Home » Newcomers » Newcomers » Neon Java IDE Visual Class - swing(In Neon no button to create)
Neon Java IDE Visual Class - swing [message #1763788] Fri, 19 May 2017 12:45 Go to next message
I can not see a way to create there is no button to do so - tried to customize prospectives
no DESIGNER ACTIONS check box under "Actions Set Availability" tab (there is no "Commands Groups Availability " as there is LUNA
"new visual class" option under "Tool Bar Visability" tab
Luna has this Neon does not
what do I do?
Re: Neon Java IDE Visual Class - swing [message #1763808 is a reply to message #1763788] Sat, 20 May 2017 02:21 Go to previous messageGo to next message
Are you sure you have the same set of plug-ins installed in both versions of Eclipse?
Re: Neon Java IDE Visual Class - swing [message #1764090 is a reply to message #1763808] Wed, 24 May 2017 12:25 Go to previous messageGo to next message
The swing designer was not there in neon
Re: Neon Java IDE Visual Class - swing [message #1764092 is a reply to message #1763808] Wed, 24 May 2017 12:25 Go to previous messageGo to next message
Re: Neon Java IDE Visual Class - swing [message #1764093 is a reply to message #1763808] Wed, 24 May 2017 12:26 Go to previous message
Previous Topic:How do I get rid of this error message?
Next Topic:installer not reading repository
Current Time: Sun Jul 20 20:39:34 EDT 2025
Powered by FUDForum. Page generated in 0.96158 seconds
