Home » Archived » Eclipse SmartHome » Rollershutter in Paper UI(Does not work for me; should it?)
Rollershutter in Paper UI [message #1757901] Tue, 21 March 2017 10:53 Go to next message
I have the following problems with the Rollershutter widget in Paper UI (Control view):
- The buttons (up, down, stop) do not result in any commands sent to the thing channel.
- The read-only widget does not seem to show the correct value, at least not with the right formatting
The following features work for me:
- Entering a manual shutter level results in a command to the channel.
- Setting the item type to read-only removes the buttons and sometimes shows the value (without formatting).
Does the Rollershutter widget have the status "final"?
Does anyone of you use it or have any experiences?
Markus
Re: Rollershutter in Paper UI [message #1760962 is a reply to message #1757901] Thu, 04 May 2017 11:26 Go to previous message
Update:
The problems are solved. One was fixed in ESH, the other one was my fault.
For details check out https://github.com/eclipse/smarthome/issues/3257
Previous Topic:Double initialize
Next Topic:[feature suggestion] Add transform on value of item to apply a bias
Current Time: Sat Jul 26 01:20:01 EDT 2025
Powered by FUDForum. Page generated in 0.06600 seconds
