Understanding UML file for parametric diagrams [message #1763450] |
Tue, 16 May 2017 06:23  |
I am creating a parametric diagram in SYSML. Once a diagram is created, I use the corresponding .uml file to do some post processing on the diagram. However, I see some discrepancy and hence seeking opinions.
I create 2 instances of a particular block (ConstraintBlock1) which has a single parameter named p1. I create a second block named ConstraintBlock2 with a parameter named p2. I connect p1 of both these blocks with p2 of ConstraintBlock2 using Binding connectors.
However, when I look into the .uml file saved corresponding to this diagram, the binding connectors reference the parameter names from within the ConstraintBlock1 Class and not from the individual objects of it. Thus, it is not possible to find out from the uml file which connector connects p2 to which instance of ConstraintBlock1.
This problem doesn't exist when only single instance of each block is used in the parametric diagram. But when using multiple instances, the connections should refer to the individual parameters from objects rather than at class level.
However, this problem is handled by the Papyrus tool in drawing the diagram because it saves the coordinates of the connections and blocks and replicates them in the diagram.
Attached a uml file for the same.
--rajesh
Attachment: d1.uml
(Size: 12.46KB, Downloaded 179 times)
Re: Understanding UML file for parametric diagrams [message #1763816 is a reply to message #1763450] |
Sat, 20 May 2017 11:34  |
Hi Seb,
Thanks for the details. I had uploaded a SYSML diagram earlier of previous version, but now I attach a SYSML1.4 diagram UML file.
TimetoAcc1, TimetoAcc2, TimetoAcc3, TimetoAcc4 are 4 constraint property of a constraint block type TimetoAcc.
BindingConnector5, BindingConnector6, BindingConnector7 and BindingConnector8 connect to these blocks. However, I cannot decipher from the UML file about which of these connector connects to which of the constraint property.
Compared to earlier version of SYSML diagram, there is no mention of ConstraintProperty in the diagram and also the nestedconnectorend doesn't reflect any such connection.
If you could shed some light on what I am missing, it will be very helpful.
--rajesh
Attachment: test.uml
(Size: 32.40KB, Downloaded 140 times)
FUDForum. Page generated in 0.04551 seconds
