Home » Eclipse Projects » Papyrus for Real Time » Importing type from header file(Importing type from c library does not work anymore (v0.9))
Importing type from header file [message #1763603] Wed, 17 May 2017 14:06 Go to next message
Hi Everyone,
In PapyrusRT v 0.8, It was possible to use AttributeProperties and assign a type to the attributes which are imported using header files. For instance, the following figure shows that the type debugEvents::Event is assigned to an attribute.
index.php/fa/29383/0/
In the new version, using the same method raise an error during code generation which is shown in the following figure:
index.php/fa/29384/0/
Is a new way introduced to use imported type in v0.9? or this is a bug?
Mojtaba
Re: Importing type from header file [message #1763612 is a reply to message #1763603] Wed, 17 May 2017 15:06 Go to previous messageGo to next message
Are you running the 0.9 RCP or the developer environment?
Re: Importing type from header file [message #1763613 is a reply to message #1763612] Wed, 17 May 2017 15:27 Go to previous messageGo to next message
It's a regression. I've opened Bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=516842 if you want to keep track of it.
[Updated on: Wed, 17 May 2017 15:33] by Moderator
Re: Importing type from header file [message #1763615 is a reply to message #1763613] Wed, 17 May 2017 16:58 Go to previous messageGo to next message
I've merged a fix. It will be in the nightly update site shortly.
If you are on the developer environment, you can pull the git repo. (I also recommend pulling the website repo and executing the Oomph setup: Help -> Perform Setup Tasks...)
Re: Importing type from header file [message #1763921 is a reply to message #1763615] Mon, 22 May 2017 23:24 Go to previous message
Thanks a lot.
Mojtaba
Previous Topic:Request to evaluate our model validation plug-in for Papyrus-RT
Next Topic:rtBound signal is not shown in message list
Current Time: Sun Jun 01 00:21:11 EDT 2025
Powered by FUDForum. Page generated in 0.03033 seconds
