Home » Modeling » TMF (Xtext) » Targeting both eclipse and LSP
Targeting both eclipse and LSP [message #1763861] Mon, 22 May 2017 06:25 Go to next message
Hi!
I have an Xtext language that I need to use both as Eclipse plugin and as a LSP server. I managed to build the two versions, but the problem is that I have code in the generator class that uses Eclipse resource APIs /IFile, IMarker) and those aren't available to the LSP server.
The right fix would be to let the generator use only Files and return markers as LSP diagnostics, while using LSP4e on the Eclipse side, but I am targeting Neon and there's a lot of plumbing to adjust in order to make that work.
So I wonder if anyone has suggestions about a simpler solution. Thanks in advance!
best regards,
Vlad
Re: Targeting both eclipse and LSP [message #1763867 is a reply to message #1763861] Mon, 22 May 2017 06:48 Go to previous messageGo to next message
Your generator should not dependent on org.eclipse.core.resources. Typically generators are agnostic of the concrete file system, that's why we have different implementations for IFileSystemAccess.
And I am not getting why a generator should use IMarker? A generator should not do any validation, that's up to the validation API. Generators should assume that the model is completely valid, everything else has to be implemented in the validator. And then LSP would use that at the right time also.
Re: Targeting both eclipse and LSP [message #1763881 is a reply to message #1763867] Mon, 22 May 2017 10:00 Go to previous message
Thank you for the pointers, Karsten.
My excuse is that most of the code is from a while ago when I was greener, and it's not always easy to rethink it. 3rd party comments help a lot!
Anyway:
* the main reason to involve eclipse resources is that some URIs are platform:// and using ResourcesPlugin to resolve that is the simplest way (but now, it isn't anymore).
* my generator is an external process that even compiles the DSL, so this was an optimization that I have to review now.
thanks again,
Vlad
Previous Topic:Resolver/ResourceSet behavior doubts
Next Topic:Is Parser generated by XText thread safe?
Current Time: Mon May 12 21:03:42 EDT 2025
Powered by FUDForum. Page generated in 0.02658 seconds
