Home » Eclipse Projects » Eclipse Platform » Eclipse 3.0M6 does not start on Linux under SDK 1.4.2_03
Eclipse 3.0M6 does not start on Linux under SDK 1.4.2_03 [message #176325] Tue, 06 January 2004 15:19 Go to next message
Originally posted by: Gerald.Preissler.gmx.de
Repost since I did not get any farther since my last post.
Eclipse 2.1.1 works on my box (Gentoo Linux with Sun SDK 1.4.2_03), but
when I try to start Eclipse 3.0M6/gtk , I get a messagebox that indicates
problems during startup. In $workspace/.metadata/.log, I find the
following:
--8<--cut
!SESSION
!ENTRY org.eclipse.core.launcher 4 0 Jan 02, 2004 22:05:41.295
!MESSAGE Exception launching the Eclipse Platform:
!STACK
java.lang.NoClassDefFoundError: org/eclipse/swt/widgets/Listener
        at org.eclipse.ui.PlatformUI.createDisplay( PlatformUI.java:149)
        at
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:41)
        at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
        at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:85)
        at sun.reflect.NativeMethodAccessorImpl.inv oke0(Native Method)
        at
        at
        at java.lang.reflect.Method.invoke(Method.j ava:324)
        at org.eclipse.core.launcher.Main.basicRun( Main.java:279)
        at org.eclipse.core.launcher.Main.run(Main. java:742)
        at org.eclipse.core.launcher.Main.main(Main .java:581)
--8=--cut
I tried setting LD_LIBRARY_PATH to
$eclipse_home/plugins/org.eclipse.swt.gtk_3.0.0/os/linux/x86 , but that did
not help.
Any hints where the problem might be?
tia
Jerry
Re: Eclipse 3.0M6 does not start on Linux under SDK 1.4.2_03 [message #176370 is a reply to message #176325] Tue, 06 January 2004 16:52 Go to previous message
Go file a bug in bugzilla...
Sebastian
Sebastian Davids (sdavids@gmx.de, davids_s@informatik.haw-hamburg.de)
ICQ: 1 16 44 89 80
PGP: EA57 0FA0 1C56 157E DD57 96EE 54B1 3E55 1F92 51DA
Previous Topic:Strange Behavior with loggers
Next Topic:TextEditor and editable Property view
Current Time: Sat Jul 26 10:17:42 EDT 2025
Powered by FUDForum. Page generated in 0.04048 seconds
