Home » Eclipse Projects » EGit / JGit » Eclipse egit not working
Eclipse egit not working [message #1763863] Mon, 22 May 2017 06:32 Go to next message
(this post initially comes from the newcomers forum, sorry for not knowing where to post it from the beginning)
I am trying to fetch from upstream using Eclipse.
If I right click on my project and go to Team -> Fetch from upstream, I get this error after a few seconds:
git-server:my-project: unknown host.
However if I type git fetch from the command line in the my-project folder, it works. In the Eclipse preferences, the ssh2 home points to my .ssh folder, and the .ssh/config contains a git-server line.
The project was cloned from the command line.
I don't see what's wrong, can you please help me ?
[Updated on: Mon, 22 May 2017 06:33] by Moderator
Re: Eclipse egit not working [message #1763927 is a reply to message #1763863] Tue, 23 May 2017 02:07 Go to previous messageGo to next message
Have you tried without an alias? I.e., using ssh://<user>@myhost.example.org/... URLs for the remotes?
Re: Eclipse egit not working [message #1764653 is a reply to message #1763927] Thu, 01 June 2017 04:08 Go to previous messageGo to next message
Well the alias is actually an alias to some ssh configuration, which includes proxy configuration, so I don't have direct access to the server. But using an alias shouldn't be a problem, assuming the ssh configuration is correct...
Re: Eclipse egit not working [message #1765022 is a reply to message #1764653] Mon, 05 June 2017 14:43 Go to previous messageGo to next message
Can I please get some help?
Re: Eclipse egit not working [message #1765254 is a reply to message #1765022] Wed, 07 June 2017 17:00 Go to previous messageGo to next message
Anyone?
Re: Eclipse egit not working [message #1765363 is a reply to message #1765254] Thu, 08 June 2017 14:54 Go to previous messageGo to next message
What kind of proxy configuration is in your .ssh/config for this git server ?
It's hard to guess what might be wrong without seeing the actual config.
Re: Eclipse egit not working [message #1765458 is a reply to message #1765363] Fri, 09 June 2017 13:22 Go to previous messageGo to next message
my ssh config is rather simple, it's something like
host git-server
user my-user
hostname 192.168.0.1
ProxyCommand /usr/bin/connect -a none -S 1.2.3.4 %h %p
but I doubt this is the issue, since I can git fetch from the command line. I just can't fetch from eclipse.
[Updated on: Fri, 09 June 2017 13:24] by Moderator
Re: Eclipse egit not working [message #1765477 is a reply to message #1765458] Sat, 10 June 2017 09:32 Go to previous message
I don't think Jsch (the Java ssh library Eclipse and JGit use) does ProxyCommand. Moreover, Jsch definitely doesn't do %-token substitution.
Previous Topic:Show Annotations option disappeared
Next Topic:Have JGit JschConfigSessionFactory ignore invalid keys
Current Time: Sun Jul 27 23:00:31 EDT 2025
Powered by FUDForum. Page generated in 0.06376 seconds
