Home » Modeling » Papyrus » SysML FlowProperty is typed by a Signal validation Error 9.3.2.5
SysML FlowProperty is typed by a Signal validation Error 9.3.2.5 [message #1761168] Mon, 08 May 2017 09:50 Go to next message
I have a model created using Papyrus (2) Neon (4.6) in SysML (1.4).
I have added a FlowProperty to an InterfaceBlock and typed it using a Signal, when I perform model validation, I get the following error:
Severity: Error;
Description: 9.3.2.5  FeatureDirection [1] A FlowProperty is typed by a ValueType, Block, or Signal.;
Element: <<FlowProperty>> <Property> NoData : NoData;
Parent: TPU::Structure::ISignals;
Type: EMF Problem;
I have tried looking in the forum for something similar, but unable to find anything, also, did try google.
I am looking to either totally or correctly type the FlowProperty with a Signal or disable this validation only.
A note, if I remove the FlowProperty stereotype, I don't get this validation error.
Any help is appreciated.
Thank you.
[Updated on: Mon, 08 May 2017 21:44] by Moderator
Re: SysML FlowProperty is typed by a Signal validation Error 9.3.2.5 [message #1761224 is a reply to message #1761168] Tue, 09 May 2017 04:28 Go to previous messageGo to next message
Thx for reporting that. It's an issue.
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=516343
You can temporary disable this specific rule:
- Window>Preferences
- Model Validation > Constraints
- SysML 1.4 normative constraints
- uncheck flowproperty.typedby
Benoît
Re: SysML FlowProperty is typed by a Signal validation Error 9.3.2.5 [message #1761288 is a reply to message #1761224] Tue, 09 May 2017 09:37 Go to previous message
Dear Benoit Maggi,
Appreciate your prompt action and replay.
I have disabled the validation and looking forward for the next SysML release.
Thank you.
Previous Topic:Add a common name to several SysML Block Definition Diagram associations
Next Topic:State Machine Graphical Transition notation
Current Time: Sun Jul 27 09:41:26 EDT 2025
Powered by FUDForum. Page generated in 0.23609 seconds
