Nattable Export Excel Report contains filter string also [message #1722142] |
Tue, 02 February 2016 23:54  |
Hello Dirk/Team,
Trying to use the nattable excel export functionality, working perfect.
Got two queries, please asssit
1. I Use a FilterRowHeaderComposite (Excel Text Box type filter) in my table. So, if I filter a column with some string (say, xyz) and do an export, then the report contains filter string as well (xyz).
Is there a way to hide the filterrow (Or need to override and customize)?
2. I beleive XSSF support is not there, this has to be performed by ourselves. But is there a way, we can hide the error pops up when a generated excel report is opened?
Error : The file format and extension don't match. The file could be corrupted or unsafe. Unless you trust its source, don't open it. Do you want to open it anyway?
<<I got some of your answers related to the 2 question, so you can ignore the 2nd question>>
[Updated on: Tue, 02 February 2016 23:56] by Moderator
FUDForum. Page generated in 0.10640 seconds
