Home » Eclipse Projects » JFace » TreeViewer with ILazyTreeContentProvider(updateElement() from ILazyTreeContentProvider gets called for expanded elements, although they are not visible)
| TreeViewer with ILazyTreeContentProvider [message #1689738] |
Tue, 24 March 2015 04:07  |
Hello!
I'm developing an eclipse plugin with a view and I'm facing two problems.
The View uses an TreeViewer and TreeViewerColumns, each column has it's own LabelProvider.
Here's an example of the structure of the TreeViewer.
root
Leaf
Leaf
Root
Leaf
Leaf
Leaf
Leaf
Root
My first problem:
I'm using a thread to call viewer.refresh() periodically. To prevent the viewer from updating every element I'm using ILazyTreeContentProvider. This works great if the root nodes are NOT expanded. But if the root nodes are expanded, the content provider updates the root nodes (not the leafs), although they are not visible.
Example:
Root not visible, update, ERROR
Leaf not visible, no update, correct
Root not visible, no update, correct
Root visible, update, correct
Leaf visible, update, correct
I don't know what I'm implementing wrong. I have enabled hash lookup for the TreeViewer (viewer.setUseHashlookup(true) ) and ensured that it's called before viewer.setInput().
My second problem:
The user can edit the treeviewer columns (I'm using CheckboxCellEditor and TextCellEditor). I would like to call viewer.refresh() every second. If the user wants to edit he or she has to type in the value within a second, otherwise the selection vanishes, because of the update. I tried to check if the user edits at the moment with viewer.IsCellEditorActive() and this works, but if I don't call TreeViewer.replace or TreeViewer.setChildCount -> the whole row vanishes. I don't know how to implement this correctly. I'm able to stop updating generally while the user is editing, but I would like to prevent an update only for the edited node.
I hope I didn't miss that a similar question has already been asked and that I'm in the correct forum. Any help would be much appreciated. Many thanks in advance.
Explanation of source code:
The View displays a TreeRegisterGroup, a TreeRegisterGroup contains TreeRegisters (root nodes) and TreeRegister contain TreeFields (leafs). Every object is a TreeElement, but TreeRegisterGroup and TreeRegister are also TreeParents (can have child TreeElements) - Composite pattern.
class ViewContentProvider implements ILazyTreeContentProvider {
public void inputChanged(Viewer viewer, Object OldInput, Object NewInput) {
mRegisterGroupToDisplay = (TreeRegisterGroup) NewInput;
public void updateChildCount(Object element, int currentChildCount) {
int NewChildCount = 0;
if (element instanceof TreeParent) {
NewChildCount = ((TreeParent) element).GetChildrenCount();
viewer.setChildCount(element, NewChildCount);
public void updateElement(Object parent, int index) {
TreeElement[] Children = null;
TreeElement ChildAtIndex = null;
int ChildCount = 0;
if (parent instanceof TreeParent) {
Children = ((TreeParent) parent).GetChildren2();
} else if (parent instanceof TreeElement) {
viewer.setHasChildren(parent, false);
viewer.setChildCount(parent, 0);
if (Children != null) {
ChildCount = Children.length;
if (ChildCount > index) {
ChildAtIndex = Children[index];
viewer.replace(parent, index, ChildAtIndex);
// get childcount of child (not of parent!!!)
if (ChildAtIndex instanceof TreeParent) {
ChildCount = ((TreeParent) ChildAtIndex)
viewer.setChildCount(ChildAtIndex, ChildCount);
} else {
viewer.setChildCount(ChildAtIndex, 0);
public Object getParent(Object child) {
if (child instanceof TreeElement) {
return ((TreeElement) child).GetParent();
return mRegisterGroupToDisplay;
| Re: TreeViewer with ILazyTreeContentProvider [message #1764161 is a reply to message #1689738] |
Fri, 26 May 2017 02:29  |
I am facing the same issue as whenever I do expandToLevel it calls updateElement method and it starts from root till leaf node even if they are not visible.
I have implemented ILazyTreeContentProvider for my treeViewer and given SWT.Virtual style with setHashLookup set as true.
Also sometimes I get widget disposed exception and while debugging I found out that internally there is one customElement hashmap which contains disposed treeitem. How should I resolve this ?
Please let me know if you have found any solution for this.
Thanks in advance.
Current Time: Wed Oct 29 02:39:07 EDT 2025
Powered by FUDForum. Page generated in 1.46248 seconds
