default value for Boolean attribute and serialization [message #1763633] |
Thu, 18 May 2017 04:31  |
Hi all,
I have this metamodel
package myDsl : myDsl = 'http://www.xtext.org/example/mydsl/MyDsl'
class Model
property greetings : Greeting[*|1] { ordered composes };
class Greeting
attribute name : String[?];
attribute condition : Boolean[1] = 'true';
It contains a boolean attribute "condition" (lowerbound 1, upperbound 1 and default value "true")
I create an Xtext project from this existing metamodel
The Xtext grammar is
// automatically generated by Xtext
grammar org.xtext.example.mydsl.MyDsl with org.eclipse.xtext.common.Terminals
import "http://www.xtext.org/example/mydsl/MyDsl"
import "http://www.eclipse.org/emf/2002/Ecore" as ecore
Model returns Model:
{Model}
'Model'
('greetings' '{' greetings+=Greeting ( "," greetings+=Greeting)* '}' )?
Greeting returns Greeting:
'Greeting'
name=ID
(condition?='valid')?
I create the following model
Model {
greetings {
Greeting test valid
I save and I open the model with the MyDsl editor model (the emf editor for mydsl).
I change the condition attribute value to "false".
When I save the model, i have this error
java.lang.RuntimeException: Could not serialize EObject via backtracking.
Constraint: Greeting_Greeting returns Greeting: (name=ID condition?='valid'?);
Values: name(1), condition(1)
Semantic Object: Model.greetings[0]->Greeting'ss'
URI: platform:/resource/mydsl/My.mydsl
Context: Greeting returns Greeting
at org.eclipse.xtext.serializer.diagnostic.ISerializationDiagnostic$ExceptionThrowingAcceptor.accept(ISerializationDiagnostic.java:131)
at org.eclipse.xtext.serializer.sequencer.BacktrackingSemanticSequencer.createSequence(BacktrackingSemanticSequencer.java:480)
at org.xtext.example.mydsl.serializer.MyDslSemanticSequencer.sequence_Greeting(MyDslSemanticSequencer.java:53)
at org.xtext.example.mydsl.serializer.MyDslSemanticSequencer.sequence(MyDslSemanticSequencer.java:35)
at org.eclipse.xtext.serializer.sequencer.AbstractSemanticSequencer.createSequence(AbstractSemanticSequencer.java:67)
at org.eclipse.xtext.serializer.acceptor.SequenceFeeder.acceptEObjectRuleCall(SequenceFeeder.java:325)
at org.eclipse.xtext.serializer.acceptor.SequenceFeeder.acceptRuleCall(SequenceFeeder.java:352)
at org.eclipse.xtext.serializer.acceptor.SequenceFeeder.accept(SequenceFeeder.java:263)
at org.eclipse.xtext.serializer.sequencer.BacktrackingSemanticSequencer.accept(BacktrackingSemanticSequencer.java:412)
at org.eclipse.xtext.serializer.sequencer.BacktrackingSemanticSequencer.createSequence(BacktrackingSemanticSequencer.java:478)
at org.xtext.example.mydsl.serializer.MyDslSemanticSequencer.sequence_Model(MyDslSemanticSequencer.java:65)
at org.xtext.example.mydsl.serializer.MyDslSemanticSequencer.sequence(MyDslSemanticSequencer.java:38)
at org.eclipse.xtext.serializer.impl.Serializer.serialize(Serializer.java:118)
at org.eclipse.xtext.serializer.impl.Serializer.serialize(Serializer.java:142)
at org.eclipse.xtext.serializer.impl.Serializer.serialize(Serializer.java:206)
at org.eclipse.xtext.resource.XtextResource.doSave(XtextResource.java:369)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(ResourceImpl.java:1430)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.saveOnlyIfChangedWithMemoryBuffer(ResourceImpl.java:1144)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(ResourceImpl.java:985)
at myDsl.presentation.MyDslEditor$18.execute(MyDslEditor.java:1498)
at org.eclipse.ui.actions.WorkspaceModifyOperation.lambda$0(WorkspaceModifyOperation.java:107)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2240)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2267)
at org.eclipse.ui.actions.WorkspaceModifyOperation.run(WorkspaceModifyOperation.java:128)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:119)
It seems that it is caused by the default value.
Any suggestion how resolve it?
best regards,
[Updated on: Thu, 18 May 2017 04:33] by Moderator
FUDForum. Page generated in 0.03740 seconds
