Problem starting Kura on Karaf on Raspberry Pi [message #1761314] |
Tue, 09 May 2017 11:54  |
Dear all,
I've built the custom distribution of Karaf provided with the Kura project, then I've moved it on a Raspberry Pi 2 Model B Quad Core.
Then I started Karaf and I've installed the feature kura-linux-armv6hf and the bundle org.eclipse.kura.raspberrypi.sensehat (because I need to use the sensehat board on my project).
At the startup of Karaf I receive the errors:
2017-05-09 15:42:52,597 | ERROR | FelixStartLevel | usb | 216 - org.eclipse.kura.linux.usb - 1.0.100.201705021440 | [org.eclipse.kura.usb.UsbService(38)] The activate method has thrown an exception
java.lang.UnsatisfiedLinkError: no EurotechLinuxUdev in java.library.path
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1857)[:1.8.0]
at java.lang.Runtime.loadLibrary0(Runtime.java:870)[:1.8.0]
at java.lang.System.loadLibrary(System.java:1119)[:1.8.0]
at org.eclipse.kura.linux.usb.LinuxUdevNative$1.run(LinuxUdevNative.java:51)
at java.security.AccessController.doPrivileged(Native Method)[:1.8.0]
at org.eclipse.kura.linux.usb.LinuxUdevNative.<clinit>(LinuxUdevNative.java:45)
at org.eclipse.kura.linux.usb.UsbServiceImpl.activate(UsbServiceImpl.java:52)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)[:1.8.0]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)[:1.8.0]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)[:1.8.0]
at java.lang.reflect.Method.invoke(Method.java:483)[:1.8.0]
at org.apache.felix.scr.impl.helper.BaseMethod.invokeMethod(BaseMethod.java:222)[18:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.helper.BaseMethod.access$500(BaseMethod.java:37)[18:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.helper.BaseMethod$Resolved.invoke(BaseMethod.java:615)
at org.apache.felix.scr.impl.helper.BaseMethod.invoke(BaseMethod.java:499)[18:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.helper.ActivateMethod.invoke(ActivateMethod.java:295)[18:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:302)[18:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:113)[18:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:866)[18:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:833)[18:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:774)[18:org.apache.felix.scr:2.0.2]
at org.apache.felix.framework.ServiceRegistrationImpl.getFactoryUnchecked(ServiceRegistrationImpl.java:347)[org.apache.felix.framework-5.4.0.jar:]
at org.apache.felix.framework.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:247)[org.apache.felix.framework-5.4.0.jar:]
at org.apache.felix.framework.ServiceRegistry.getService(ServiceRegistry.java:344)[org.apache.felix.framework-5.4.0.jar:]
at org.apache.felix.framework.Felix.getService(Felix.java:3699)[org.apache.felix.framework-5.4.0.jar:]
at org.apache.felix.framework.BundleContextImpl.getService(BundleContextImpl.java:470)[org.apache.felix.framework-5.4.0.jar:]
at org.apache.felix.scr.impl.manager.SingleRefPair.getServiceObject(SingleRefPair.java:72)[18:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.helper.BindMethod.getServiceObject(BindMethod.java:646)[18:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.DependencyManager.getServiceObject(DependencyManager.java:2137)[18:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.prebind(DependencyManager.java:1048)[18:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.DependencyManager.prebind(DependencyManager.java:1457)[18:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.collectDependencies(AbstractComponentManager.java:983)[18:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:812)[18:org.apache.felix.scr:2.0.2]
at org.osgi.util.tracker.ServiceTracker.addingService(ServiceTracker.java:414)[org.osgi.core-6.0.0.jar:]
at org.eclipse.kura.core.configuration.ConfigurationServiceImpl$3.addingService(ConfigurationServiceImpl.java:259)[114:org.eclipse.kura.core.configuration:1.1.0.201705081607]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:870)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:901)[org.osgi.core-6.0.0.jar:]
at org.apache.felix.framework.util.EventDispatcher.invokeServiceListenerCallback(EventDispatcher.java:991)[org.apache.felix.framework-5.4.0.jar:]
at org.apache.felix.framework.util.EventDispatcher.fireEventImmediately(EventDispatcher.java:839)[org.apache.felix.framework-5.4.0.jar:]
at org.apache.felix.framework.util.EventDispatcher.fireServiceEvent(EventDispatcher.java:546)[org.apache.felix.framework-5.4.0.jar:]
at org.apache.felix.framework.Felix.fireServiceEvent(Felix.java:4557)[org.apache.felix.framework-5.4.0.jar:]
at org.apache.felix.framework.Felix.registerService(Felix.java:3549)[org.apache.felix.framework-5.4.0.jar:]
at org.apache.felix.framework.BundleContextImpl.registerService(BundleContextImpl.java:348)[org.apache.felix.framework-5.4.0.jar:]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:869)[18:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:857)[18:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:133)[18:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:915)[18:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:715)[18:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:954)[18:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:915)[18:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1215)[18:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1136)[18:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:945)[18:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:881)[18:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1167)[18:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:120)[18:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:399)[18:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.config.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:676)[18:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:339)[18:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:360)[18:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.Activator.access$000(Activator.java:53)[18:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:260)[18:org.apache.felix.scr:2.0.2]
at org.apache.felix.utils.extender.AbstractExtender.createExtension(AbstractExtender.java:259)[18:org.apache.felix.scr:2.0.2]
at org.apache.felix.utils.extender.AbstractExtender.modifiedBundle(AbstractExtender.java:232)[18:org.apache.felix.scr:2.0.2]
at org.apache.felix.utils.extender.AbstractExtender.addingBundle(AbstractExtender.java:192)[18:org.apache.felix.scr:2.0.2]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerAdding(BundleTracker.java:469)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerAdding(BundleTracker.java:415)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444)[org.osgi.core-6.0.0.jar:]
at org.apache.felix.framework.util.EventDispatcher.invokeBundleListenerCallback(EventDispatcher.java:916)[org.apache.felix.framework-5.4.0.jar:]
at org.apache.felix.framework.util.EventDispatcher.fireEventImmediately(EventDispatcher.java:835)[org.apache.felix.framework-5.4.0.jar:]
at org.apache.felix.framework.util.EventDispatcher.fireBundleEvent(EventDispatcher.java:517)[org.apache.felix.framework-5.4.0.jar:]
at org.apache.felix.framework.Felix.fireBundleEvent(Felix.java:4541)[org.apache.felix.framework-5.4.0.jar:]
at org.apache.felix.framework.Felix.activateBundle(Felix.java:2216)[org.apache.felix.framework-5.4.0.jar:]
at org.apache.felix.framework.Felix.startBundle(Felix.java:2144)[org.apache.felix.framework-5.4.0.jar:]
at org.apache.felix.framework.Felix.setActiveStartLevel(Felix.java:1371)[org.apache.felix.framework-5.4.0.jar:]
at org.apache.felix.framework.FrameworkStartLevelImpl.run(FrameworkStartLevelImpl.java:308)[org.apache.felix.framework-5.4.0.jar:]
at java.lang.Thread.run(Thread.java:744)[:1.8.0]
2017-05-09 15:42:52,624 | ERROR | FelixStartLevel | usb | 216 - org.eclipse.kura.linux.usb - 1.0.100.201705021440 | [org.eclipse.kura.usb.UsbService(38)] Failed creating the component instance; see log for reason
and
2017-05-09 15:42:52,627 | ERROR | lixDispatchQueue | position | 215 - org.eclipse.kura.linux.position - 1.0.100.201705021440 | FrameworkEvent ERROR - org.eclipse.kura.linux.position
org.osgi.framework.ServiceException: Service factory returned null. (Component: org.eclipse.kura.usb.UsbService (38))
at org.apache.felix.framework.ServiceRegistrationImpl.getFactoryUnchecked(ServiceRegistrationImpl.java:380)[org.apache.felix.framework-5.4.0.jar:]
How can I solve?
What is the correct way to install Kura and the sensehat bundle on my Raspberry board. under Karaf?
Thank you very much for your support,
Best regards
Re: Problem starting Kura on Karaf on Raspberry Pi [message #1766348 is a reply to message #1766255] |
Tue, 20 June 2017 08:26  |
unfortunately there is no new update on the Karaf side. The PR opened to solve the native lib loading is still pending because the author of the Karaf enhancement is having some issues to have the fix working in its environment.
I would suggest to open another issue on github to track the issue you are seeing with jdk.dio.
Matteo
FUDForum. Page generated in 0.04309 seconds
