Home » Eclipse Projects » Remote Application Platform (RAP) » Deploying RAP Mail onto Apache Karaf(Deploying RAP Mail onto Apache Karaf)
Deploying RAP Mail onto Apache Karaf [message #1761889] Thu, 11 May 2017 11:53 Go to next message
Hi all,
I was wondering if anyone has experience in deploying RAP Mail on Karaf. Sometimes it's successfully deployed but sometimes the following exception occurs:
org.apache.karaf.features.internal.util.MultiException: Error restarting bundles
	at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:868)[8:org.apache.karaf.features.core:4.0.8]
	at org.apache.karaf.features.internal.service.FeaturesServiceImpl.doProvision(FeaturesServiceImpl.java:1176)[8:org.apache.karaf.features.core:4.0.8]
	at org.apache.karaf.features.internal.service.FeaturesServiceImpl$1.call(FeaturesServiceImpl.java:1074)[8:org.apache.karaf.features.core:4.0.8]
	at java.util.concurrent.FutureTask.run(FutureTask.java:266)[:1.8.0_66]
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)[:1.8.0_66]
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)[:1.8.0_66]
	at java.lang.Thread.run(Thread.java:745)[:1.8.0_66]
Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.equinox.http.registry.internal.Activator.start() of bundle org.eclipse.equinox.http.registry.
	at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:792)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:721)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
	at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:941)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
	at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:318)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
	at org.eclipse.osgi.container.Module.doStart(Module.java:571)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
	at org.eclipse.osgi.container.Module.start(Module.java:439)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
	at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:392)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
	at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:411)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
	at org.apache.karaf.features.internal.service.FeaturesServiceImpl.startBundle(FeaturesServiceImpl.java:1287)[8:org.apache.karaf.features.core:4.0.8]
	at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:860)[8:org.apache.karaf.features.core:4.0.8]
	... 6 more
Caused by: java.lang.NullPointerException: null values not allowed
	at org.eclipse.core.internal.registry.ReferenceMap.put(ReferenceMap.java:355)
	at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.getBundle(RegistryStrategyOSGI.java:151)
	at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:166)
	at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
	at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
	at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
	at org.eclipse.equinox.http.registry.internal.HttpContextManager.added(HttpContextManager.java:75)
	at org.eclipse.equinox.http.registry.internal.ExtensionPointTracker.open(ExtensionPointTracker.java:75)
	at org.eclipse.equinox.http.registry.internal.HttpContextManager.start(HttpContextManager.java:47)
	at org.eclipse.equinox.http.registry.internal.HttpRegistryManager.start(HttpRegistryManager.java:104)
	at org.eclipse.equinox.http.registry.internal.HttpServiceTracker.addingService(HttpServiceTracker.java:58)
	at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941)[org.osgi.core-6.0.0.jar:]
	at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:870)[org.osgi.core-6.0.0.jar:]
	at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256)[org.osgi.core-6.0.0.jar:]
	at org.osgi.util.tracker.AbstractTracked.trackInitial(AbstractTracked.java:183)[org.osgi.core-6.0.0.jar:]
	at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:318)[org.osgi.core-6.0.0.jar:]
	at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:261)[org.osgi.core-6.0.0.jar:]
	at org.eclipse.equinox.http.registry.internal.HttpServiceTracker.open(HttpServiceTracker.java:42)
	at org.eclipse.equinox.http.registry.internal.Activator.addingService(Activator.java:59)
	at org.eclipse.equinox.http.registry.internal.Activator.start(Activator.java:37)
	at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:771)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
	at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
	at java.security.AccessController.doPrivileged(Native Method)[:1.8.0_66]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:764)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
	... 15 more
Any insight would be greatly appreciated.
Thanks & Regards,
SetNug
Re: Deploying RAP Mail onto Apache Karaf [message #1761921 is a reply to message #1761889] Thu, 11 May 2017 17:41 Go to previous messageGo to next message
It looks like it can't find the bundle for the contributor.
At least that's what it looks like from looking at the eclipse source code. It's passing a null value for a bundle it should have found
Re: Deploying RAP Mail onto Apache Karaf [message #1763290 is a reply to message #1761921] Fri, 12 May 2017 07:38 Go to previous messageGo to next message
Hi Chris,
Thank you for looking into this.
Looking at the code, the error caused by the following snippet:
bundle = Activator.getContext().getBundle(OSGiId);
which returns null, but since there's no log, it's not possible to know what OSGiId is.
Thanks & Regards,
SetNug
Re: Deploying RAP Mail onto Apache Karaf [message #1763416 is a reply to message #1761889] Mon, 15 May 2017 10:08 Go to previous message
Maybe the same reason as what is described here?
https://issues.apache.org/jira/browse/KARAF-4070
Previous Topic:Handle CTRL+S in a RAP application
Next Topic:Download file
Current Time: Sun Jul 27 01:12:02 EDT 2025
Powered by FUDForum. Page generated in 0.04770 seconds
