Home » Archived » Jubula » Parameters of test case in Jubula(Parameters of test case in Jubula)
Parameters of test case in Jubula [message #1763732] Fri, 19 May 2017 03:29 Go to next message
I have some questions. Could you please help me to answer the questions.
1. As title, I want to run test suite in "testexec.exe" during Jubula GUI is closed. Let me know if I can edit parameters of Test Case without opening Jubula GUI (eg: Could I config some files?). By the way, If I could run more than one test suite?
2. I have a Test Case that using a loop. I want to the loop having time out or count number (eg: after 40s, the loop is finished or count number as for(i =0, i<10, i++)). Do you have any ideas to resolve the Test Case?
Trung.
Re: Parameters of test case in Jubula [message #1763926 is a reply to message #1763732] Tue, 23 May 2017 01:51 Go to previous messageGo to next message
1. If you want specific parameter values to be different when you run a test, then you can use environment variables which you then set on your machine before the test runs.
2. For a count number in a loop, you can use an iterate node (as of 8.4.1). For amount of time, you may be able to set and read a timer which you then use as a while condition (also as of 8.4.1).
Alex
Re: Parameters of test case in Jubula [message #1763929 is a reply to message #1763926] Tue, 23 May 2017 02:34 Go to previous messageGo to next message
1. Could you please explain your idea more clearly? I mean I just want to edit parameter in Test Case without opening Jubula GUI (see attach picture). Do you have any way?
2. Thanks for your answer! Could you please give me a example or document?
[Updated on: Wed, 24 May 2017 03:02] by Moderator
Re: Parameters of test case in Jubula [message #1764374 is a reply to message #1763929] Mon, 29 May 2017 05:40 Go to previous messageGo to next message
Hi Trung
No, there is no way to modify the Test Cases outside Jubula like you would like to do. What Alex suggested was to use Environment Variables. If you have a Test Case where you need data which you know will come from external sources, then you can set it up so that the Test Case uses a variable, and you can assign a value to this variable by setting Environment Variables before running the test, see here:
https://testing.bredex.de/files/content/software/documentation/userManual/tasks/ch03s14s05.html#using-environment-variables-in-tests
So if you'd like to use a variable with name EXTERNAL_DATA (e.g. use $EXTERNAL_DATA as a parameter), then you have to set the Environment Variable TEST_UDV_EXTERNAL_DATA before running the test.
Best wishes,
Miklos
Re: Parameters of test case in Jubula [message #1764383 is a reply to message #1764374] Mon, 29 May 2017 05:58 Go to previous message
Thank Miklos!
Previous Topic:Jubula 8.5 Standalone Released
Next Topic:Using Jubula jars in JavaFX
Current Time: Sun Jul 20 21:03:19 EDT 2025
Powered by FUDForum. Page generated in 0.04307 seconds
