Home » Eclipse Projects » GEF » How to use arrow key to adjust figure's position slightly
How to use arrow key to adjust figure's position slightly [message #175961] Thu, 07 April 2005 01:38 Go to next message
Hi all,
When I use GEF's logic example, I found the figure only can moved by mouse.
If two figure connect by a connection, and I want to make the connection
horizontal, then I must move one figure many times to make this.
Is there a way to register some keys(arrow key), to adjust figure's
position slightly?
Just like Photoshop, can use mouse to move the figure position, and also
can use arrow key to move figure slightly.
Re: How to use arrow key to adjust figure's position slightly [message #176031 is a reply to message #175961] Thu, 07 April 2005 10:25 Go to previous messageGo to next message
GEF is completely accessible. Select an EditPart and hit '.' -- the
period/fullstop key.
"wei zhang" <zhang-wei@sinocom.cn> wrote in message
news:156c467415e028515422f96947821cab$1@www.eclipse.org...
> Hi all,
mouse.
> position slightly?
> Thanks
Re: How to use arrow key to adjust figure's position slightly [message #176115 is a reply to message #176031] Thu, 07 April 2005 22:05 Go to previous messageGo to next message
Oh, I see.
Thanks a lot.
But I had another questions.
I found when I put a "Circuit" EditPart to "emptyModel1.logic",
and select this EditPart, then hit '.' key,
the period/fullstop key appeared.
The period/fullstop keys contain 8 resize keys(can resize EditPart)
and 1 move key(can move the EditPart's position).
But put a "Or Gate" EditPart to "emptyModel1.logic",
and do the same operation.
The period/fullstop keys only contain 5 move key.
Why different EditPart get different kinds of period/fullstop key?
Is there a way to disable the resize key from period/fullstop keys?
Re: How to use arrow key to adjust figure's position slightly [message #176190 is a reply to message #176115] Fri, 08 April 2005 11:17 Go to previous messageGo to next message
Gates and LEDs can't be resized, hence the resize handles don't show up on
them. Look at ResizableEditPolicy.
news:ce8e404bb00446bad5e9d0a2de4b0eca$1@www.eclipse.org...
> Oh, I see.
> Thanks a lot.
Re: How to use arrow key to adjust figure's position slightly [message #176195 is a reply to message #176115] Fri, 08 April 2005 11:18 Go to previous messageGo to next message
Yes, you can customize all of this using AccessibleHandleProvider interface
Gates are not resizable
> Oh, I see.
> Thanks a lot.
> I found when I put a "Circuit" EditPart to "emptyModel1.logic", and select
> this EditPart, then hit '.' key, the period/fullstop key appeared. The
> But put a "Or Gate" EditPart to "emptyModel1.logic", and do the same
> operation.
Re: How to use arrow key to adjust figure's position slightly [message #176598 is a reply to message #176195] Sun, 10 April 2005 23:47 Go to previous message
Thanks a lot
I also found just overwrite
XYLayoutEditPolicy#createChildEditPolicy(EditPart) will be disable resize
action.
code just like this
protected EditPolicy createChildEditPolicy(EditPart child) {
ResizableEditPolicy policy = new ResizableEditPolicy();
policy.setResizeDirections(0);
return policy;
Previous Topic:Anchor Problem or Router Problem??
Next Topic:Switch figure of a model
Current Time: Wed Sep 03 22:04:00 EDT 2025
Powered by FUDForum. Page generated in 0.40918 seconds
