Home » Eclipse Projects » P2 » Wrong bundle loaded after update on macosx
Wrong bundle loaded after update on macosx [message #1763975] Tue, 23 May 2017 10:19 Go to next message
I have a problem with p2 updating on mac os x, i described it here for more context.
We use the standard UpdateService which is working correctly. The app loads new stuff from repository and put it in app/plugins directory, so we end up having in this directory both versions of each of our plugins (say versions 1 and 2).
On windows, when the app starts, it picks up the correct version of the plugins (version 2), but on mac, it keeps loading the wrong one (version 1). If i delete all v1 jars, it picks up the correct ones (v2 obviously) but if i then undelete them (so we now have back v1 and V2), it keeps taking v2.
I noticed a difference between windows and mac in the file configuration\org.eclipse.equinox.simpleconfigurator\bundles.info (which, correct me if i am wrong, seems to describe the jars to load)
On windows, when i do the update, this file contains only the new version of the jars, ex:
dp.fast.app,2.0.1,plugins/dp.fast.app_2.0.1.jar,4,false
dp.fast.app.update,2.0.1,plugins/dp.fast.app.update_2.0.1.jar,4,false
dp.fast.app.workbench,2.0.1,plugins/dp.fast.app.workbench_2.0.1.jar,4,false
dp.fast.connector,2.0.1,plugins/dp.fast.connector_2.0.1.jar,4,false
dp.fast.core,2.0.1,plugins/dp.fast.core_2.0.1.jar,4,false
dp.fast.core.fx,2.0.1,plugins/dp.fast.core.fx_2.0.1.jar,4,false
But on mac, it contains both the old and the new version:
dp.fast.app,2.0.0,plugins/dp.fast.app_2.0.0.jar,4,false
dp.fast.app.update,2.0.0,plugins/dp.fast.app.update_2.0.0.jar,4,false
dp.fast.app.workbench,2.0.0,plugins/dp.fast.app.workbench_2.0.0.jar,4,false
dp.fast.connector,2.0.0,plugins/dp.fast.connector_2.0.0.jar,4,false
dp.fast.core,2.0.0,plugins/dp.fast.core_2.0.0.jar,4,false
dp.fast.core.fx,2.0.0,plugins/dp.fast.core.fx_2.0.0.jar,4,false
I guess the problem lays here. If i remove the lines containing the old version, the app correctly loads the new bundle (obvioulsy).
So what can create these double lines ?
Re: Wrong bundle loaded after update on macosx [message #1763998 is a reply to message #1763975] Tue, 23 May 2017 14:29 Go to previous messageGo to next message
Are you running on MacOS 10.12 (Sierra)? Sierra introduced a new feature called Gatekeeper Path Randomization. See the following links for some details:
https://weblog.rogueamoeba.com/2016/06/29/sierra-and-gatekeeper-path-randomization/
https://bugs.eclipse.org/bugs/show_bug.cgi?id=507328
https://bugs.eclipse.org/bugs/show_bug.cgi?id=461670
Re: Wrong bundle loaded after update on macosx [message #1764043 is a reply to message #1763998] Wed, 24 May 2017 05:30 Go to previous messageGo to next message
Thank you for your interesting information.
Yes we are running on Sierra but i am not sure that we are concerned by GPR, since our app is shipped directly in Applications folder.
From the debug i did, it seems to have something to do with "shared mode", although i dont know how to disable it.
Re: Wrong bundle loaded after update on macosx [message #1782872 is a reply to message #1764043] Fri, 02 March 2018 12:50 Go to previous messageGo to next message
Hello
I'm experiencing the same problem on Windos 10.. Have you found any solution?
Re: Wrong bundle loaded after update on macosx [message #1820913 is a reply to message #1782872] Fri, 31 January 2020 09:32 Go to previous message
Same here (although it is not reproducible), on Linux and Windows.
Did you ever find a solution or cause, Veselin?
Previous Topic:Export: Generate metadata repository fails with "A problem occured while invoking the direc
Next Topic:Updating target platform for RCP application from Neon to 2019-12
Current Time: Thu Jul 24 07:34:08 EDT 2025
Powered by FUDForum. Page generated in 0.04598 seconds
