Home » Archived » Jubula » Loading Project need Ten minutes or more, is it nomal?
Loading Project need Ten minutes or more, is it nomal? [message #1763619] |
Thu, 18 May 2017 00:01  |
My jubula project has 1500 testcases, The application is based on javaFX technology.It takes twenty minutes to load the testcase through the command ,In addition,4G memory is not enough for executing testcases.
Is there any way to solve these two problems?
Re: Loading Project need Ten minutes or more, is it nomal? [message #1764377 is a reply to message #1763925] |
Mon, 29 May 2017 05:50   |
Hi Wang
Does the problem happen during test execution or when loading the project? If it happens during loading the project then I don't have any quick idea what might cause the problems (we have projects with over 10,000 testcases, and they load within seconds). If the problem happens during test execution, then it may be caused by your AUT being a bit unfriendly to Jubula - something like this happened to one of our users. I don't want to go into the technical details, but the problem was that the AUT was generating a lot of Events, which were completely ignored by the AUT itself, but Jubula was interested in them, so this slowed down test execution enormously and finally caused an out-of-memory exception.
Without further information, I cannot really say more - please let me know if you still have this problem...
Best wishes,
Miklos
Re: Loading Project need Ten minutes or more, is it nomal? [message #1769150 is a reply to message #1768424] |
Thu, 27 July 2017 02:54  |
Is there any reused Project missing also from a reused project a reused Project? This slows down project loading a lot.
Did you try to use the H2 database this one is normally slower, but if there are some network problems it is faster.
It also sounds odd that your jubula needs that much memory, do you have any custom plugins installed?
with regards
Marvin Mueller
Current Time: Sun Jul 27 09:32:49 EDT 2025
Powered by FUDForum. Page generated in 0.19729 seconds
