Home » Modeling » TMF (Xtext) » ScopeProvider and Linker
ScopeProvider and Linker [message #1763891] Mon, 22 May 2017 12:38 Go to next message
Hi all
I have this metamodel
package fsm : fsm = 'http://fsm'
	class FSM
		property ownedState#owningFSM : State[*|1] { ordered composes };
	class State
		property owningFSM#ownedState : FSM[1];
		attribute name : String[?];
		property outgoingTransition#source : Transition[*|1] { ordered composes };
		property incomingTransition#target : Transition[*|1] { ordered };
		attribute initial : Boolean[1];
		attribute final : Boolean[1];
	class Transition
		property source#outgoingTransition : State[1];
		property target#incomingTransition : State[1];
		attribute input : String[?];
		attribute output : String[?];
	primitive datatype _'String' : 'java.lang.String' { serializable };
I generate a Xtext grammar from this metamodel
// automatically generated by Xtext
grammar org.xtext.example.fsm.FSM with org.eclipse.xtext.common.Terminals
import "http://fsm"
import "http://www.eclipse.org/emf/2002/Ecore" as ecore
FSM returns FSM:
	{FSM}
	'FSM'
		('ownedState' '{' ownedState+=State ( "," ownedState+=State)* '}' )?
State returns State:
	initial?='initial'
	final?='final'
	'State'
		('name' name=ID)?
		('outgoingTransition' '{' outgoingTransition+=Transition ( "," outgoingTransition+=Transition)* '}' )?
Transition returns Transition:
	'Transition'
		('input' input=STRING)?
		('output' output=STRING)?
		'target' target=[State|ID]
In order to manage the eopposite relation target <--> incomingTransition
I create a FSMLinker class
public class FSMLinker extends LazyLinker {
	protected EObject createProxy(EObject obj, INode node, EReference eRef) {
                        State s = (State) ((Transition)obj).eContainer();
			FSM fsm = (FSM) s.eContainer();
			for (State  state : fsm.getOwnedState())
				if(state.getName().equals(node.getText())){
					return state;
		return super.createProxy(obj, node, eRef);
I manage also the scope provider by editing FSMScopeProvider
class FSMScopeProvider extends AbstractFSMScopeProvider {
	override getScope(EObject object, EReference ref) {
		if (object instanceof Transition) {
			scope_Transition_target(object as Transition, ref)
	def scope_Transition_target(Transition transition, EReference reference) {
		var ArrayList<IEObjectDescription> res = new ArrayList<IEObjectDescription>
		var State s = transition.eContainer as State
		var FSM fsm = s.eContainer as FSM
		for (state : fsm.ownedState) {
			res.add(EObjectDescription.create(state.name, state))
		return new SimpleScope(IScope.NULLSCOPE, res)
When I create a model like this
FSM{
	ownedState
		initial final State { name s1  outgoingTransition {Transition {
			input "did" output "aa" target s1
		initial final State { name s2 }
no error is happened.
However, when i change the model to be like that
FSM{
	ownedState
			input "did" output "aa" target s2
An error appears
- The required feature 'target' of 'fsm.impl.TransitionImpl@58395231{platform:/resource/fsm/test.fsm#//@ownedState.0/@outgoingTransition.0}' must be set
Any suggestion?
Re: ScopeProvider and Linker [message #1763894 is a reply to message #1763891] Mon, 22 May 2017 12:56 Go to previous messageGo to next message
unfortuantely the way you post your stuff makes it hard to reproduce. (having an xcore metamodel would make it easier for example)
i dont see where you create the transitions. and i dont know your rules: shall this work within one files. or with multiple files as well.
Re: ScopeProvider and Linker [message #1763896 is a reply to message #1763894] Mon, 22 May 2017 13:01 Go to previous messageGo to next message
Maybe it is enhough to clone the proxy instead of simply returning it. But as I said. A reproducible example would help
Re: ScopeProvider and Linker [message #1763908 is a reply to message #1763896] Mon, 22 May 2017 15:07 Go to previous messageGo to next message
well after installing and fiddling around with oclinecore the following seems to work
public class MyDslDerivedStateComputer implements IDerivedStateComputer {
	@Inject
	SyntheticLinkingSupport sls;
	public void installDerivedState(DerivedStateAwareResource resource, boolean preLinkingPhase) {
		if (!resource.getContents().isEmpty() && preLinkingPhase) {
			FSM fsm = (FSM) resource.getContents().get(0);
			for (State s : fsm.getOwnedState()) {
				for (State ss : fsm.getOwnedState()) {
					for (Transition t : ss.getOutgoingTransition()) {
						List<INode> nodes = NodeModelUtils.findNodesForFeature(t, FsmPackage.Literals.TRANSITION__TARGET);
						if (!nodes.isEmpty()) {
							String text = nodes.get(0).getText().trim();
							if (s.getName().equals(text)) {
								final EObject proxy = EcoreUtil.create(FsmPackage.Literals.TRANSITION);
								((InternalEObject) proxy).eSetProxyURI(EcoreUtil.getURI(t));
								s.getIncomingTransition().add((Transition) proxy);
	public void discardDerivedState(DerivedStateAwareResource resource) {
		if (!resource.getContents().isEmpty()) {
				s.getIncomingTransition().clear();
class MyDslRuntimeModule extends AbstractMyDslRuntimeModule {
	def Class<? extends IDerivedStateComputer> bindIDerivedStateComputer() {
	def Class<? extends Manager> bindIResourceDescription$Manager() {
		DerivedStateAwareResourceDescriptionManager
	override Class<? extends XtextResource> bindXtextResource() {
Re: ScopeProvider and Linker [message #1763915 is a reply to message #1763908] Mon, 22 May 2017 17:38 Go to previous messageGo to next message
Thank you Christian for your personal investment.
I am sorry if the case study is not very clear.
I shared it in my github https://github.com/fzalila/fsm
I added the MyDslDerivedStateComputer.
I comment the Linker class.
The error disappears.
However, when I save a fsm model (test.fsm ) as xmi here, the incomingTransition reference, the eopposite reference of target reference, is not populated.
It means that the state "s3"
<ownedState name="s3" initial="true" final="true"/>
lacks
... incomingTransition="//@ownedState.0/@outgoingTransition.0">
Any idea how can I complete this information?
Re: ScopeProvider and Linker [message #1763916 is a reply to message #1763915] Mon, 22 May 2017 18:01 Go to previous messageGo to next message
In addition, when I try to create the model with the EMF editor and I add the target reference, an error occurs
It says that State.incomingTransition violates the upper bound: It holds 1 values, but only 0 are allowed.
However State.incomingTransition is an 0..* reference
Any suggestion?
java.lang.RuntimeException: Could not serialize State:
Semantic Object: FSM.ownedState[0]->State's'
URI: platform:/resource/fsm-examples/My.fsm
Context: State returns State
	at org.eclipse.xtext.serializer.diagnostic.ISerializationDiagnostic$ExceptionThrowingAcceptor.accept(ISerializationDiagnostic.java:131)
	at org.eclipse.xtext.serializer.sequencer.BacktrackingSemanticSequencer.createSequence(BacktrackingSemanticSequencer.java:503)
	at org.xtext.example.fsm.serializer.FSMSemanticSequencer.sequence_State(FSMSemanticSequencer.java:69)
	at org.xtext.example.fsm.serializer.FSMSemanticSequencer.sequence(FSMSemanticSequencer.java:39)
	at org.eclipse.xtext.serializer.sequencer.AbstractSemanticSequencer.createSequence(AbstractSemanticSequencer.java:67)
	at org.eclipse.xtext.serializer.acceptor.SequenceFeeder.acceptEObjectRuleCall(SequenceFeeder.java:325)
	at org.eclipse.xtext.serializer.acceptor.SequenceFeeder.acceptRuleCall(SequenceFeeder.java:352)
	at org.eclipse.xtext.serializer.acceptor.SequenceFeeder.accept(SequenceFeeder.java:263)
	at org.eclipse.xtext.serializer.sequencer.BacktrackingSemanticSequencer.accept(BacktrackingSemanticSequencer.java:434)
	at org.eclipse.xtext.serializer.sequencer.BacktrackingSemanticSequencer.createSequence(BacktrackingSemanticSequencer.java:501)
	at org.xtext.example.fsm.serializer.FSMSemanticSequencer.sequence_FSM(FSMSemanticSequencer.java:57)
	at org.xtext.example.fsm.serializer.FSMSemanticSequencer.sequence(FSMSemanticSequencer.java:36)
	at org.eclipse.xtext.serializer.impl.Serializer.serialize(Serializer.java:115)
	at org.eclipse.xtext.serializer.impl.Serializer.serializeToRegions(Serializer.java:136)
	at org.eclipse.xtext.serializer.impl.Serializer.serialize(Serializer.java:142)
	at org.eclipse.xtext.serializer.impl.Serializer.serialize(Serializer.java:189)
	at org.eclipse.xtext.resource.XtextResource.doSave(XtextResource.java:386)
	at org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(ResourceImpl.java:1430)
	at org.eclipse.emf.ecore.resource.impl.ResourceImpl.saveOnlyIfChangedWithMemoryBuffer(ResourceImpl.java:1144)
	at org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(ResourceImpl.java:985)
	at fsm.presentation.FsmEditor$18.execute(FsmEditor.java:1498)
	at org.eclipse.ui.actions.WorkspaceModifyOperation.lambda$0(WorkspaceModifyOperation.java:107)
	at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2240)
	at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2267)
	at org.eclipse.ui.actions.WorkspaceModifyOperation.run(WorkspaceModifyOperation.java:128)
	at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:119)
Re: ScopeProvider and Linker [message #1763919 is a reply to message #1763916] Mon, 22 May 2017 23:05 Go to previous messageGo to next message
For the latter you have to customize itransientvalueservice
Unfortunately the eopposit support in Xtext is quite bad.
So I have no idea.
Re: ScopeProvider and Linker [message #1763920 is a reply to message #1763919] Mon, 22 May 2017 23:11 Go to previous messageGo to next message
and i my unit test it works fine
 * generated by Xtext 2.12.0-SNAPSHOT
package org.xtext.example.mydsl.tests
import com.google.inject.Inject
import fsm.FSM
import org.eclipse.xtext.testing.InjectWith
import org.eclipse.xtext.testing.XtextRunner
import org.eclipse.xtext.testing.util.ParseHelper
import org.eclipse.xtext.testing.validation.ValidationTestHelper
import org.junit.Assert
import org.junit.Test
import org.junit.runner.RunWith
import org.eclipse.emf.ecore.EPackage
import fsm.FsmPackage
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl
import org.eclipse.emf.common.util.URI
import java.io.ByteArrayOutputStream
import java.nio.charset.StandardCharsets
@RunWith(XtextRunner)
@InjectWith(MyDslInjectorProvider)
class MyDslParsingTest {
	@Inject
	ParseHelper<FSM> parseHelper
	@Inject extension ValidationTestHelper h
	@Test
	def void loadModel() {
		EPackage.Registry.INSTANCE.put(FsmPackage.eNS_URI, FsmPackage::eINSTANCE)
		val result = parseHelper.parse('''
			FSM{
				ownedState
		Assert.assertNotNull(result)
		Assert.assertTrue(result.eResource.errors.isEmpty)
		println(result.validate)
		println('''
		«FOR s : result.ownedState»
			«s.name»:
			«FOR t : s.outgoingTransition»
				«t.target.name»
			«ENDFOR»
			«s.name»: «s.incomingTransition»
		«ENDFOR»
		val RS2 = new ResourceSetImpl
		val r2 = RS2.createResource(URI.createURI("dummy.xmi"))
		r2.contents.add(result)
		val baos = new ByteArrayOutputStream
		r2.save(baos, null)
		println(new String(baos.toByteArray, StandardCharsets.UTF_8))
Re: ScopeProvider and Linker [message #1763946 is a reply to message #1763920] Tue, 23 May 2017 05:42 Go to previous messageGo to next message
For me also the test is fine.
For the tested model
FSM{
				ownedState
when, I test parse it, I obtain the correct xmi
<?xml version="1.0" encoding="ASCII"?>
<fsm:FSM xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:fsm="http://fsm">
  <ownedState name="s1" initial="true" final="true">
    <outgoingTransition target="//@ownedState.1" input="did" output="aa"/>
  </ownedState>
  <ownedState name="s2" incomingTransition="//@ownedState.0/@outgoingTransition.0" initial="true" final="true"/>
</fsm:FSM>
However, when I Run my toxmi method
I obtain the following without incomingTransition
  </ownedState>
  <ownedState name="s2" initial="true" final="true"/>
</fsm:FSM>
This is my code used to save as xmi.
	public void run(IAction action) {
		IFile file = getFile();
		URI xtextURI = URI.createPlatformResourceURI(file.getFullPath().toString(), true);
	    XtextResourceSet resourceSet = new XtextResourceSet();
	    Resource xtextResource = resourceSet.createResource(xtextURI);
	    System.out.println(xtextURI.toString());
	    if (xtextResource != null){
		    Map<String,Boolean> options = new HashMap<String,Boolean>();
		    options.put(XtextResource.OPTION_RESOLVE_ALL, Boolean.TRUE);
		    try {
				xtextResource.load(options);
			} catch (IOException e1) {
				e1.printStackTrace();
		    Resource xmiResource = new XMIResourceFactoryImpl().createResource(xtextURI.trimFileExtension().appendFileExtension("xmi"));
		    xmiResource.getContents().add(xtextResource.getContents().get(0));
		    EcoreUtil.resolveAll(resourceSet);
		    try {
				xmiResource.save(null);
			} catch (IOException e) {
				e.printStackTrace();
	    }else{
	    	ModelStatus sts = new ModelStatus(IStatus.ERROR, "org.eclipse.xtext.toXmi", "http://fsm", "Impossible to load the selected file for xmi conversion.\n" +
	    			"Maybe this file is not an XText instance ? Status");
	    	ErrorDialog.openError(shell, "Error", "Impossible to load the selected file for xmi conversion.\n" +
	    			"Maybe this file is not an XText instance ?", sts);
Is it correct, PLZ ?
Re: ScopeProvider and Linker [message #1763952 is a reply to message #1763946] Tue, 23 May 2017 07:08 Go to previous messageGo to next message
maybe you should inject a iresourcesetprovider
to obtain the resourceset for the project
[Updated on: Tue, 23 May 2017 07:25] by Moderator
Re: ScopeProvider and Linker [message #1763964 is a reply to message #1763952] Tue, 23 May 2017 08:49 Go to previous messageGo to next message
I update my toXmi class
		Injector injector = FsmActivator.getInstance().getInjector("org.xtext.example.fsm.FSM");
		XtextResourceSetProvider provider = injector.getInstance(XtextResourceSetProvider.class);
		ResourceSet resourceSet = provider.get(file.getProject());
		XtextResource xtextResource = (XtextResource) resourceSet.getResource(xtextURI, true);;
		    try {
		    try {
	    }else{
I obtain that
    <outgoingTransition input="did" output="aa">
      <target href="My.fsm#|0"/>
    </outgoingTransition>
  </ownedState>
</fsm:FSM>
No IncomingTransition and target reference is not correct.
Plz, Christian, Does exist an example that can be followed to create my own toxmi module for my dsl?
best regards
Re: ScopeProvider and Linker [message #1763968 is a reply to message #1763964] Tue, 23 May 2017 09:00 Go to previous messageGo to next message
no but if you push your stuff and a example project i might one day find the time to debug this.
did you check the model is correct "after" loading from xtext?
is an unresolved proxy.
this might have todo with how you load the model.
- can you leave out the resolve all
- and do a EcoreUtil.resolve after loading the model?
Re: ScopeProvider and Linker [message #1763969 is a reply to message #1763968] Tue, 23 May 2017 09:16 Go to previous messageGo to next message
The whole projects are here https://github.com/fzalila/fsm
This is my EMF project
https://github.com/fzalila/fsm/tree/master/org.eclipse.fsm
This is my Xtext project
https://github.com/fzalila/fsm/tree/master/org.xtext.example.fsm
This is my toXmi module https://github.com/fzalila/fsm/tree/master/org.eclipse.xtext.toXmi
and this is my example project
https://github.com/fzalila/fsm/tree/master/fsm-examples
Re: ScopeProvider and Linker [message #1763971 is a reply to message #1763969] Tue, 23 May 2017 09:34 Go to previous messageGo to next message
issue is here
//remove the && preLinkingPhase
Re: ScopeProvider and Linker [message #1763972 is a reply to message #1763971] Tue, 23 May 2017 09:44 Go to previous message
wonderfuuuuuuuuuuuuuul!!
Thanks Christian :-)
It works perfectly
Previous Topic:Loading Xtext Resource Into EMF Editor Breaks on Save?
Next Topic:[SOLVED] Xtext : Personalize Description
Current Time: Sun Jul 20 21:18:17 EDT 2025
Powered by FUDForum. Page generated in 0.07774 seconds
