Home » Modeling » OCL » Evaluation of transformations with OCL
Evaluation of transformations with OCL [message #33638] Fri, 20 July 2007 13:02 Go to next message
I was wondering if anyone has experience with evaluating transformations
with OCL. From my limited knowledge on the subject, I believe constraint
based checking can be used to verify that a transformation is correct.
By providing a redundant specification in OCL of the result of the
transformation can a transformation be evaluated? If anyone have any
tips, tools, papers or links that may be of interest I would appreciate it.
Andrew.
Re: Evaluation of transformations with OCL [message #33671 is a reply to message #33638] Fri, 20 July 2007 16:06 Go to previous messageGo to next message
Hi, Andrew,
Are you dealing with metamodel-to-metamodel transformations, or with
model-to-model transformations in the same metamodel? Note that OCL (as
implemented in MDT) supports only the Ecore and UML metamodels, to date.
You may want to ask about this on the GMT and/or M2M newsgroups. There QVT
implementations in the works in these projects, and their communities have
some valuable insight.
Christian
Andrew Carton wrote:
> it.
> Andrew.
Re: Evaluation of transformations with OCL [message #33805 is a reply to message #33638] Tue, 24 July 2007 04:45 Go to previous messageGo to next message
Originally posted by: wah.zurich.ibm.com
Andrew,
we have written a paper a while ago in which we use OCL to specify the
preconditions and postconditions of transformations. It may contain some
useful information for you.
You can find a PDF version of the paper here:
http://www.research.ibm.com/journal/sj/441/koehler.pdf
Michael
> Andrew.
1'" [message #1761854] Thu, 11 May 2017 11:37 Go to previous messageGo to next message
@@5rGry [message #1761856] Thu, 11 May 2017 11:38 Go to previous messageGo to next message
[message #1761857] Thu, 11 May 2017 11:38 Go to previous messageGo to next message
[message #1761858] Thu, 11 May 2017 11:38 Go to previous messageGo to next message
1'" [message #1761859] Thu, 11 May 2017 11:39 Go to previous messageGo to next message
@@duhu1 [message #1761860] Thu, 11 May 2017 11:39 Go to previous messageGo to next message
[message #1761861] Thu, 11 May 2017 11:40 Go to previous messageGo to next message
[message #1761862] Thu, 11 May 2017 11:40 Go to previous messageGo to next message
1'" [message #1761863] Thu, 11 May 2017 11:41 Go to previous messageGo to next message
@@y3OhE [message #1761864] Thu, 11 May 2017 11:41 Go to previous messageGo to next message
[message #1761865] Thu, 11 May 2017 11:42 Go to previous messageGo to next message
[message #1761866] Thu, 11 May 2017 11:42 Go to previous messageGo to next message
1'" [message #1761867] Thu, 11 May 2017 11:43 Go to previous messageGo to next message
@@9ny2d [message #1761868] Thu, 11 May 2017 11:43 Go to previous messageGo to next message
[message #1761869] Thu, 11 May 2017 11:44 Go to previous messageGo to next message
[message #1761870] Thu, 11 May 2017 11:44 Go to previous messageGo to next message
1'" [message #1761871] Thu, 11 May 2017 11:45 Go to previous messageGo to next message
@@yQuCy [message #1761872] Thu, 11 May 2017 11:45 Go to previous messageGo to next message
[message #1761873] Thu, 11 May 2017 11:45 Go to previous messageGo to next message
[message #1761874] Thu, 11 May 2017 11:46 Go to previous messageGo to next message
1'" [message #1761875] Thu, 11 May 2017 11:46 Go to previous messageGo to next message
@@oD1pA [message #1761876] Thu, 11 May 2017 11:47 Go to previous messageGo to next message
[message #1761877] Thu, 11 May 2017 11:47 Go to previous messageGo to next message
[message #1761878] Thu, 11 May 2017 11:48 Go to previous messageGo to next message
1'" [message #1761879] Thu, 11 May 2017 11:48 Go to previous messageGo to next message
@@1YEKt [message #1761880] Thu, 11 May 2017 11:49 Go to previous messageGo to next message
[message #1761881] Thu, 11 May 2017 11:49 Go to previous messageGo to next message
[message #1761882] Thu, 11 May 2017 11:50 Go to previous messageGo to next message
1'" [message #1761883] Thu, 11 May 2017 11:50 Go to previous messageGo to next message
@@r9Uyy [message #1761884] Thu, 11 May 2017 11:51 Go to previous messageGo to next message
[message #1761885] Thu, 11 May 2017 11:51 Go to previous messageGo to next message
[message #1761886] Thu, 11 May 2017 11:52 Go to previous messageGo to next message
1'" [message #1761887] Thu, 11 May 2017 11:52 Go to previous messageGo to next message
@@gArg2 [message #1761888] Thu, 11 May 2017 11:53 Go to previous messageGo to next message
[message #1761890] Thu, 11 May 2017 11:53 Go to previous messageGo to next message
[message #1761891] Thu, 11 May 2017 11:54 Go to previous messageGo to next message
1'" [message #1761892] Thu, 11 May 2017 11:54 Go to previous messageGo to next message
@@aeaBO [message #1761893] Thu, 11 May 2017 11:55 Go to previous messageGo to next message
[message #1761894] Thu, 11 May 2017 11:55 Go to previous messageGo to next message
[message #1761895] Thu, 11 May 2017 11:56 Go to previous messageGo to next message
1'" [message #1761896] Thu, 11 May 2017 11:56 Go to previous messageGo to next message
@@elmQg [message #1761897] Thu, 11 May 2017 11:57 Go to previous messageGo to next message
[message #1761899] Thu, 11 May 2017 11:57 Go to previous messageGo to next message
[message #1761900] Thu, 11 May 2017 11:57 Go to previous messageGo to next message
1'" [message #1761902] Thu, 11 May 2017 11:58 Go to previous messageGo to next message
@@PeUnK [message #1761903] Thu, 11 May 2017 11:58 Go to previous messageGo to next message
[message #1761904] Thu, 11 May 2017 11:59 Go to previous messageGo to next message
[message #1761906] Thu, 11 May 2017 11:59 Go to previous messageGo to next message
Re: help on SaveAs [message #1763333] Fri, 12 May 2017 13:24 Go to previous message
Previous Topic:Setting non-blank root/package URIs in Papyrus
Next Topic:UML constraints context
Current Time: Thu Nov 06 13:03:02 EST 2025
Powered by FUDForum. Page generated in 0.13952 seconds
