Home » Eclipse Projects » Dirigible » New Repository Structure(Restructuring current Repository hierarchy )
New Repository Structure [message #1763315] Fri, 12 May 2017 10:43 Go to next message
Hi Team,
For the new release I thing it's time to have some changes in the Repository.
1. Remove '/db/dirigible' root collection, as it doesn't bring any value
2. Remove the mandatory semantic folders (e.g. 'DataStructures', 'ScriptingServices', 'WebContent', ...)
3. The publish process to be simple 'copy/paste' from the Workspace to the Registry
4. Publish updaters will work based on the file extension, as of now, for the whole Repository
5. The Preview of the artifacts will be dependent by the file extension:
5.1 *.html to be rendered
5.2 *.js will be considered to be executed server-side
6. For the runtime access the 'semantic' path will be still needed, as of now
- /js/example/service.js will be executed server-side
- /web/example/app.js will be executed client-side
Yordan
Re: New Repository Structure [message #1763323 is a reply to message #1763315] Fri, 12 May 2017 11:36 Go to previous messageGo to next message
Hi Yordan,
This proposal looks simpler and much more straight forward than what we have now, I like it.
Something which have to be mentioned is that with this structure the project name will be part of the service module e.g. var myModule1 = require("my_project/some_package/my_module1") which is not necessary a bad thing of course.
Nedelcho
Re: New Repository Structure [message #1763327 is a reply to message #1763323] Fri, 12 May 2017 12:19 Go to previous messageGo to next message
Hi Nedelcho,
What about projects migration?
How we will achieve backward compatibility for projects built with the 2.x version, or at least what will be the migration path?
One possible way is during import to look for the semantic folders, ignore them, ignore the project name and import packages as a top level projects. So in this way project with the following stricture [1] will be imported as [2].
[1]
Example/ScriptingService
/module1/test.js
/module2/test2.js
[2]
module1/test.js
module2/test2.js
Note: module1 and module2 are top level projects!
Yordan
Re: New Repository Structure [message #1763332 is a reply to message #1763327] Fri, 12 May 2017 13:18 Go to previous messageGo to next message
We can have issues with the Git sourced projects in this way. Of course, we can revise the Project:Repository 1:1 decision as well
Re: New Repository Structure [message #1763405 is a reply to message #1763332] Mon, 15 May 2017 07:10 Go to previous message
New Repository structure proposal:
/registry
  /public
    /<project_name>
        /<artefact_name>
  /settings
    /<setting_group>
      /<setting_file>
  /templates
    /<template_name>
      /<template_artefact_name>
/users
  /<user_name>
    /<workspace_name>
      /<project_name>
        /<artefact_name>
Previous Topic:Remove Semantic Folders
Next Topic:Vert.x for reactive apps
Current Time: Mon Jul 21 02:05:43 EDT 2025
Powered by FUDForum. Page generated in 0.29861 seconds
