Home » Archived » Eclipse Process Manager (Stardust) » Using JNDI Session for Mail Application(But getting unexpected class with trailing numbers.)
Using JNDI Session for Mail Application [message #1759286] |
Sun, 09 April 2017 19:53  |
15:51:56 WARN [080-exec-9] AuditTrailLogger - Activity thread interrupted at 'Activity: Application Activity 1', reason: javax.mail.MessagingException: java:comp/env/mail/Session returned javax.mail.Session@1418a780 but class javax.mail.Session is expected! (User: motu (Realm: carnot) (Of the Universe, Master))
15:51:53 INFO [080-exec-1] FiFoJobManager - Enqueued job Job {runnable = ForkedActionRunner {action = org.eclipse.stardust.engine.core.runtime.internal.SynchUserSessionToDiskAction@39cdfce0}, done = false, error = null}. Scheduled queue length is now 1
15:51:53 INFO [Thread1 ] FiFoJobManager - Adding job Job {runnable = ForkedActionRunner {action = org.eclipse.stardust.engine.core.runtime.internal.SynchUserSessionToDiskAction@39cdfce0}, done = false, error = null}. Active jobs queue length is now 1
15:51:53 INFO [Thread4 ] Parameters - CARNOT version: 4.1.0.20161206-2011
15:51:53 INFO [Thread4 ] ForkingDebugInterceptor - --> forked: org.eclipse.stardust.engine.core.runtime.internal.SynchUserSessionToDiskAction@39cdfce0
15:51:53 INFO [080-exec-1] ProcessInstanceBean - Setting starting user to '1' for process instance 304.
15:51:53 INFO [080-exec-1] ProcessInstanceBean - State change for Process instance = 304 (Process Definition: Process Definition 1) (model oid = 119, version = 1, revision = 2): Created-->Active.
15:51:53 INFO [080-exec-1] WorkflowServiceImpl - Starting process 'ProcessDefinition1', oid = 304, synchronous = true
15:51:53 INFO [Thread4 ] ForkingDebugInterceptor - <-- forked.
15:51:53 INFO [080-exec-1] ActivityInstanceBean - State change for Activity instance 'ManualActivity1', oid: 788 (process instance = 304) (model oid = 119, version = 1, revision = 2): Created-->Created.
15:51:53 INFO [080-exec-1] ActivityInstanceBean - Performer of Activity instance 'ManualActivity1', oid: 788 (process instance = 304) (model oid = 119, version = 1, revision = 2) set to Role: Administrator.
15:51:53 INFO [080-exec-1] ActivityInstanceBean - State change for Activity instance 'ManualActivity1', oid: 788 (process instance = 304) (model oid = 119, version = 1, revision = 2): Created-->Suspended.
15:51:53 INFO [080-exec-1] ActivityInstanceBean - Performer of Activity instance 'ManualActivity1', oid: 788 (process instance = 304) (model oid = 119, version = 1, revision = 2) set to User: motu (Realm: carnot) (Of the Universe, Master).
15:51:53 INFO [080-exec-1] ActivityInstanceBean - State change for Activity instance 'ManualActivity1', oid: 788 (process instance = 304) (model oid = 119, version = 1, revision = 2): Suspended-->Application.
15:51:53 ERROR [080-exec-1] ManagedBeanUtils - Failed to retrieve or initialize spring based bean....infinityRequestScopedCustomBpmEventsControllerERROR: No bean named 'infinityRequestScopedCustomBpmEventsController' is defined
15:51:53 INFO [080-exec-1] Interaction - Resolved interaction ID for Process Definition 1: Manual Activity 1 (17/04/10 15:51:53) to Nzg4fDE0OTE4MTA3MTM1NTY=
15:51:53 INFO [080-exec-5] Parameters - CARNOT version: 4.1.0.20161206-2011
Apr 10, 2017 3:51:53 PM org.apache.catalina.core.ApplicationContext log
INFO: WARNING: Component _id690 just got an automatic id, because there was no id assigned yet. If this component was created dynamically (i.e. not by a JSP tag) you should assign it an explicit static id or assign it the id you get from the createUniqueId from the current UIViewRoot component right after creation!
15:51:56 INFO [080-exec-9] Interaction - Resolved interaction ID for Process Definition 1: Manual Activity 1 (17/04/10 15:51:53) to Nzg4fDE0OTE4MTA3MTM1NTY=
15:51:56 INFO [080-exec-9] rameInteractionController - Triggering asynchronous close of activity panel ...
15:51:56 INFO [080-exec-9] ActivityPanelController - Handling externally triggered close of activity panel: complete
15:51:56 INFO [080-exec-9] ActivityInstanceBean - State change for Activity instance 'ManualActivity1', oid: 788 (process instance = 304) (model oid = 119, version = 1, revision = 2): Application-->Completed.
15:51:56 INFO [080-exec-9] ActivityInstanceBean - Remove from worklists: Activity instance 'ManualActivity1', oid: 788 (process instance = 304) (model oid = 119, version = 1, revision = 2)
15:51:56 INFO [080-exec-9] ActivityInstanceBean - State change for Activity instance 'ApplicationActivity1', oid: 789 (process instance = 304) (model oid = 119, version = 1, revision = 2): Created-->Created.
15:51:56 INFO [080-exec-9] ActivityInstanceBean - State change for Activity instance 'ApplicationActivity1', oid: 789 (process instance = 304) (model oid = 119, version = 1, revision = 2): Created-->Application.
15:51:56 WARN [080-exec-9] LogUtils -
javax.mail.MessagingException: java:comp/env/mail/Session returned javax.mail.Session@1418a780 but class javax.mail.Session is expected!;
nested exception is:
javax.naming.NamingException: java:comp/env/mail/Session returned javax.mail.Session@1418a780 but class javax.mail.Session is expected!
at org.eclipse.stardust.engine.extensions.mail.app.MailAssembler.prepareMsg(MailAssembler.java:180)
at org.eclipse.stardust.engine.extensions.mail.app.MailAssembler.sendMail(MailAssembler.java:113)
at org.eclipse.stardust.engine.extensions.mail.app.MailApplicationInstance.send(MailApplicationInstance.java:338)
at org.eclipse.stardust.engine.core.runtime.beans.ActivityInstanceBean.invokeAsynchronously(ActivityInstanceBean.java:1862)
at org.eclipse.stardust.engine.core.runtime.beans.ActivityInstanceBean.invokeApplication(ActivityInstanceBean.java:1587)
at org.eclipse.stardust.engine.core.runtime.beans.ActivityInstanceBean.invoke(ActivityInstanceBean.java:1289)
at org.eclipse.stardust.engine.core.runtime.beans.ActivityInstanceBean.doStartActivity(ActivityInstanceBean.java:1279)
at org.eclipse.stardust.engine.core.runtime.beans.ActivityInstanceBean.start(ActivityInstanceBean.java:1240)
at org.eclipse.stardust.engine.core.runtime.beans.ActivityThread.runCurrentActivity(ActivityThread.java:1229)
at org.eclipse.stardust.engine.core.runtime.beans.ActivityThread.runInternal(ActivityThread.java:419)
at org.eclipse.stardust.engine.core.runtime.beans.ActivityThread.run(ActivityThread.java:242)
at org.eclipse.stardust.engine.core.runtime.beans.ActivityThread.schedule(ActivityThread.java:127)
at org.eclipse.stardust.engine.core.runtime.audittrail.management.ActivityInstanceUtils.complete(ActivityInstanceUtils.java:409)
at org.eclipse.stardust.engine.core.runtime.beans.WorkflowServiceImpl.complete(WorkflowServiceImpl.java:1109)
at org.eclipse.stardust.engine.core.runtime.beans.WorkflowServiceImpl.complete(WorkflowServiceImpl.java:992)
at org.eclipse.stardust.engine.core.runtime.beans.interceptors.CallingInterceptor.invoke(CallingInterceptor.java:29)
at org.eclipse.stardust.engine.core.runtime.interceptor.MethodInvocationImpl.proceed(MethodInvocationImpl.java:130)
at org.eclipse.stardust.engine.core.runtime.beans.interceptors.POJOExceptionHandler.invoke(POJOExceptionHandler.java:30)
at org.eclipse.stardust.engine.core.runtime.beans.interceptors.RuntimeExtensionsInterceptor.invoke(RuntimeExtensionsInterceptor.java:34)
at org.eclipse.stardust.engine.core.runtime.beans.interceptors.GuardingInterceptor.invoke(GuardingInterceptor.java:78)
at org.eclipse.stardust.engine.core.runtime.beans.interceptors.AbstractLoginInterceptor.performCall(AbstractLoginInterceptor.java:201)
at org.eclipse.stardust.engine.core.runtime.beans.interceptors.AbstractLoginInterceptor.invoke(AbstractLoginInterceptor.java:121)
at org.eclipse.stardust.engine.api.spring.SpringBeanLoginInterceptor.invoke(SpringBeanLoginInterceptor.java:79)
at org.eclipse.stardust.engine.api.spring.SpringSessionInterceptor.doWithDataSource(SpringSessionInterceptor.java:143)
at org.eclipse.stardust.engine.api.spring.SpringSessionInterceptor.access$000(SpringSessionInterceptor.java:49)
at org.eclipse.stardust.engine.api.spring.SpringSessionInterceptor$1.doInConnection(SpringSessionInterceptor.java:88)
at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:342)
at org.eclipse.stardust.engine.api.spring.SpringSessionInterceptor.invoke(SpringSessionInterceptor.java:82)
at org.eclipse.stardust.engine.api.spring.SpringConfigurationInterceptor.invoke(SpringConfigurationInterceptor.java:101)
at org.eclipse.stardust.engine.core.runtime.beans.interceptors.PropertyLayerProviderInterceptor.invoke(PropertyLayerProviderInterceptor.java:129)
at org.eclipse.stardust.engine.core.runtime.beans.interceptors.DebugInterceptor.invoke(DebugInterceptor.java:56)
at org.eclipse.stardust.engine.api.spring.SpringTxInterceptor$1.doInTransaction(SpringTxInterceptor.java:93)
at org.springframework.transaction.support.TransactionTemplate.execute(TransactionTemplate.java:131)
at org.eclipse.stardust.engine.api.spring.SpringTxInterceptor.invoke(SpringTxInterceptor.java:71)
at org.eclipse.stardust.engine.core.runtime.interceptor.MethodInvocationImpl.execute(MethodInvocationImpl.java:68)
at org.eclipse.stardust.engine.core.runtime.beans.InvocationManager.invoke(InvocationManager.java:53)
at com.sun.proxy.$Proxy51.complete(Unknown Source)
at org.eclipse.stardust.engine.api.spring.WorkflowServiceBean.complete(WorkflowServiceBean.java:68)
at org.eclipse.stardust.engine.api.spring.SpringServiceFactory$SpringServiceInvocationHandler.invoke(SpringServiceFactory.java:201)
at org.eclipse.stardust.ui.web.processportal.common.PPUtils.complete(PPUtils.java:472)
at org.eclipse.stardust.ui.web.processportal.view.ActivityDetailsBean.completeCurrentActivityContinue(ActivityDetailsBean.java:1963)
at org.eclipse.stardust.ui.web.processportal.view.ActivityDetailsBean.access$900(ActivityDetailsBean.java:155)
at org.eclipse.stardust.ui.web.processportal.view.ActivityDetailsBean$7.handleEvent(ActivityDetailsBean.java:1941)
at org.eclipse.stardust.ui.web.processportal.view.ActivityDetailsBean.retrieveOutDataMappingContinue(ActivityDetailsBean.java:2388)
at org.eclipse.stardust.ui.web.processportal.view.ActivityDetailsBean.retrieveOutDataMapping(ActivityDetailsBean.java:2369)
at org.eclipse.stardust.ui.web.processportal.view.ActivityDetailsBean.completeCurrentActivity(ActivityDetailsBean.java:1934)
at org.eclipse.stardust.ui.web.processportal.view.ActivityDetailsBean.completeCurrentActivity(ActivityDetailsBean.java:1918)
at org.eclipse.stardust.ui.web.processportal.view.ActivityDetailsBean.completeCurrentActivity(ActivityDetailsBean.java:1913)
at org.eclipse.stardust.ui.web.processportal.view.ActivityPanelController.setRemoteControlActivityStateChangeCommandId(ActivityPanelController.java:197)
at org.apache.myfaces.el.PropertyResolverImpl.setProperty(PropertyResolverImpl.java:409)
at org.apache.myfaces.el.PropertyResolverImpl.setValue(PropertyResolverImpl.java:176)
at com.sun.facelets.el.LegacyELContext$LegacyELResolver.setValue(LegacyELContext.java:201)
at com.sun.el.parser.AstValue.setValue(AstValue.java:113)
at com.sun.el.ValueExpressionImpl.setValue(ValueExpressionImpl.java:246)
at com.sun.facelets.el.TagValueExpression.setValue(TagValueExpression.java:93)
at com.sun.facelets.el.LegacyValueBinding.setValue(LegacyValueBinding.java:68)
at javax.faces.component.UIInput.updateModel(UIInput.java:270)
at javax.faces.component.UIInput.processUpdates(UIInput.java:207)
at javax.faces.component.UIComponentBase.processUpdates(UIComponentBase.java:648)
at org.eclipse.stardust.ui.web.common.app.tags.TabScopedComponent.processUpdates(TabScopedComponent.java:128)
at javax.faces.component.UIForm.processUpdates(UIForm.java:90)
at javax.faces.component.UIViewRoot.processUpdates(UIViewRoot.java:160)
at org.apache.myfaces.lifecycle.UpdateModelValuesExecutor.execute(UpdateModelValuesExecutor.java:33)
at org.apache.myfaces.lifecycle.LifecycleImpl.executePhase(LifecycleImpl.java:95)
at org.apache.myfaces.lifecycle.LifecycleImpl.execute(LifecycleImpl.java:70)
at com.icesoft.faces.webapp.http.core.JsfLifecycleExecutor.apply(JsfLifecycleExecutor.java:50)
at com.icesoft.faces.webapp.http.core.ReceiveSendUpdates.renderCycle(ReceiveSendUpdates.java:169)
at com.icesoft.faces.webapp.http.core.ReceiveSendUpdates.service(ReceiveSendUpdates.java:110)
at com.icesoft.faces.webapp.http.core.RequestVerifier.service(RequestVerifier.java:65)
at com.icesoft.faces.webapp.http.servlet.BasicAdaptingServlet.service(BasicAdaptingServlet.java:51)
at com.icesoft.faces.webapp.http.servlet.SessionVerifier.service(SessionVerifier.java:62)
at com.icesoft.faces.webapp.http.servlet.PathDispatcher.service(PathDispatcher.java:55)
at com.icesoft.faces.webapp.http.servlet.SessionDispatcher.service(SessionDispatcher.java:107)
at com.icesoft.faces.webapp.http.servlet.BlockExpiredSessionRequests.service(BlockExpiredSessionRequests.java:53)
at com.icesoft.faces.webapp.http.servlet.MainServlet.service(MainServlet.java:204)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:731)
at com.icesoft.faces.webapp.xmlhttp.BlockingServlet.service(BlockingServlet.java:71)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
at org.eclipse.stardust.ui.web.html5.EnhancedJarResourceFilter.doFilter(EnhancedJarResourceFilter.java:148)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:218)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:505)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:169)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:958)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:452)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1087)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:637)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:318)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
Caused by: javax.naming.NamingException: java:comp/env/mail/Session returned javax.mail.Session@1418a780 but class javax.mail.Session is expected!
at org.eclipse.stardust.engine.extensions.mail.app.MailAssembler.createSession(MailAssembler.java:160)
at org.eclipse.stardust.engine.extensions.mail.app.MailAssembler.prepareMsg(MailAssembler.java:178)
... 140 more
15:51:56 WARN [080-exec-9] AuditTrailLogger - javax.mail.MessagingException: java:comp/env/mail/Session returned javax.mail.Session@1418a780 but class javax.mail.Session is expected!;
javax.naming.NamingException: java:comp/env/mail/Session returned javax.mail.Session@1418a780 but class javax.mail.Session is expected! (User: motu (Realm: carnot) (Of the Universe, Master))
15:51:56 INFO [080-exec-9] ProcessInstanceBean - State change for Process instance = 304 (Process Definition: Process Definition 1) (model oid = 119, version = 1, revision = 2): Active-->Interrupted.
15:51:56 INFO [080-exec-9] AuditTrailLogger - Process instance interrupted. (User: motu (Realm: carnot) (Of the Universe, Master))
15:51:56 INFO [080-exec-9] ActivityInstanceBean - State change for Activity instance 'ApplicationActivity1', oid: 789 (process instance = 304) (model oid = 119, version = 1, revision = 2): Application-->Interrupted.
15:51:56 INFO [080-exec-9] FiFoJobManager - Enqueued job Job {runnable = ForkedActionRunner {action = Process interruption janitor, pi = 304}, done = false, error = null}. Scheduled queue length is now 1
15:51:56 INFO [Thread1 ] FiFoJobManager - Adding job Job {runnable = ForkedActionRunner {action = Process interruption janitor, pi = 304}, done = false, error = null}. Active jobs queue length is now 1
15:51:56 INFO [Thread5 ] Parameters - CARNOT version: 4.1.0.20161206-2011
15:51:56 INFO [Thread5 ] ForkingDebugInterceptor - --> forked: Process interruption janitor, pi = 304
15:51:56 INFO [Thread5 ] ForkingDebugInterceptor - <-- forked.
How to fix this one? I have followed everything from Help - Eclipse Platform for setting up JNDI Session.
Current Time: Mon Jul 21 12:27:47 EDT 2025
Powered by FUDForum. Page generated in 0.07336 seconds
