Home » Language IDEs » Java Development Tools (JDT) » Eclipse wrong formatting of Override non-Javadoc
Eclipse wrong formatting of Override non-Javadoc [message #1764020] Wed, 24 May 2017 02:40 Go to next message
Eclipse is messing up code with format
Take this piece of code: This is how eclipse would add the non-Javadoc with ALT+SHIFT+J
            /* (non-Javadoc)
             * @see javafx.util.StringConverter#fromString(java.lang.String)
            public Number fromString(String string) {
Try formatting this piece of code and it messes it up: CTRL+SHIFT+F
             * (non-Javadoc)
How can I avoid this? The problem is you get unnecessary whitepace that messes up git diff.
[Updated on: Wed, 24 May 2017 02:42] by Moderator
Re: Eclipse wrong formatting of Override non-Javadoc [message #1764026 is a reply to message #1764020] Wed, 24 May 2017 04:06 Go to previous messageGo to next message
You'd have to change Java Formatter preferences on the Comments tab; probably you don't want "Blank line before Javadoc tags" enabled.
Re: Eclipse wrong formatting of Override non-Javadoc [message #1764028 is a reply to message #1764026] Wed, 24 May 2017 04:21 Go to previous message
That did work, but I only want that behaviour on comments with non-Javadoc.
It wouldn't be so bad I at least I could ommit the whitespace on the empty comment lines. There is no option to ommit these whitespace.
[Updated on: Wed, 24 May 2017 04:33] by Moderator
Previous Topic:Transfering custom @Interfaces from super function to overriden function
Next Topic:LDAP server startup logs
Current Time: Mon Jul 21 00:23:47 EDT 2025
Powered by FUDForum. Page generated in 0.08309 seconds
