| Does anyone test e(fx)clipse applications? [message #1763909] |
Mon, 22 May 2017 15:19  |
Hi community,
I am wondering if anyone has run unit, functional and integration tests on e(fx)clipse applications and can comment on what the best approach is.
After some research in the Internet, I found that many people recommend writing test code using fragments for each plugin in e4 applications. Is this the recommended way for e(fx)clipse too? According to what I read, this approach is limited to JUnit 3.X tests or JUnit 4.x if one creates and maintains the test suites (I want to believe there is something better).
Also, what is the best way to launch and shutdown the whole application to perform functional and integration tests from the test class?
Since testing is a must in my case, I am giving a shot to the gradle Goomph plugin to try to run Tom's maven example using gradle. That would be the dream scenario for me because of how easily all kind of tests can run under gradle.
I requested some help from one of Goomph's programmers (Ned Twigg) and I would happily post here a working example if I ever get that far. If anyone is interested, the question thread is here: https://github.com/diffplug/goomph/issues/31
Thanks!
FUDForum. Page generated in 0.07236 seconds
