Home » Eclipse Projects » GEF » Palette reset on nodes not connections
Palette reset on nodes not connections [message #176184] Fri, 08 April 2005 10:50 Go to next message
Originally posted by: james.willans.xactium.com
Once a node has been added to a GEF diagram, the palette automatically
resets itself to be the general selection tool. This is not the case for
connection tools. How would I go about changing the moding so that the
node tools behave the same way as connection tools (remain in the same
mode until the user chooses something different)?
Thanks.
James
Re: Palette reset on nodes not connections [message #176221 is a reply to message #176184] Fri, 08 April 2005 11:49 Go to previous messageGo to next message
If you're using the latest build or HEAD:
toolEntry.setToolProperty(AbstractTool.PROPERTY_UNLOAD_WHEN_ FINISHED,
Boolean.FALSE);
Otherwise, override createTool() and invoke
tool.setUnloadWhenFinished(false)
"James Willans" <james.willans@xactium.com> wrote in message
news:001126e0dd67ee7d3f37310db43927c1$1@www.eclipse.org...
> Thanks.
> James
Re: Palette reset on nodes not connections [message #176334 is a reply to message #176221] Sat, 09 April 2005 07:09 Go to previous message
Thanks Pratik - that worked.
> Boolean.FALSE);
>> Thanks.
>> James
Previous Topic:Limit number of Lines in TextFlow
Next Topic:How to limit the number of connections?
Current Time: Sat Jul 26 19:19:43 EDT 2025
Powered by FUDForum. Page generated in 0.03550 seconds
