Home » Eclipse Projects » Eclipse 4 » How to populate undo/redo in an E3/E4 hybrid editor (DIEditorPart)?
How to populate undo/redo in an E3/E4 hybrid editor (DIEditorPart)? [message #1763648] Thu, 18 May 2017 07:02
My application is hybrid E3/E4 because I want to use parts of the Eclipse Workbench, but also make my stuff (somewhat) ready for later pure E4 based applications.
In this application I have an editor which uses a custom editor input (not file-based, but based on data pulled from a database; when the user saves the changes, they are written back to the database). My local in-memory representation of the data is managed by EMF / Xcore and the editor uses a manually-designed GUI that works via EMF Edit Databinding, i.e., I am using an EditingDomain (that is, a basic AdapterFactoryEditingDomain with a BasicCommandStack) to track all the changes.
To plug my E4 editor into an E3 editor, I use the compatibility layer, and here especially the DIEditorPart.
While this works fine so far, I have not yet been able to get undo/redo to work.
My code looks like this (I am using Scala with Scala-IDE):
The E3 editor bridge:
final class CustomEditorPartE3Bridge extends DIEditorPart(classOf[CustomEditorPart])
The "real" part:
final class CustomEditorPart {
  @Inject private var _ctx: IEclipseContext = _
  private var _view: Option[MyCustomEditorView] = None
  @Inject private var _dirty: MDirtyable = _
  @Inject @Optional private var _dirtyE3: IDirtyProviderService = _
  private var doPersist: () => Unit = () => {}
  @PostConstruct
  def init(input: IEditorInput): Unit = input match {
    case i: MyCustomEditorInput => initPart(i)
    case _ =>
      throw new IllegalStateException("Required a %s but got a %s".
        format(classOf[MyCustomEditorInput].getName, input.getClass.getName))
  private def initPart(input: MyCustomEditorInput): Unit = {
    val cc = _ctx.createChild()
    // Now we need an adapter factory and a respective editing domain
    // to enable Undo and Redo
    val adapterFactory = new ModelAdapterFactory // generated with Xcore
    val cs = new BasicCommandStack
    val domain = new AdapterFactoryEditingDomain(adapterFactory, cs)
    // We need the editing domain in the control for Databinding
    cc.set(classOf[EditingDomain], domain)
    // Now we setup the view
    _view = Some(ContextInjectionFactory.make(classOf[MyCustomEditorView], cc))
    // And we handle dirtying of our part
    object csl extends CommandStackListener {
      def commandStackChanged(eo: EventObject): Unit = {
        val dirty = cs.isSaveNeeded()
        if (_dirtyE3 == null) {
          _dirty.setDirty(dirty)
        } else {
          Display.getDefault.asyncExec(() => _dirtyE3.setDirtyState(dirty))
   cs.addCommandStackListener(csl)
    // Finally, we setup our saving routine.
    doPersist = () => { /* not relevant here */ }
  @Focus
  def setFocus(): Unit = _view.foreach(_.setFocus)
  @PersistState
  def persistState(): Unit = {}
  @Persist
  def commit(): Unit = doPersist()
So, how do I contribute undo/redo so that E3's undo/redo mechanism kicks in? Do I somehow have to propagate my EditingDomain back to my E3 bridge and set up some action bar contributor or can I inject something that sets up the undo/redo for me?
Previous Topic:How to use 'BeanProperties' without warnings
Next Topic:Product Configuration Wizard
Current Time: Sun Jul 20 20:20:23 EDT 2025
Powered by FUDForum. Page generated in 0.06294 seconds
