Home » Eclipse Projects » GEF » expand/collapse the Container EditPart in "flow" example
expand/collapse the Container EditPart in "flow" example [message #176340] Sat, 09 April 2005 11:01 Go to next message
Originally posted by: eric_guoyi.hotmail.com
This is my case. I want to modify the "flow" example of GEF3.0 to implement
functions that can expand/collapse the StructuredActivityEditPart by
double-click or ContextMenu.
Here is my step:
1.add the attribute named "isExpand" on the StructuredActivity Model;
2.add the command "ControlUnfoldCommand" to control the model's attribute;
3.add the EditPolicy to get that command,then install that EditPolicy
mapping DIRECT_EDIT_ROLE;
How should I do next ?
Re: expand/collapse the Container EditPart in "flow" example [message #176424 is a reply to message #176340] Sun, 10 April 2005 12:31 Go to previous message
Override performRequest() in your EditPart to launch the direct edit
manager. If you're not sure how to do this, look at our several examples or
just search this newsgroup.
Lastly, when your command changes the model, your EditPart will be notified
of this change. At that point, you'll have to update your figure to look
like it's expanded/collapsed.
"Eric Guo" <eric_guoyi@hotmail.com> wrote in message
news:d38ngn$g9$1@news.eclipse.org...
> Hello,
implement
> Here is my step:
Previous Topic:PolygonDecoration: widget disposed
Next Topic:Anchor Problem or Router Problem??
Current Time: Sun Jul 20 21:10:08 EDT 2025
Powered by FUDForum. Page generated in 0.03834 seconds
