State Machine Graphical Transition notation [message #1761193] |
Mon, 08 May 2017 13:35  |
I am working on State Machine diagrams and want to build a diagram using the Graphical Transition notation, where you can model the trigger of the Transition as Signal receipt symbol.
From UML 2.5 specs:
14.2.4.9 Transition
As an alternative, in cases where the effect Behavior can be described as a control-flow based sequence of Actions, there is a graphical representation for Transitions and compound transitions which is similar to the notation used for Activities.
One of these actions:
14.2.4.9.2 Signal receipt symbol
Signal receipt symbol is shown as a five-pointed polygon that looks like a rectangle with a triangular notch in one
of its sides (either one).
This does not seem to be implemented in Papyrus Neon 2. Will it ever be implemented?
Or there is a workaround to enable/use this alternative notation.
Appreciate any help.
Thank you.
FUDForum. Page generated in 0.06630 seconds
