Home » Modeling » TMF (Xtext) » resolution of uriFragment '|0' failed.
resolution of uriFragment '|0' failed. [message #1764137] Thu, 25 May 2017 14:56 Go to next message
I have this grammar
grammar org.xtext.example.mydsl3.FSM with org.eclipse.xtext.common.Terminals
generate fSM "http://www.xtext.org/example/mydsl3/FSM"
Model:
	types+=EnumerationType*
	fsm+=FSM*
FSM:
	'FSM'
		'type' type=[EnumerationType|QualifiedID]
		ownedState+=State*
State:
	'State'
		('literal' literal=[EnumerationLiteral|QualifiedID])
		('transitions' '(' (outgoingTransition+=Transition)* ')')?
Transition returns Transition:
		'to' target=[State|QualifiedID]
EnumerationType:
	'EnumerationType'
	name=ID
	'literals'
		  literals+=EnumerationLiteral ( "," literals+=EnumerationLiteral)*
EnumerationLiteral:
	name=ID
QualifiedID : (ID | QUALIFIED_ID ) ;
terminal QUALIFIED_ID :
  '^'?('a'..'z'|'A'..'Z'|'_')('a'..'z'|'A'..'Z'|'_'|'0'..'9')*  '.' ('a'..'z'|'A'..'Z'|'_')('a'..'z'|'A'..'Z'|'_'|'0'..'9')* ( '.' ('a'..'z'|'A'..'Z'|'_')('a'..'z'|'A'..'Z'|'_'|'0'..'9')* )*;
It allows to create model like this one
EnumerationType enum1 literals ( literal1 , literal2 )
FSM {
	type enum1
	State
			literal enum1.literal1
			transitions ( to  enum1.literal2 )
	State
		{ literal enum1.literal2
			transitions ( to enum1.literal1 )
At this stage, I have errors on transitions (Couldn't resolve reference to State 'enum1.literal2'.) because scope management are not completed.
I add the required scope management as shown in the following
class FSMScopeProvider extends AbstractFSMScopeProvider {
	override getScope(EObject object, EReference ref) {
		if (object instanceof Transition) {
			scope_Transition_target(object as Transition, ref)
	def scope_Transition_target(Transition transition, EReference reference) {
		var ArrayList<IEObjectDescription> res = new ArrayList<IEObjectDescription>
		var State s = transition.eContainer as State
		var FSM fsm = s.eContainer as FSM
		for (state : fsm.ownedState) {
			res.add(
				EObjectDescription.create(
					QualifiedName.create((state.literal.eContainer as EnumerationType).name, state.literal.name),
					state.literal))
			// println("res " + res)
			return new SimpleScope(IScope.NULLSCOPE, res)
However, when I edit my model an error wizard appears
index.php/fa/29453/0/
and additional errors appear in the console as shown in below.
Any suggestion?
If there are any who may be interested to reproduce,
the source code is available here https://github.com/fzalila/xtextfsm/tree/master/org.xtext.example.mydsl3
and an example project is available here https://github.com/fzalila/xtextfsm/tree/master/fsm-example
best regards
327718 [Worker-13] ERROR org.eclipse.xtext.linking.lazy.LazyLinkingResource  - resolution of uriFragment '|0' failed.
	at org.eclipse.xtext.linking.impl.DefaultLinkingService.getLinkedObjects(DefaultLinkingService.java:122)
	at org.eclipse.xtext.linking.lazy.LazyLinkingResource.getEObject(LazyLinkingResource.java:247)
	at org.eclipse.xtext.linking.lazy.LazyLinkingResource.getEObject(LazyLinkingResource.java:222)
	at org.eclipse.xtext.linking.lazy.LazyLinkingResource.doResolveLazyCrossReference(LazyLinkingResource.java:189)
	at org.eclipse.xtext.linking.lazy.LazyLinkingResource.resolveLazyCrossReference(LazyLinkingResource.java:148)
	at org.eclipse.xtext.linking.lazy.LazyLinkingResource.resolveLazyCrossReferences(LazyLinkingResource.java:134)
	at org.eclipse.xtext.EcoreUtil2.resolveLazyCrossReferences(EcoreUtil2.java:498)
	at org.eclipse.xtext.ui.editor.reconciler.XtextDocumentReconcileStrategy.postParse(XtextDocumentReconcileStrategy.java:175)
	at org.eclipse.xtext.ui.editor.reconciler.XtextDocumentReconcileStrategy.doReconcile(XtextDocumentReconcileStrategy.java:153)
	at org.eclipse.xtext.ui.editor.reconciler.XtextDocumentReconcileStrategy.reconcile(XtextDocumentReconcileStrategy.java:67)
	at org.eclipse.xtext.ui.editor.reconciler.XtextReconciler.doRun(XtextReconciler.java:449)
	at org.eclipse.xtext.ui.editor.reconciler.XtextReconciler.access$3(XtextReconciler.java:429)
	at org.eclipse.xtext.ui.editor.reconciler.XtextReconciler$1.process(XtextReconciler.java:363)
	at org.eclipse.xtext.ui.editor.reconciler.XtextReconciler$1.process(XtextReconciler.java:1)
	at org.eclipse.xtext.util.concurrent.IUnitOfWork$Void.exec(IUnitOfWork.java:37)
	at org.eclipse.xtext.resource.OutdatedStateManager.exec(OutdatedStateManager.java:91)
	at org.eclipse.xtext.ui.editor.model.XtextDocument$XtextDocumentLocker.modify(XtextDocument.java:428)
	at org.eclipse.xtext.ui.editor.model.XtextDocument.internalModify(XtextDocument.java:162)
	at org.eclipse.xtext.ui.editor.reconciler.XtextReconciler.run(XtextReconciler.java:360)
!ENTRY org.apache.log4j 4 0 2017-05-25 20:31:07.553
!MESSAGE org.eclipse.xtext.linking.lazy.LazyLinkingResource  - resolution of uriFragment '|0' failed.
!STACK 0
327719 [Worker-13] ERROR org.eclipse.xtext.ui.editor.reconciler.XtextDocumentReconcileStrategy  - Error post-processing resource with content:
EnumerationType tt literals ( aa , bb )
FSM {
	type tt
	State
			literal tt.aa
			transitions ( to tt.bb )
	State
		{ literal tt.bb
			transitions ( to tt.aa )
org.eclipse.emf.common.util.WrappedException: java.lang.NullPointerException
	at org.eclipse.xtext.linking.lazy.LazyLinkingResource.getEObject(LazyLinkingResource.java:230)
	... 17 more
!MESSAGE org.eclipse.xtext.ui.editor.reconciler.XtextDocumentReconcileStrategy  - Error post-processing resource with content:
FSM {
	type tt
	State
			literal tt.aa
	State
		{ literal tt.bb
!STACK 0
	... 17 more
327723 [Worker-13] ERROR org.eclipse.xtext.linking.lazy.LazyLinkingResource  - resolution of uriFragment '|0' failed.
	at org.eclipse.xtext.validation.ResourceValidatorImpl.resolveProxies(ResourceValidatorImpl.java:161)
	at org.eclipse.xtext.validation.ResourceValidatorImpl.validate(ResourceValidatorImpl.java:74)
	at org.eclipse.xtext.ui.editor.validation.ValidationJob$1.exec(ValidationJob.java:91)
	at org.eclipse.xtext.ui.editor.validation.ValidationJob$1.exec(ValidationJob.java:1)
	at org.eclipse.xtext.util.concurrent.CancelableUnitOfWork.exec(CancelableUnitOfWork.java:26)
	at org.eclipse.xtext.ui.editor.model.XtextDocument$XtextDocumentLocker.internalReadOnly(XtextDocument.java:520)
	at org.eclipse.xtext.ui.editor.model.XtextDocument$XtextDocumentLocker.readOnly(XtextDocument.java:492)
	at org.eclipse.xtext.ui.editor.model.XtextDocument.readOnly(XtextDocument.java:133)
	at org.eclipse.xtext.ui.editor.validation.ValidationJob.createIssues(ValidationJob.java:86)
	at org.eclipse.xtext.ui.editor.validation.ValidationJob.run(ValidationJob.java:67)
!ENTRY org.apache.log4j 4 0 2017-05-25 20:31:07.557
!STACK 0
327724 [Worker-13] ERROR org.eclipse.xtext.ui.editor.validation.ValidationJob  - Error running validator
	... 16 more
!ENTRY org.apache.log4j 4 0 2017-05-25 20:31:07.558
!MESSAGE org.eclipse.xtext.ui.editor.validation.ValidationJob  - Error running validator
!STACK 0
	... 16 more
328374 [Worker-13] ERROR org.eclipse.xtext.linking.lazy.LazyLinkingResource  - resolution of uriFragment '|0' failed.
	at org.eclipse.xtext.builder.clustering.ClusteringBuilderState.doUpdate(ClusteringBuilderState.java:230)
	at org.eclipse.xtext.builder.builderState.AbstractBuilderState.update(AbstractBuilderState.java:116)
	at org.eclipse.xtext.builder.impl.XtextBuilder.doBuild(XtextBuilder.java:287)
	at org.eclipse.xtext.builder.impl.XtextBuilder.incrementalBuild(XtextBuilder.java:267)
	at org.eclipse.xtext.builder.impl.XtextBuilder.build(XtextBuilder.java:161)
	at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:735)
	at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:206)
	at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:246)
	at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:301)
	at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:304)
	at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:360)
	at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:383)
	at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:144)
	at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:235)
!ENTRY org.apache.log4j 4 0 2017-05-25 20:31:08.208
!STACK 0
328374 [Worker-13] ERROR org.eclipse.xtext.builder.clustering.ClusteringBuilderState  - Error loading resource from: platform:/resource/test/My.fsm
	... 21 more
!ENTRY org.apache.log4j 4 0 2017-05-25 20:31:08.209
!MESSAGE org.eclipse.xtext.builder.clustering.ClusteringBuilderState  - Error loading resource from: platform:/resource/test/My.fsm
!STACK 0
	... 21 more
328376 [Worker-13] ERROR org.eclipse.xtext.builder.clustering.CopiedResourceDescription  - java.lang.IllegalStateException: getReferenceDescriptions platform:/resource/test/My.fsm
	at org.eclipse.xtext.builder.clustering.CopiedResourceDescription.getReferenceDescriptions(CopiedResourceDescription.java:84)
	at org.eclipse.xtext.builder.builderState.BuilderStateUtil.copyReferenceDescriptions(BuilderStateUtil.java:59)
	at org.eclipse.xtext.builder.builderState.BuilderStateUtil.create(BuilderStateUtil.java:34)
	at org.eclipse.xtext.builder.clustering.ClusteringBuilderState.doUpdate(ClusteringBuilderState.java:267)
!ENTRY org.apache.log4j 4 0 2017-05-25 20:31:08.210
!MESSAGE org.eclipse.xtext.builder.clustering.CopiedResourceDescription  - java.lang.IllegalStateException: getReferenceDescriptions platform:/resource/test/My.fsm
!STACK 0
328377 [Worker-13] ERROR org.eclipse.xtext.builder.clustering.CopiedResourceDescription  - java.lang.IllegalStateException: getImportedNames platform:/resource/test/My.fsm
	at org.eclipse.xtext.builder.clustering.CopiedResourceDescription.getImportedNames(CopiedResourceDescription.java:75)
	at org.eclipse.xtext.builder.builderState.BuilderStateUtil.copyImportedNames(BuilderStateUtil.java:40)
	at org.eclipse.xtext.builder.builderState.BuilderStateUtil.create(BuilderStateUtil.java:35)
!ENTRY org.apache.log4j 4 0 2017-05-25 20:31:08.211
!MESSAGE org.eclipse.xtext.builder.clustering.CopiedResourceDescription  - java.lang.IllegalStateException: getImportedNames platform:/resource/test/My.fsm
!STACK 0
328380 [Worker-13] ERROR org.eclipse.xtext.linking.lazy.LazyLinkingResource  - resolution of uriFragment '|0' failed.
	at org.eclipse.xtext.ui.validation.DefaultResourceUIValidatorExtension.addMarkers(DefaultResourceUIValidatorExtension.java:60)
	at org.eclipse.xtext.ui.validation.DefaultResourceUIValidatorExtension.updateValidationMarkers(DefaultResourceUIValidatorExtension.java:46)
	at org.eclipse.xtext.builder.builderState.MarkerUpdaterImpl.processDelta(MarkerUpdaterImpl.java:93)
	at org.eclipse.xtext.builder.builderState.MarkerUpdaterImpl.updateMarkers(MarkerUpdaterImpl.java:63)
	at org.eclipse.xtext.builder.builderState.AbstractBuilderState.updateMarkers(AbstractBuilderState.java:82)
	at org.eclipse.xtext.builder.clustering.ClusteringBuilderState.doUpdate(ClusteringBuilderState.java:283)
!ENTRY org.apache.log4j 4 0 2017-05-25 20:31:08.214
!STACK 0
328380 [Worker-13] ERROR org.eclipse.xtext.builder.clustering.ClusteringBuilderState  - Error validating platform:/resource/test/My.fsm
	... 28 more
!ENTRY org.apache.log4j 4 0 2017-05-25 20:31:08.215
!MESSAGE org.eclipse.xtext.builder.clustering.ClusteringBuilderState  - Error validating platform:/resource/test/My.fsm
!STACK 0
	... 28 more
328882 [Worker-13] ERROR org.eclipse.xtext.linking.lazy.LazyLinkingResource  - resolution of uriFragment '|0' failed.
	at org.eclipse.xtext.resource.impl.DefaultResourceDescription.computeReferenceDescriptions(DefaultResourceDescription.java:135)
	at org.eclipse.xtext.resource.impl.DefaultResourceDescription$2.get(DefaultResourceDescription.java:123)
	at org.eclipse.xtext.resource.impl.DefaultResourceDescription$2.get(DefaultResourceDescription.java:120)
	at org.eclipse.xtext.util.OnChangeEvictingCache.get(OnChangeEvictingCache.java:77)
	at org.eclipse.xtext.resource.impl.DefaultResourceDescription.getReferenceDescriptions(DefaultResourceDescription.java:120)
	at org.eclipse.xtext.resource.DescriptionUtils.collectOutgoingReferences(DescriptionUtils.java:29)
	at org.eclipse.xtext.resource.impl.DefaultResourceDescriptionManager.isAffected(DefaultResourceDescriptionManager.java:117)
	at org.eclipse.xtext.ui.editor.DirtyStateEditorSupport.isReparseRequired(DirtyStateEditorSupport.java:649)
	at org.eclipse.xtext.ui.editor.DirtyStateEditorSupport$UpdateEditorStateJob$1.exec(DirtyStateEditorSupport.java:161)
	at org.eclipse.xtext.ui.editor.DirtyStateEditorSupport$UpdateEditorStateJob$1.exec(DirtyStateEditorSupport.java:1)
	at org.eclipse.xtext.ui.editor.DirtyStateEditorSupport$UpdateEditorStateJob.run(DirtyStateEditorSupport.java:146)
!ENTRY org.apache.log4j 4 0 2017-05-25 20:31:08.716
!STACK 0
!ENTRY org.eclipse.xtext.ui 4 0 2017-05-25 20:31:08.717
!MESSAGE Error updating dirty state editor
!STACK 0
	... 20 more
  • Attachment: xtextfsm.png
    (Size: 157.93KB, Downloaded 1709 times)
Re: resolution of uriFragment '|0' failed. [message #1764139 is a reply to message #1764137] Thu, 25 May 2017 15:11 Go to previous messageGo to next message
You don't call super in your scope provider
Thus you implicitly return null
That's bad
Call super.getScope(ctx, ref) or return IScope.NULLSCOPE
Re: resolution of uriFragment '|0' failed. [message #1764140 is a reply to message #1764139] Thu, 25 May 2017 15:23 Go to previous messageGo to next message
Thanks Christian
I update my scope class
 * generated by Xtext 2.11.0
package org.xtext.example.mydsl3.scoping
import org.eclipse.emf.ecore.EObject
import org.eclipse.emf.ecore.EReference
import org.xtext.example.mydsl3.fSM.Transition
import java.util.ArrayList
import org.eclipse.xtext.resource.IEObjectDescription
import org.xtext.example.mydsl3.fSM.State
import org.xtext.example.mydsl3.fSM.FSM
import org.eclipse.xtext.resource.EObjectDescription
import org.eclipse.xtext.naming.QualifiedName
import org.xtext.example.mydsl3.fSM.EnumerationType
import org.eclipse.xtext.scoping.impl.SimpleScope
import org.eclipse.xtext.scoping.IScope
 * This class contains custom scoping description.
 * See https://www.eclipse.org/Xtext/documentation/303_runtime_concepts.html#scoping
 * on how and when to use it.
		else{
			super.getScope(object, ref)
			res.add(
					state.literal))
However errors on transitions (Couldn't resolve reference to State 'enum1.literal2'.) reappear as shown in the image
index.php/fa/29454/0/
the strange thing is that the editor proposes 2 quick fixes.
It couldn't resolve reference to State 'enum1.literal1' on the hand, and proposes quick fixes containing one of provided element ('enum1.literal1') on the other hand.
Is it normal?
  • Attachment: xtextfsm2.png
    (Size: 524.61KB, Downloaded 1959 times)
[Updated on: Thu, 25 May 2017 15:33] by Moderator
Re: resolution of uriFragment '|0' failed. [message #1764142 is a reply to message #1764140] Thu, 25 May 2017 15:34 Go to previous messageGo to next message
Your states have no names do they?
You can reference only things with name
Either direct or with IQualifiedNameProvider
Or in the scope as you do
Please make sure you created the scope elements correct
Ok: QualifiedName.create("a","b")
Bad: QualifiedName.create("a.b")
Re: resolution of uriFragment '|0' failed. [message #1764143 is a reply to message #1764142] Thu, 25 May 2017 15:40 Go to previous messageGo to next message
Ps debugging defaultlinkingservice getLinkedObjects should help to analyze
Re: resolution of uriFragment '|0' failed. [message #1764145 is a reply to message #1764142] Thu, 25 May 2017 16:02 Go to previous messageGo to next message
Christian Dietrich wrote on Thu, 25 May 2017 21:34
My states don't have names but they are referred via the literal feature which have name.
I create qualified names as you recommend it QualifiedName.create("a","b")
QualifiedName.create(   (state.literal.eContainer as EnumerationType).name    ,     state.literal.name),               state.literal))
Christian Dietrich wrote on Thu, 25 May 2017 21:40
some additional explanation plz!
Re: resolution of uriFragment '|0' failed. [message #1764147 is a reply to message #1764145] Thu, 25 May 2017 16:05 Go to previous messageGo to next message
Simply set a breakpoint in that method and Look what happens
Re: resolution of uriFragment '|0' failed. [message #1764200 is a reply to message #1764147] Fri, 26 May 2017 11:20 Go to previous messageGo to next message
Thank you Christian for the suggestion.
I understand how linking and scoping mechanisms work.
The second edition of Lorenzo Bettini book explains how both mechanisms interact.
I create a FSMLinkingService class and I override the getLinkedObjects method (as you suggest) as shown below
public class FSMLinkingService extends DefaultLinkingService {
	private static final Logger logger = Logger.getLogger(DefaultLinkingService.class);
	@Inject
	private IQualifiedNameConverter qualifiedNameConverter;
	public List<EObject> getLinkedObjects(EObject context, EReference ref, INode node) throws IllegalNodeException {
		final EClass requiredType = ref.getEReferenceType();
		if (requiredType == null) {
			return Collections.<EObject>emptyList();
		final String crossRefString = getCrossRefNodeAsString(node);
		if (crossRefString == null || crossRefString.equals("")) {
		if (logger.isDebugEnabled()) {
			logger.debug("before getLinkedObjects: node: '" + crossRefString + "'");
		final IScope scope = getScope(context, ref);
		final QualifiedName qualifiedLinkName = qualifiedNameConverter.toQualifiedName(crossRefString);
		final IEObjectDescription eObjectDescription = scope.getSingleElement(qualifiedLinkName);
			logger.debug("after getLinkedObjects: node: '" + crossRefString + "' result: " + eObjectDescription);
		if (eObjectDescription == null) {
			return Collections.emptyList();
		final EObject result;
		if (context instanceof Transition && ref.getName().equals("target")) {
			State state = getReferringState((EnumerationLiteral) eObjectDescription.getEObjectOrProxy());
			result = state;
		} else {
			result = eObjectDescription.getEObjectOrProxy();
		return Collections.singletonList(result);
	private State getReferringState(EnumerationLiteral literal) {
		EnumerationType type = (EnumerationType) literal.eContainer();
		Model model = (Model) type.eContainer();
		for (FSM fsm : model.getFsm()) {
			for (State state : fsm.getOwnedState()) {
				if (state.getLiteral() == literal)
					return state;
		return null;
And now, the errors resolved.
However the xmi output of the following parsingTest doesn't resolve references
	def void loadModel() {
		EPackage.Registry.INSTANCE.put(FSMPackage.eNS_URI, FSMPackage::eINSTANCE)
		val result = parseHelper.parse('''
			FSM {
				type enum1
				State
				State
		Assert.assertNotNull(result)
		Assert.assertTrue(result.eResource.errors.isEmpty)
                RS2 = new ResourceSetImpl
		val r2 = RS2.createResource(URI.createURI("dummy.xmi"))
		r2.contents.add(result)
		val baos = new ByteArrayOutputStream
		r2.save(baos, null)
		println(new String(baos.toByteArray, StandardCharsets.UTF_8))
It generates the following xmi that doesn't resolve the reference to states (target reference <target href="__synthetic0.fsm#|2"/> ) and literals (<literal href="__synthetic0.fsm#|1"/>)
How can resolve this please?
best regards,
<?xml version="1.0" encoding="ASCII"?>
<fSM:Model xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:fSM="http://www.xtext.org/example/mydsl3/FSM">
  <types name="enum1">
    <literals name="literal1"/>
    <literals name="literal2"/>
  </types>
  <fsm type="//@types.0">
    <ownedState>
      <outgoingTransition>
      </outgoingTransition>
    </ownedState>
    <ownedState>
      <literal href="__synthetic0.fsm#|3"/>
        <target href="__synthetic0.fsm#|4"/>
    </ownedState>
  </fsm>
</fSM:Model>
Re: resolution of uriFragment '|0' failed. [message #1764206 is a reply to message #1764200] Fri, 26 May 2017 12:19 Go to previous messageGo to next message
I did no imply to customize the linking
I just wanted you to debug what goes wrong ther
Make sure the links can be resolved
You can use ecoreUtil2.resolve all to actually trigger resolving the stuff
You can you ValidationTestHelper (or something like that) to make sure there are no errors
Re: resolution of uriFragment '|0' failed. [message #1764208 is a reply to message #1764206] Fri, 26 May 2017 12:28 Go to previous messageGo to next message
when I add ecoreUtil2.resolve all , the "resolution of uriFragment '|0' failed" error reappears
0    [main] ERROR xt.linking.lazy.LazyLinkingResource  - resolution of uriFragment '|0' failed.
java.lang.IndexOutOfBoundsException: Index: 0, Size: 0
	at java.util.ArrayList.rangeCheck(ArrayList.java:653)
	at java.util.ArrayList.get(ArrayList.java:429)
	at org.eclipse.xtext.linking.lazy.LazyLinkingResource.hasLazyProxyInformation(LazyLinkingResource.java:502)
	at org.eclipse.xtext.linking.lazy.LazyLinkingResource.getLazyProxyInformation(LazyLinkingResource.java:509)
	at org.eclipse.xtext.linking.lazy.LazyURIEncoder.getLazyProxyInformation(LazyURIEncoder.java:148)
	at org.eclipse.xtext.linking.lazy.LazyURIEncoder.decode(LazyURIEncoder.java:127)
	at org.eclipse.xtext.linking.lazy.LazyLinkingResource.getEObject(LazyLinkingResource.java:221)
	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getEObject(ResourceSetImpl.java:223)
	at org.eclipse.emf.ecore.util.EcoreUtil.resolve(EcoreUtil.java:203)
	at org.eclipse.emf.ecore.util.EcoreUtil.resolve(EcoreUtil.java:259)
	at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eResolveProxy(BasicEObjectImpl.java:1477)
	at org.xtext.example.mydsl3.fSM.impl.FSMImpl.getType(FSMImpl.java:94)
	at org.xtext.example.mydsl3.fSM.impl.FSMImpl.eGet(FSMImpl.java:168)
	at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjectImpl.java:1011)
	at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjectImpl.java:1003)
	at org.eclipse.emf.ecore.util.EContentsEList$FeatureIteratorImpl.hasNext(EContentsEList.java:439)
	at org.eclipse.emf.ecore.util.EcoreUtil.resolveCrossReferences(EcoreUtil.java:304)
	at org.eclipse.emf.ecore.util.EcoreUtil.resolveAll(EcoreUtil.java:298)
	at org.eclipse.emf.ecore.util.EcoreUtil.resolveAll(EcoreUtil.java:283)
	at org.xtext.example.mydsl3.tests.FSMParsingTest.loadModel(FSMParsingTest.java:82)
	at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:50)
	at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:12)
	at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:47)
	at org.junit.internal.runners.statements.InvokeMethod.evaluate(InvokeMethod.java:17)
	at org.eclipse.xtext.testing.XtextRunner$1.evaluate(XtextRunner.java:49)
	at org.junit.runners.ParentRunner.runLeaf(ParentRunner.java:325)
	at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:78)
	at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:57)
	at org.junit.runners.ParentRunner$3.run(ParentRunner.java:290)
	at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:71)
	at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:288)
	at org.junit.runners.ParentRunner.access$000(ParentRunner.java:58)
	at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:268)
	at org.junit.runners.ParentRunner.run(ParentRunner.java:363)
	at org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.run(JUnit4TestReference.java:86)
	at org.eclipse.jdt.internal.junit.runner.TestExecution.run(TestExecution.java:38)
	at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:459)
	at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:678)
	at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:382)
	at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main(RemoteTestRunner.java:192)
4    [main] ERROR xt.linking.lazy.LazyLinkingResource  - resolution of uriFragment '|1' failed.
java.lang.IndexOutOfBoundsException: Index: 1, Size: 0
	at org.eclipse.emf.ecore.util.EcoreUtil.resolve(EcoreUtil.java:199)
	at org.xtext.example.mydsl3.fSM.impl.StateImpl.getLiteral(StateImpl.java:94)
	at org.xtext.example.mydsl3.fSM.impl.StateImpl.eGet(StateImpl.java:168)
6    [main] ERROR xt.linking.lazy.LazyLinkingResource  - resolution of uriFragment '|1' failed.
8    [main] ERROR xt.linking.lazy.LazyLinkingResource  - resolution of uriFragment '|2' failed.
java.lang.IndexOutOfBoundsException: Index: 2, Size: 0
	at org.xtext.example.mydsl3.fSM.impl.TransitionImpl.getTarget(TransitionImpl.java:74)
	at org.xtext.example.mydsl3.fSM.impl.TransitionImpl.eGet(TransitionImpl.java:118)
9    [main] ERROR xt.linking.lazy.LazyLinkingResource  - resolution of uriFragment '|2' failed.
10   [main] ERROR xt.linking.lazy.LazyLinkingResource  - resolution of uriFragment '|3' failed.
java.lang.IndexOutOfBoundsException: Index: 3, Size: 0
11   [main] ERROR xt.linking.lazy.LazyLinkingResource  - resolution of uriFragment '|4' failed.
java.lang.IndexOutOfBoundsException: Index: 4, Size: 0
12   [main] ERROR xt.linking.lazy.LazyLinkingResource  - resolution of uriFragment '|4' failed.
Re: resolution of uriFragment '|0' failed. [message #1764209 is a reply to message #1764208] Fri, 26 May 2017 12:42 Go to previous messageGo to next message
I can have a look next week
As I said the linking should not need customization but you need to debug it to find out what caused yesterday's error
Re: resolution of uriFragment '|0' failed. [message #1764211 is a reply to message #1764209] Fri, 26 May 2017 12:54 Go to previous messageGo to next message
Ok Christian
If you want to reproduce, the whole code and example are available here https://github.com/fzalila/xtextfsm
When I debug the getLinkedObjects method, I observe that when the context is a Transition and the reference is target,
the result object is an EnumerationLiteral. However, the result object must a State and not an EnumerationLiteral.
So, I add a conditional statement to detect this case and the result value (in this case) becomes the state who refers to the concerned literal (and not the literal itself as returned by default).
Therefore, I add the getReferringState method that search the concerned state.
This customized behavior resolve the Couldn't resolve reference to State 'enum1.literal2'.
Actually, the problem is when I test the parser, the references are not resolved.
			result = state;
		} else {
					return state;
		return null;
Re: resolution of uriFragment '|0' failed. [message #1764220 is a reply to message #1764211] Fri, 26 May 2017 14:03 Go to previous messageGo to next message
well i had a look with my parents pc.
in your test you miss a
EcoreUtil.resolveAll(result.eResource.resourceSet)
besides this i dont get any errors in the editor nor in the test (using xtext 2.12)
if i revert the changes to linking service i get the error you describe
and the cause is clear
QualifiedName.create((state.literal.eContainer as EnumerationType).name, state.literal.name), state.literal))
you add literals to the scope. not states
you may want to do a
QualifiedName.create((state.literal.eContainer as EnumerationType).name, state.literal.name), state))
instead
Re: resolution of uriFragment '|0' failed. [message #1764221 is a reply to message #1764220] Fri, 26 May 2017 14:19 Go to previous messageGo to next message
Sorry Christian for this trivial error. Yes it must be state and not state.literal.
I add testCorrectParsing test (ValidationTestHelper).
class FSMParsingTest {
	@Inject extension ParseHelper<Model> parseHelper
	@Inject extension ValidationTestHelper
	@Test
	def void testCorrectParsing() {
						FSM {
							type enum1
							State
							State
		'''.parse.assertNoErrors
	@Test
			FSM {
				type enum1
				State
				State
		val RS2 = new ResourceSetImpl
               // added resolve
		r2.save(baos, null)
Both tests testCorrectParsing and loadmodel are correct.
However, despite the add of EcoreUtil.resolveAll(result.eResource.resourceSet) the generated xmi is always doesn't contain the resolved references
  </types>
  <fsm>
    <type href="__synthetic0.fsm#|0"/>
    <ownedState>
    </ownedState>
    <ownedState>
    </ownedState>
  </fsm>
</fSM:Model>
and this error is always here during loadModel test
1    [main] ERROR xt.linking.lazy.LazyLinkingResource  - resolution of uriFragment '|0' failed.
	at org.eclipse.emf.ecore.util.EcoreUtil.resolveAll(EcoreUtil.java:271)
	at org.xtext.example.mydsl3.tests.FSMParsingTest.loadModel(FSMParsingTest.java:134)
5    [main] ERROR xt.linking.lazy.LazyLinkingResource  - resolution of uriFragment '|1' failed.
7    [main] ERROR xt.linking.lazy.LazyLinkingResource  - resolution of uriFragment '|2' failed.
8    [main] ERROR xt.linking.lazy.LazyLinkingResource  - resolution of uriFragment '|3' failed.
9    [main] ERROR xt.linking.lazy.LazyLinkingResource  - resolution of uriFragment '|3' failed.
10   [main] ERROR xt.linking.lazy.LazyLinkingResource  - resolution of uriFragment '|4' failed.
Re: resolution of uriFragment '|0' failed. [message #1764222 is a reply to message #1764221] Fri, 26 May 2017 14:32 Go to previous messageGo to next message
Resolved!
EcoreUtil.resolveAll(result.eResource.resourceSet) must be before r2.contents.add(result)
It is logic.
references must be resolved before adding contents
Thanks christian
Re: resolution of uriFragment '|0' failed. [message #1764223 is a reply to message #1764222] Fri, 26 May 2017 14:33 Go to previous message
of course.
this resolved the references in the model this should be done before moving
Previous Topic:Making change to DotExpression example
Next Topic:Error When Serializing CrossReference
Current Time: Wed Sep 17 21:01:35 EDT 2025
Powered by FUDForum. Page generated in 0.24329 seconds
