Home » Modeling » EMF » Loading Xtext Resource Into EMF Editor Breaks on Save?
Loading Xtext Resource Into EMF Editor Breaks on Save? [message #1763683] Thu, 18 May 2017 10:38 Go to next message
I have a simple EMF model in which I have built the standard edit/editor plug-ins and therefore have a basic EMF editor that I can use to edit my EMF model. My EMF model has references to an Xtext DSL I've created. I have validated that all the models talk to one another and that I can create links from the EMF model to the Xtext model and the links are persisted as I want them to be.
I have found, however, that even loading the Xtext resource into the EMF editor is enough to break the editor while the doSave() method is being called. I don't have to have created any links between the models to get this broken behavior. In order to save, I have to close the dirty editor, and only then can I save the file without the following errors.
I can't put my finger on what is happening. All I have to do is load both models into the editor, and if I change anything in the EMF model to trigger a dirty setting, I get the following error:
!ENTRY company.domain..editor 2 0 2017-05-17 15:49:53.066
!MESSAGE
!STACK 0
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:398)
at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(ProgressMonitorDialog.java:481)
at dfdft.presentation.dfdftEditor.doSave(dfdftEditor.java:1527)
at org.eclipse.ui.internal.DefaultSaveable.doSave(DefaultSaveable.java:51)
at org.eclipse.ui.Saveable.doSave(Saveable.java:220)
Followed by a stack overflow inducing chain of these:
at org.eclipse.xtext.validation.impl.ConcreteSyntaxConstraintProvider.containsRelevantElement(ConcreteSyntaxConstraintProvider.java:318)
Each of the models validates on its own and there are no links between them.
Any ideas?
Edit: It is not my current intention to let people edit the Xtext DSL resource using this editor, I am only trying to demonstrated edits of my EMF model (which isn't Xtext).
Is this something to do with serialization of the Xtext model and even if I don't want to edit it, I need to provide some kind of serialization description?
[Updated on: Thu, 18 May 2017 10:42] by Moderator
Re: Loading Xtext Resource Into EMF Editor Breaks on Save? [message #1763725 is a reply to message #1763683] Fri, 19 May 2017 02:10 Go to previous messageGo to next message
No, I have no idea. The cause of the invocation target exception isn't shown/available? Certainly the generated editor will try to save all resources in the resource set, and perhaps that's not appropriate in this case for some of the resources...
Re: Loading Xtext Resource Into EMF Editor Breaks on Save? [message #1763769 is a reply to message #1763725] Fri, 19 May 2017 08:34 Go to previous message
I don't know if it's related, but in Sirius we had to explicitly ignore some Xtext-based resources from saving. Specifically, org.eclipse.xtext.common.types.access.TypeResource "throw new UnsupportedOperationException();" on save() (at least in Xtext 2.11).
Previous Topic:[CDO] Create ecore model with CDOBlob attribute
Next Topic:XML serialization
Current Time: Sat Jul 26 03:59:44 EDT 2025
Powered by FUDForum. Page generated in 0.03384 seconds
