Reporting Tool).
Viewer Version : 2.6.0
Engine Version: 2.6.0
JRE version: 1.6.0_12
View Example
5. Clicked on "View example" and got the following error:
- Fatal error occurred when try to startup report engine.
org.eclipse.birt.report.exception.ViewerException: Fatal error occurred when try to startup report engine. at org.eclipse.birt.report.service.ReportEngineService.setEngin eContext(ReportEngineService.java:326) at org.eclipse.birt.report.service.BirtViewerReportService.setC ontext(BirtViewerReportService.java:1022) at org.eclipse.birt.report.servlet.ViewerServlet.__getContext(V iewerServlet.java:148) at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer vlet.doGet(BirtSoapMessageDispatcherServlet.java:151) at javax.servlet.http.HttpServlet.service(HttpServlet.java:617) at org.apache.axis.transport.http.AxisServletBase.service(AxisS ervletBase.java:327) at javax.servlet.http.HttpServlet.service(HttpServlet.java:717) at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer vlet.service(BirtSoapMessageDispatcherServlet.java:122) at org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:290) at org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:206) at org.eclipse.birt.report.filter.ViewerFilter.doFilter(ViewerF ilter.java:68) at org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:206) at org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:233) at org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:191) at org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:128) at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorRepo rtValve.java:102) at org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:109) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAd apter.java:286) at org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:845) at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHand ler.process(Http11Protocol.java:583) at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoin t.java:447) at java.lang.Thread.run(Thread.java:619)
The catalina.out logfile doesn't say more than this.
Does anybody have an idea of what could be wrong?
Please note that tomcat on my pc is out of the box, I haven't changed anything, whereas the tomcat on the server has been installed by our system administrator, and I don't know whether he configured anything that could be causing the problem...
Anna
Re: Error deploying Birt Viewer on Tomcat [message #642270 is a reply to message #642249] Tue, 30 November 2010 11:15 Go to previous messageGo to next message
Do you have anything in this directory
WEB-INF\platform\configuration
other than the config.ini?
Jason
On 11/30/2010 10:07 AM, pellianna@gmail.com wrote:
> 3. restarted Tomcat
> page where it says:
> View Example
> ilter.java:68) at
> apter.java:286) at
> ssor.java:845) at
> Does anybody have an idea of what could be wrong? Please note that
> the problem...
> Thanks
> Anna
Re: Error deploying Birt Viewer on Tomcat [message #642410 is a reply to message #642270] Wed, 01 December 2010 04:01 Go to previous messageGo to next message
Hi Jason
thanks for your reply.
The configuration directory only contains the config.ini file.
If I stop and start tomcat I actually see an error message in catalina.out, even before I click on the WebViewerExample:
at org.eclipse.birt.report.listener.ViewerServletContextListene r.contextInitialized(ViewerServletContextListener.java:62)
at org.apache.catalina.core.StandardContext.listenerStart(Stand ardContext.java:3843)
at org.apache.catalina.core.StandardContext.start(StandardConte xt.java:4342)
at org.apache.catalina.core.ContainerBase.addChildInternal(Cont ainerBase.java:791)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBas e.java:771)
at org.apache.catalina.core.StandardHost.addChild(StandardHost. java:525)
at org.apache.catalina.startup.HostConfig.deployDirectory(HostC onfig.java:926)
at org.apache.catalina.startup.HostConfig.deployDirectories(Hos tConfig.java:889)
at org.apache.catalina.startup.HostConfig.deployApps(HostConfig .java:492)
at org.apache.catalina.startup.HostConfig.start(HostConfig.java :1149)
at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostCo nfig.java:311)
at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent (LifecycleSupport.java:117)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.j ava:1053)
at org.apache.catalina.core.StandardHost.start(StandardHost.jav a:719)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.j ava:1045)
at org.apache.catalina.core.StandardEngine.start(StandardEngine .java:443)
at org.apache.catalina.core.StandardService.start(StandardServi ce.java:516)
at org.apache.catalina.core.StandardServer.start(StandardServer .java:710)
at org.apache.catalina.startup.Catalina.start(Catalina.java:578 )
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:2 88)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:41 3)
Dec 1, 2010 9:54:47 AM org.apache.coyote.http11.Http11Protocol start
Also, there is a warning when I click on the link for the example:
WARNING: Unable to find required classes (javax.activation.DataHandler and javax.mail.internet.MimeMultipart). Attachment support is disabled.
but I get this on my pc too and it still works.
Thanks again
Anna
Re: Error deploying Birt Viewer on Tomcat [message #642571 is a reply to message #642410] Wed, 01 December 2010 14:26 Go to previous messageGo to next message
The warning and error are separate. Do the user who starts tomcat have
write permission to the configuration directory?
Jason
On 12/1/2010 4:01 AM, Anna wrote:
> Hi Jason
> thanks for your reply. The configuration directory only contains the
> config.ini file.
> xt.java:4342)
> ainerBase.java:791)
> onfig.java:926)
> tConfig.java:889)
> nfig.java:311)
> ce.java:516)
> ssorImpl.java:39)
> at java.lang.reflect.Method.invoke(Method.java:597)
> Thanks again
> Anna
Re: Error deploying Birt Viewer on Tomcat [message #642672 is a reply to message #642571] Thu, 02 December 2010 04:59 Go to previous messageGo to next message
Hi Jason
yes, it all belongs to the same user.
Anna
Re: Error deploying Birt Viewer on Tomcat [message #642756 is a reply to message #642672] Thu, 02 December 2010 10:38 Go to previous messageGo to next message
Can you create a jsp page at the top level of the BIRT Viewer with the
following content:
<%@ page import="java.io.File;" %>
<%= System.getProperty("java.version")%>
<br>
<%= application.getAttribute( "javax.servlet.context.tempdir" )%>
<br>
<%= application.getRealPath("/WEB-INF/Platform/") %>
<br>
File tst = new File(application.getRealPath("/WEB-INF/Platform/"));
if( tst.canWrite()){
Platform Writable
}else{
Platform Not Writable
<br>
File tst2 = new
File(application.getRealPath("/WEB-INF/Platform/configuration "));
if( tst2.canWrite()){
Configuration Writable
}else{
Configuration Not Writable
Run it and post the results?
Jason
On 12/2/2010 4:59 AM, Anna wrote:
> Hi Jason
> Thanks
> Anna
Re: Error deploying Birt Viewer on Tomcat [message #642768 is a reply to message #642756] Thu, 02 December 2010 11:14 Go to previous messageGo to next message
Hi Jason
here it is:
1.6.0_12
/netfs/data/avalon_03d/server/apache-tomcat-6.0.18/work/Cata lina/localhost/WebViewerExample2
/CHBS/apps/avalonws/server/apache-tomcat-6.0.18/temp/13-WebV iewerExample2/WEB-INF/Platform
So it does have to do with not being able to write into the configuration directory....how can I fix this?
Thanks again
Anna
Re: Error deploying Birt Viewer on Tomcat [message #642773 is a reply to message #642768] Thu, 02 December 2010 11:29 Go to previous messageGo to next message
Hi Jason
I think there were typos in the JSP...unix is case sensitive, so I put Platform lowercase and removed the empty space under configuration. Now the code is:
<br>
<br>
<br>
File tst = new File(application.getRealPath("/WEB-INF/platform/"));
Platform Writable
}else{
<br>
File tst2 = new
File(application.getRealPath("/WEB-INF/platform/configuration/ "));
}else{
and I get:
1.6.0_12
/CHBS/apps/avalonws/server/apache-tomcat-6.0.18/temp/15-WebV iewerExample2/WEB-INF/Platform
Platform Writable
Kind regards
Anna
Re: Error deploying Birt Viewer on Tomcat [message #642794 is a reply to message #642773] Thu, 02 December 2010 12:14 Go to previous messageGo to next message
Anna,
Any chance you could try the 2.6.1 viewer?
I am not certain this will make a difference but could you give it a
try. You and another user are having the same issue and it appears both
are using 2.6.0.
Jason
On 12/2/2010 11:29 AM, Anna wrote:
> Hi Jason
> the code is:
> <br>
> <br>
> <br>
> Platform Writable
> }else{
> <br>
> File tst2 = new
> }else{
> and I get:
> 1.6.0_12 /netfs/data/avalon_03d/server/apache-tomcat-6.0.18/work/Cata
> iewerExample2/WEB-INF/Platform Platform Writable Configuration Writable
> Kind regards
> Anna
Re: Error deploying Birt Viewer on Tomcat [message #642798 is a reply to message #642794] Thu, 02 December 2010 12:59 Go to previous messageGo to next message
Hi Jason
the other user is actually a student working in my group - I didn't realize that we had ended up talking about the same issue, I saw he had posted about issues with a db connection... I am so sorry about this!
I am at home right now and don't have access to the server, so no screenshot, but yesterday I tried and downloaded the latest runtime too to test it, still the same problem Sad
I really appreciate all your help
thanks
Anna
Re: Error deploying Birt Viewer on Tomcat [message #643588 is a reply to message #642798] Tue, 07 December 2010 10:16 Go to previous messageGo to next message
I just found out that if I undeploy one of the applications that are already in tomcat, birt-viewer works.
I made a copy of my tomcat installation on the same server, changed the port numbers, undeployed everything but birt-viewer, then one by one deployed everything again. This way I am pretty sure that it's one of the other applications that causes the problem, but only to birt-viewer. It doesn't cause any issues to the other ones.
I know it's difficult for anyone to try and troubleshoot this....but maybe someone could give me a hint on how to go about it? If there is a conflict of some sort shouldn't this be visible in a log file?
Anna
Re: Error deploying Birt Viewer on Tomcat [message #643621 is a reply to message #643588] Tue, 07 December 2010 11:07 Go to previous messageGo to next message
did you find the app that causes the birt-viewer to fail?
If you undeploy it and deploy the birt-viewer does it work?
if it does and then you redeploy the app does the viewer stop working?
Also you can set the log level for the viewer to fine in the web.xml but
this may not help if the viewer does not start at all.
Jason
On 12/7/2010 10:16 AM, Anna wrote:
> Hi
> Thanks
> Anna
Re: Error deploying Birt Viewer on Tomcat [message #643625 is a reply to message #643621] Tue, 07 December 2010 11:44 Go to previous messageGo to next message
Hi Jason
yes, I know which application is causing the issue. If I undeploy it and restart Tomcat, birt-viewer works. If I deploy it again, and restart, I get again the error above and birt-viewer doesn't start.
I have done this several times, I am pretty sure this is the problem.
I will try to change the logging level as you suggested. Where would the additional info go, catalina.out, or does birt write other log files?
I didn't think this type of conflict could happen...
Anna
Re: Error deploying Birt Viewer on Tomcat [message #643693 is a reply to message #643625] Tue, 07 December 2010 16:51 Go to previous messageGo to next message
It would go in the log file under the logs directory of the viewer, but
it might not right anything to it if the engine never starts.
Jason
On 12/7/2010 11:44 AM, Anna wrote:
> Hi Jason
> Thanks
> Anna
Re: Error deploying Birt Viewer on Tomcat [message #1764243 is a reply to message #642249] Sat, 27 May 2017 03:08 Go to previous message
Dear Team,
I am getting problem when i am deploying birt 4.6.0 into tomcat 7.47 and JDK/jre 1.8
error is as follows
May 27, 2017 12:20:11 PM org.apache.catalina.core.ContainerBase addChildInternal
SEVERE: ContainerBase.addChild: start:
org.apache.catalina.LifecycleException: Failed to start component [StandardEngine[Catalina].StandardHost[localhost].StandardContext[/birt]]
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:154)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:901)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:877)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:633)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:983)
at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1660)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
please tell me any compatibility issue is there ?
Thanks in Advance ..
Previous Topic:BIRT 2.5.1
Next Topic:Use Javascript variable value in dataset
Current Time: Wed Jul 23 11:24:49 EDT 2025
Powered by FUDForum. Page generated in 0.11336 seconds
