Home » Modeling » TMF (Xtext) » Hide parts of the textual representation in the editor
Hide parts of the textual representation in the editor [message #1763658] Thu, 18 May 2017 08:01 Go to next message
Hi everybody,
I'm currently working on a DSL project, in which I have some potentially long datatype paths like this:
method myMethod(in /very/long/path/to/Datatype var1, out /another/long/path/to/Datatype2 var2)
Is there a possibility in Xtext to hide some parts of a string in the editor, but not to loose the information in the node model? My goal is to be able to toggle between the full and a short representation like this:
method myMethod(in Datatype var1, out Datatype2 var2)
It would be really helpful if someone could point me in the right direction.
Many thanks in advance!
Tobias
Re: Hide parts of the textual representation in the editor [message #1763670 is a reply to message #1763658] Thu, 18 May 2017 09:13 Go to previous messageGo to next message
have a look at the feature called folding. i dont know if it is applicable at your usecase though
Re: Hide parts of the textual representation in the editor [message #1763675 is a reply to message #1763670] Thu, 18 May 2017 09:38 Go to previous messageGo to next message
I managed to divide the paths in two segments, one for the absolute path and one for the actual type.
Is there a possibility to hide/collapse/fold an element on a token basis?
Folding normally works only on full lines.
Re: Hide parts of the textual representation in the editor [message #1763676 is a reply to message #1763675] Thu, 18 May 2017 09:48 Go to previous messageGo to next message
nope i think you have to dig into how folding works in eclipse text editors (the general term is projection i think)
and if this is possbile to be applied on a non line base.
Re: Hide parts of the textual representation in the editor [message #1763680 is a reply to message #1763676] Thu, 18 May 2017 10:10 Go to previous messageGo to next message
p.s: and if this is only about readablity you might have a look at the word wrap feature as well https://bugs.eclipse.org/bugs/show_bug.cgi?id=35779
Re: Hide parts of the textual representation in the editor [message #1763681 is a reply to message #1763676] Thu, 18 May 2017 10:22 Go to previous message
Thank you, Christian!
I will dig into the ProjectionViewer in order to get the desired result. There is a master/slave document mechanism which could be the solution.
The word wrap feature on the other hand is not exactly what I'm looking for, but thanks for the hint.
I will post a possible solution if I find one.
Previous Topic:default value for Boolean attribute and serialization
Next Topic:non-grammar features in a model object
Current Time: Mon Jul 21 04:59:24 EDT 2025
Powered by FUDForum. Page generated in 0.06588 seconds
