Home » Modeling » TMF (Xtext) » Cross Reference without additional feature
Cross Reference without additional feature [message #1761176] Mon, 08 May 2017 11:11 Go to next message
 is currently offline Friend
Hi, I tried to look for answers on the forum on my own, but didn't find what I've looked for - please don't kill me if the question has been already answered.
I have defined following:
AttributeGroup:
( doc = COMMENT )?
'group' name = ID
'from' mainObject = [ Class | QualifiedName ]
'select' attributes += AbstractAttribute (',' attributes += AbstractAttribute)*;
now I define a reference:
AttributeGroupReference:
group = [AttributeGroup]
this is all well, but what I would actually want to do would be to refer the "attributes" feature of the AttributeGroup in moe or less following fashion:
attributes = group.attributes;
the idea is that I would then be able to access the attributes directly from the AttributeGroupReference (I don't really need the AttributeGroup itself even).
Originally I've posted it on stack overflow (if somebody want's to get some fame ...):
http://stackoverflow.com/questions/43810119/xtext-cross-reference-of-a-feature-of-a-reference
Re: Cross Reference without additional feature [message #1761182 is a reply to message #1761176] Mon, 08 May 2017 11:35 Go to previous messageGo to next message
Hi I don't understand you question.
What about sharing sample models as well
Re: Cross Reference without additional feature [message #1761186 is a reply to message #1761182] Mon, 08 May 2017 12:25 Go to previous messageGo to next message
Sorry - don't understand what the sample models are Smile - I'm using xtext as a parser and I'm working on the grammar - the only model I know of is created at runtime when I parse the file with my grammar and I suppose it's not the thing you want from me.
Essentially what I want to do is to make a feature that can be fed either by direct definition of a type or by a cross reference to the type defined elsewhere - or to somehow make in one type a cross reference and then to assig a feature from this reference to a feature in my type .
Re: Cross Reference without additional feature [message #1761187 is a reply to message #1761186] Mon, 08 May 2017 12:34 Go to previous messageGo to next message
yes and in your question you mix grammar and concrete syntax.
so please:
how shall the file look like that the user models
and where shall be the cross references
and where should they point to
Re: Cross Reference without additional feature [message #1761216 is a reply to message #1761176] Tue, 09 May 2017 02:21 Go to previous messageGo to next message
I also don't completely get what you mean. I could imagine that you mean that you want to refer to a list of attributes.
attributes += [AbstractAttribute|QualifiedName]+
This would allow to list a set of attributes with their qualified name, which are prefixed with the AttributeGroup's name. Should work out of the box.
Re: Cross Reference without additional feature [message #1761316 is a reply to message #1761216] Tue, 09 May 2017 12:06 Go to previous messageGo to next message
This would be almost what I need - except is that I want to define this list of attributes in a different place (the AttributeGroup) and be able to use the whole list, not the attributes in the list one by one.
so I have the "AttributeGroup" that has the list of "AbstractAttribute" named "attributes"
and I want the "AttributeGroupReference" to also have the list of "AbstractAttribute" named "attributes" but the contents of this list to be taken from the referenced "AttributeGroup"
Re: Cross Reference without additional feature [message #1761335 is a reply to message #1761316] Tue, 09 May 2017 14:35 Go to previous messageGo to next message
that do you mean by use?
cant you simply follow the reference?
e.g.
doSomeThingWith(AttributeGroupReference ref) {
ref.getGroup().getAttributes()
Re: Cross Reference without additional feature [message #1761346 is a reply to message #1761316] Wed, 10 May 2017 02:09 Go to previous message
I think Christian is right. Since you don't want to list the attributes in the concrete syntax model, you just need to name the AttributeGroup for a cross reference. To get the group's attributes list, just evaluate the collection in the AST.
Previous Topic:Xtext 2.12 and Guava
Next Topic:Compare and merge/mark on Regeneration Xtext-Xtend
Current Time: Thu Jul 31 00:46:39 EDT 2025
Powered by FUDForum. Page generated in 0.05116 seconds
