Home » Modeling » GMF (Graphical Modeling Framework) » Problem : Audit constraints
| Problem : Audit constraints [message #175906] |
Thu, 06 March 2008 03:07  |
I'm new with GMF.
I've done the tutorial about mindmap model, and then downloaded the
source of the project. I have a problem when I try to test the audit
constraints.
I built a mindmap diagram with a null named Topic element. When I
validate the model, normally an error should be raised because of the
audit rule "name.size() > 0". However, nothing happens and the
validation completes successfully.
Any ideas ?
Thanks for your help.
Philippe
Configuration :
Eclipse 3.3.1.1
*** Features:
org.eclipse.cvs (1.0.1.R33x_r20070802-7C79_9_KKG-mDM9e3H5D) "Eclipse CVS
Client"
org.eclipse.cvs.source (1.0.1.R33x_r20070802-7C79_9_KKG-mDM9e3H5D)
"Eclipse CVS Client SDK"
org.eclipse.emf (2.3.2.v200802051830) "Eclipse Modeling Framework (EMF)"
org.eclipse.emf.codegen (2.3.1.v200802051830) "EMF Template Code Generator"
org.eclipse.emf.codegen.ecore (2.3.2.v200802051830) "EMF Ecore Code
Generation"
org.eclipse.emf.codegen.ecore.ui (2.3.1.v200802051830) "EMF Ecore Code
Generation UI"
org.eclipse.emf.codegen.ui (2.3.1.v200802051830) "EMF Template Code
Generator UI"
org.eclipse.emf.common (2.3.1.v200802051830) "EMF Common"
org.eclipse.emf.common.ui (2.3.1.v200802051830) "EMF Common UI"
org.eclipse.emf.converter (2.3.1.v200802051830) "EMF Model Convert Support"
org.eclipse.emf.doc (2.3.2.v200802051830) "Eclipse Modeling Framework
(EMF) Programmers Guide"
org.eclipse.emf.ecore (2.3.2.v200802051830) "EMF Ecore"
org.eclipse.emf.ecore.edit (2.3.1.v200802051830) "EMF Ecore Edit Support"
org.eclipse.emf.ecore.editor (2.3.1.v200802051830) "Sample Ecore Editor"
org.eclipse.emf.ecore.sdo (2.3.1.v200802051830) "EMF Service Data
Objects (SDO)"
org.eclipse.emf.ecore.sdo.doc (2.3.2.v200802051830) "EMF Service Data
Objects (SDO) Programmers Guide"
org.eclipse.emf.ecore.sdo.edit (2.3.1.v200802051830) "EMF Service Data
Objects (SDO) Edit Support"
org.eclipse.emf.ecore.sdo.editor (2.3.1.v200802051830) "EMF Service Data
Objects (SDO) Editor"
org.eclipse.emf.ecore.sdo.source (2.3.2.v200802051830) "EMF Service Data
Objects (SDO) Source"
org.eclipse.emf.edit (2.3.2.v200802051830) "EMF Edit"
org.eclipse.emf.edit.ui (2.3.1.v200802051830) "EMF Edit UI"
org.eclipse.emf.examples (2.3.1.v200802051830) "Eclipse Modeling
Framework (EMF) Examples"
org.eclipse.emf.examples.source (2.3.1.v200802051830) "Eclipse Modeling
org.eclipse.emf.mapping (2.3.1.v200802051830) "EMF Mapping "
org.eclipse.emf.mapping.ecore (2.3.1.v200802051830) "Eclipse Modeling
Framework (EMF) - org.eclipse.emf.mapping.ecore"
org.eclipse.emf.mapping.ecore.editor (2.3.1.v200802051830) "Eclipse
Modeling Framework (EMF) - org.eclipse.emf.mapping.ecore.editor"
org.eclipse.emf.mapping.ui (2.3.1.v200802051830) "EMF Mapping UI"
org.eclipse.emf.ocl (1.1.1.v200709121956-1007w31181_232_67) "Object
Constraint Language (OCL) 2.0 Compatibility API"
org.eclipse.emf.ocl.doc (1.1.0.v200706071450-10-7w311817182561) "Object
Constraint Language (OCL) 2.0 Compatibility API Documentation"
org.eclipse.emf.ocl.examples (1.1.0.v200706071450-32-9oA55P5M5P8GJ5)
"Object Constraint Language (OCL) 2.0 Examples"
org.eclipse.emf.ocl.examples.source (1.1.0.v200706071450) "Object
Constraint Language (OCL) 2.0 Examples Source"
org.eclipse.emf.ocl.source (1.1.1.v200709121956-1007w31181_232_67)
"Object Constraint Language (OCL) 2.0 Compatibility Source"
org.eclipse.emf.query (1.1.1.v200711281714-1007w311822392825) "EMF Model
Query"
org.eclipse.emf.query.doc (1.1.0.v200706071712-21-8s733G3E4C5B76) "EMF
Model Query Documentation"
org.eclipse.emf.query.examples (1.1.0.v200706071712-428Y_kE77Y7U9QAOEC)
"EMF Model Query Examples"
org.eclipse.emf.query.examples.source (1.1.0.v200706071712) "EMF Model
Query Examples Source"
org.eclipse.emf.query.ocl (1.1.0.v200706071712-10-7w311817182823) "EMF
Model Query OCL Integration"
org.eclipse.emf.query.ocl.source (1.1.0.v200706071712-10-7w311817182823)
"EMF Model Query OCL Integration Source"
org.eclipse.emf.query.source (1.1.1.v200711281714-1007w311822392825)
"EMF Model Query Source"
org.eclipse.emf.source (2.3.2.v200802051830) "Eclipse Modeling Framework
(EMF) Source"
org.eclipse.emf.transaction (1.1.2.v200710151610-208a8s733G4A3F5H88)
"EMF Model Transaction Core"
org.eclipse.emf.transaction.doc (1.1.0.v200706071723-208Y8s733G3E3G5G79)
"EMF Model Transaction Documentation"
org.eclipse.emf.transaction.examples
(1.0.100.v200706071723-3-Ag8x8FlRtR_NWNVFQ9QBE) "EMF Model Transaction
Examples"
org.eclipse.emf.transaction.examples.source (1.0.100.v200706071723) "EMF
Model Transaction Examples Source"
org.eclipse.emf.transaction.source
(1.1.2.v200710151610-208a8s733G4A3F5H88) "EMF Model Transaction Source"
org.eclipse.emf.validation (1.1.1.v200708161445-318Z9oA55P5O6O8IC_) "EMF
Validation Framework Core"
org.eclipse.emf.validation.doc (1.1.0.v200706071520-21-8s733G3E4C5_88)
"EMF Validation Framework Documentation"
org.eclipse.emf.validation.examples
(1.1.0.v200706071520-52_7AgI99h9cAZDRKI) "EMF Validation Framework Example"
org.eclipse.emf.validation.examples.source (1.1.0.v200706071520) "EMF
Validation Framework Examples Source"
org.eclipse.emf.validation.ocl (1.1.0.v200706071520-10-7w311817182631)
"EMF Validation Framework OCL Integration"
org.eclipse.emf.validation.ocl.source
(1.1.0.v200706071520-10-7w311817182631) "EMF Validation Framework OCL
Integration Source"
org.eclipse.emf.validation.source
(1.1.1.v200708161445-318Z9oA55P5O6O8IC_) "EMF Validation Framework Source"
org.eclipse.emf.workspace (1.1.2.v200711281719-208a8s733G4A3F5H88) "EMF
Model Transaction Workbench Integration Core"
org.eclipse.emf.workspace.doc (1.1.0.v200706071723-10-7w311817182834)
"EMF Model Transaction Workbench Integration Documentation"
org.eclipse.emf.workspace.examples
(1.0.100.v200706071723-3-Ag9oA55P5M5P8PAD) "EMF Model Transaction
Workbench Integration Examples"
org.eclipse.emf.workspace.examples.source (1.0.100.v200706071723) "EMF
Model Transaction Workbench Integration Examples Source"
org.eclipse.emf.workspace.source
(1.1.2.v200711281719-208a8s733G4A3F5H88) "EMF Model Transaction
Workbench Integration Source"
org.eclipse.eodm (0.9.1.v200710090302) "pluginName (Incubation)"
org.eclipse.eodm.doc (0.9.1.v200710090302) "Plugin.name (Incubation)"
org.eclipse.eodm.source (0.9.1.v200710090302) "EODM Source"
org.eclipse.gef (3.3.1.v20070814) "Graphical Editing Framework"
org.eclipse.gef.sdk (3.3.1.v20070814) "Graphical Editing Framework
Developer Resources"
org.eclipse.gef.source (3.3.1.v20070814) "Graphical Editing Framework
org.eclipse.gmf (1.0.101.v20080114-2222-7d-EVOEYjiMWaZ4YWeu3dCypkm71)
"Graphical Modeling Framework"
org.eclipse.gmf.doc (1.1.0.v20070809-0000-10-7w3119122503333) "Graphical
Modeling Framework Documentation"
org.eclipse.gmf.examples.pde (1.1.0.v20070809-0000-2-8Y8s733G3I3K13333)
"Graphical Modeling Framework Examples"
org.eclipse.gmf.sdk (2.0.1.v20070921-0000-7f79CSEMnY9yMVlrV-40M7vY1p8w)
"Graphical Modeling Framework SDK"
org.eclipse.gmf.sdk.source (2.0.1.v20070921-0000) "Graphical Modeling
Framework SDK Developer Resources"
org.eclipse.gmf.source
(1.0.101.v20080114-2222-7d-EVOEYjiMWaZ4YWeu3dCypkm71) "Graphical
Modeling Framework Runtime Developer Resources"
org.eclipse.jdt (3.3.1.r331_v20070629-7o7jE72EDlXAbqAcnbmyg1rf8RIL)
"Eclipse Java Development Tools"
org.eclipse.jdt.source
(3.3.1.r331_v20070629-7o7jE72EDlXAbqAcnbmyg1rf8RIL) "Eclipse Java
Development Tools SDK"
org.eclipse.jet (0.8.1.v20070913-17E19oA55P5V_8) "Eclipse Modeling
Framework Technologies - JET (Incubation)"
org.eclipse.jet.doc (0.8.0.v20070913-07707w31181_31) "Eclipse Modeling
Framework Technologies - JET Documentation (Incubation)"
org.eclipse.jet.examples (0.8.0.v20070913-077-7w31181_24) "Eclipse
Modeling Framework Technologies - JET Examples (Incubation)"
org.eclipse.jet.source (0.8.1.v20070913) "Eclipse Model to Text - JET SDK"
org.eclipse.mylyn_feature (2.1.0.v20070927-0900) "Mylyn"
org.eclipse.mylyn.bugzilla_feature (2.1.0.v20070927-0900) "Mylyn"
org.eclipse.mylyn.context_feature (2.1.0.v20070927-0900) "Mylyn"
org.eclipse.mylyn.ide_feature (2.1.0.v20070927-0900) "Mylyn"
org.eclipse.mylyn.java_feature (2.1.0.v20070927-0900) "Mylyn"
org.eclipse.mylyn.pde_feature (2.1.0.v20070927-0900) "Mylyn"
org.eclipse.ocl (1.1.1.v200707131415-3209oA55P5N7F8JDH) "Object
Constraint Language (OCL) 2.0 Parser/Interpreter"
org.eclipse.ocl.doc (1.1.0.v200706071450-21-8s733G3E3G5AC3) "Object
Constraint Language (OCL) 2.0 Documentation"
org.eclipse.ocl.source (1.1.1.v200707131415-3209oA55P5N7F8JDH) "Object
Constraint Language (OCL) 2.0 Source"
org.eclipse.ocl.uml (1.1.1.v200707131415-1007w311818242526) "OCL 2.0
Binding for UML"
org.eclipse.ocl.uml.source (1.1.1.v200707131415-1007w311818242526) "OCL
2.0 Binding for UML Source"
org.eclipse.pde (3.3.2.R33x_r20071022-7N7M4CYWLBCz-yHkMIuHN) "Eclipse
Plug-in Development Environment"
org.eclipse.pde.source (3.3.2.R33x_r20071022-7N7M4CYWLBCz-yHkMIuHN)
"Eclipse Plug-in Development Environment Developer Resources"
org.eclipse.platform (3.3.2.R33x_v20071022-_19UEksF-G8Yc6bUv3Dz)
"Eclipse Platform"
org.eclipse.platform.source (3.3.2.R33x_v20071022-_19UEksF-G8Yc6bUv3Dz)
"Eclipse Platform Plug-in Developer Resources"
org.eclipse.rcp (3.3.2.R33x_r20071022-8y8eE9CEV3FspP8HJrY1M2dS) "Eclipse
RCP"
org.eclipse.rcp.source (3.3.2.R33x_r20071022-8y8eE9CEV3FspP8HJrY1M2dS)
"Eclipse RCP Plug-in Developer Resources"
org.eclipse.sdk (3.3.2.R33x_r20071022-7M7J7C_Mu2gop0b_GAwplOBhyuKO)
"Eclipse Project SDK"
org.eclipse.uml2 (2.1.1.v200708301222) "UML2"
org.eclipse.uml2.diagram (0.7.101.v200802260712) "UML2 Diagramming
Plug-in (Incubation)"
org.eclipse.uml2.diagram.source (0.7.101.v200802260712) "UML2
Diagramming Source"
org.eclipse.uml2.doc (2.1.1.v200707181556) "UML2 Documentation"
org.eclipse.uml2.examples (2.1.0.v200706251652) "UML2 Examples"
org.eclipse.uml2.examples.source (2.1.0.v200706251652) "UML2 Examples
Source"
org.eclipse.uml2.source (2.1.1.v200708301222) "UML2 Source"
org.eclipse.uml2tools (0.7.101.v200802260712) "UML2 Tools Plug-in
(Incubation)"
org.eclipse.uml2tools.doc (0.7.0.v200802260712) "UML2 Tools
Documentation Plug-in"
org.eclipse.xsd (2.3.2.v200802051830) "XML Schema Infoset Model (XSD)"
org.eclipse.xsd.doc (2.3.2.v200802051830) "XML Schema Infoset Model
(XSD) Programmers Guide"
org.eclipse.xsd.ecore.converter (2.3.2.v200802051830) "XML Schema
Infoset Model (XSD) - org.eclipse.xsd.ecore.converter"
org.eclipse.xsd.edit (2.3.0.v200802051830) "XML Schema Edit Framework"
org.eclipse.xsd.editor (2.3.0.v200802051830) "XML Schema Editor"
org.eclipse.xsd.mapping (2.3.0.v200802051830) "XML Schema Infoset Model
(XSD) - org.eclipse.xsd.mapping"
org.eclipse.xsd.mapping.editor (2.3.0.v200802051830) "XML Schema Infoset
Model (XSD) - org.eclipse.xsd.mapping.editor"
org.eclipse.xsd.source (2.3.2.v200802051830) "XML Schema Infoset Model
(XSD) Source"
org.topcased.modeler.sam (1.3.0.v200802191607) "SAM Editor"
*** Plug-in Registry:
com.ibm.icu (3.6.1.v20070906) "International Components for Unicode for
Java (ICU4J)" [Active]
com.ibm.icu.source (3.6.1.v20070906) "International Components for
Unicode for Java (ICU4J) source plug-in" [Resolved]
com.jcraft.jsch (0.1.31) "JSch" [Resolved]
javax.servlet (2.4.0.v200706111738) "Servlet API Bundle" [Resolved]
javax.servlet.jsp (2.0.0.v200706191603) "Java Server Pages API Bundle"
[Resolved]
javax.servlet.jsp.source (2.0.0.v200706191603) "Java Server Pages API
Source Bundle" [Resolved]
javax.servlet.source (2.4.0.v200706111738) "Servlet API Source Bundle"
[Resolved]
net.sourceforge.lpg.lpgjavaruntime (1.1.0.v200706111738) "SourceForge
LPG" [Resolved]
net.sourceforge.lpg.lpgjavaruntime.source (1.1.0.v200706111738)
"SourceForge LPG Source Bundle" [Resolved]
org.apache.ant (1.7.0.v200706080842) "Apache Ant" [Resolved]
org.apache.ant.source (1.7.0.v200706080842) "Apache Ant Source" [Resolved]
org.apache.batik.bridge (1.6.0.v200706111724) "Apache Batik
Bridge/GVT/Scripting" [Resolved]
org.apache.batik.bridge.source (1.6.0.v200706111724) "Apache Batik
Bridge/GVT/Scripting Source Bundle" [Resolved]
org.apache.batik.css (1.6.0.v200706111724) "Apache Batik CSS" [Resolved]
org.apache.batik.css.source (1.6.0.v200706111724) "Apache Batik CSS
org.apache.batik.dom (1.6.0.v200706111724) "Apache Batik DOM" [Resolved]
org.apache.batik.dom.source (1.6.0.v200706111724) "Apache Batik DOM
org.apache.batik.dom.svg (1.6.0.v200706111724) "Apache Batik SVG DOM"
[Resolved]
org.apache.batik.dom.svg.source (1.6.0.v200706111724) "Apache Batik SVG
DOM Source Bundle" [Resolved]
org.apache.batik.ext.awt (1.6.0.v200706111724) "Apache Batik AWT
Utilities" [Resolved]
org.apache.batik.ext.awt.source (1.6.0.v200706111724) "Apache Batik AWT
Utilities Source Bundle" [Resolved]
org.apache.batik.parser (1.6.0.v200706111724) "Apache Batik Parser"
[Resolved]
org.apache.batik.parser.source (1.6.0.v200706111724) "Apache Batik
Parser Source Bundle" [Resolved]
org.apache.batik.svggen (1.6.0.v200706111724) "Apache Batik SVG
Generation" [Resolved]
org.apache.batik.svggen.source (1.6.0.v200706111724) "Apache Batik SVG
Generation Source Bundle" [Resolved]
org.apache.batik.transcoder (1.6.0.v200706111724) "Apache Batik
Transcoder" [Resolved]
org.apache.batik.transcoder.source (1.6.0.v200706111724) "Apache Batik
Transcoder Source Bundle" [Resolved]
org.apache.batik.util (1.6.0.v200706111724) "Apache Batik Utilities"
[Resolved]
org.apache.batik.util.gui (1.6.0.v200706111724) "Apache Batik GUI
org.apache.batik.util.gui.source (1.6.0.v200706111724) "Apache Batik GUI
org.apache.batik.util.source (1.6.0.v200706111724) "Apache Batik
org.apache.batik.xml (1.6.0.v200706111724) "Apache Batik XML" [Resolved]
org.apache.batik.xml.source (1.6.0.v200706111724) "Apache Batik XML
org.apache.commons.el (1.0.0.v200706111724) "Apache Commons JSP 2.0
Expression Language Interpreter" [Resolved]
org.apache.commons.el.source (1.0.0.v200706111724) "Apache Commons JSP
2.0 Expression Language Interpreter Source" [Resolved]
org.apache.commons.logging (1.0.4.v200706111724) "Apache Commons Logging
Plug-in" [Resolved]
org.apache.commons.logging.source (1.0.4.v200706111724) "Apache Commons
Logging Plug-in Source" [Resolved]
org.apache.jasper (5.5.17.v200706111724) "Apache Jasper 2 Plug-in"
[Resolved]
org.apache.jasper.source (5.5.17.v200706111724) "Apache Jasper 2 Source
Plug-in" [Resolved]
org.apache.lucene (1.9.1.v200706111724) "Apache Lucene" [Resolved]
org.apache.lucene.analysis (1.9.1.v200706181610) "Apache Lucene
Analysis" [Resolved]
org.apache.lucene.analysis.source (1.9.1.v200706181610) "Apache Lucene
Analysis Source" [Resolved]
org.apache.lucene.source (1.9.1.v200706111724) "Apache Lucene Source"
[Resolved]
org.apache.xerces (2.8.0.v200705301630) "Apache Xerces-J" [Resolved]
org.apache.xml.resolver (1.1.0.v200705310020) "Apache XmlResolver"
[Resolved]
org.eclipse.ant.core (3.1.200.v20070522) "Ant Build Tool Core" [Starting]
org.eclipse.ant.ui (3.2.200.v20070825_r331) "Ant UI" [Active]
org.eclipse.compare (3.3.1.r33x_20070906) "Compare Support" [Active]
org.eclipse.core.boot (3.1.100.v20060603) "Core Boot" [Starting]
org.eclipse.core.commands (3.3.0.I20070605-0010) "Commands" [Resolved]
org.eclipse.core.contenttype (3.2.100.v20070319) "Eclipse Content
Mechanism" [Active]
org.eclipse.core.databinding (1.0.1.M20070822-0800) "JFace Data Binding"
[Resolved]
org.eclipse.core.databinding.beans (1.0.1.M20070910-0800b) "JFace Data
Binding for JavaBeans" [Resolved]
org.eclipse.core.expressions (3.3.0.v20070606-0010) "Expression
Language" [Active]
org.eclipse.core.filebuffers (3.3.1.r331_v20070829) "File Buffers" [Active]
org.eclipse.core.filesystem (1.1.0.v20070606) "Core File Systems" [Active]
org.eclipse.core.filesystem.win32.x86 (1.1.0.v20070510) "Core File
System for Windows" [Resolved]
org.eclipse.core.jobs (3.3.1.R33x_v20070709) "Eclipse Jobs Mechanism"
[Active]
org.eclipse.core.net (1.0.1.r33x_20070709) "Internet Connection
Management" [Active]
org.eclipse.core.resources (3.3.0.v20070604) "Core Resource Management"
[Active]
org.eclipse.core.resources.compatibility (3.2.100.v20070502) "Core
Resource Management Compatibility Fragment" [Resolved]
org.eclipse.core.resources.win32 (3.3.0.v20070226) "Core Resource
Management Win32 Fragment" [Resolved]
org.eclipse.core.runtime (3.3.100.v20070530) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.1.200.v20070502) "Core Runtime
Plug-in Compatibility" [Active]
org.eclipse.core.runtime.compatibility.auth (3.2.100.v20070502)
"Authorization Compatibility Plug-in" [Active]
org.eclipse.core.runtime.compatibility.registry (3.2.100.v20070316)
"Eclipse Registry Compatibility Fragment" [Resolved]
org.eclipse.core.variables (3.2.0.v20070426) "Core Variables" [Starting]
org.eclipse.cvs (1.0.0.v20070606) "Eclipse CVS Client" [Starting]
"Eclipse CVS Client SDK" [Resolved]
org.eclipse.debug.core (3.3.1.v20070731_r331) "Debug Core" [Active]
org.eclipse.debug.ui (3.3.1.v20070731_r331) "Debug UI" [Active]
org.eclipse.draw2d (3.2.100.v20070529) "Graphical Editing Framework
Draw2d" [Active]
org.eclipse.draw2d.doc.isv (3.2.100.v20070529) "Graphical Editing
Framework Draw2d Documentation" [Starting]
org.eclipse.emf (2.3.0.v200802051830) "Eclipse Modeling Framework (EMF)"
[Starting]
org.eclipse.emf.activities (2.3.0.v200802051830) "EMF Activities" [Starting]
org.eclipse.emf.ant (2.3.1.v200802051830) "EMF Ant Tasks" [Starting]
org.eclipse.emf.cheatsheets (2.3.0.v200802051830) "EMF Cheat Sheets"
[Starting]
Generator" [Starting]
Generation" [Starting]
org.eclipse.emf.codegen.ecore.ui (2.3.0.v200802051830) "EMF Ecore Code
Generation UI" [Starting]
org.eclipse.emf.codegen.ui (2.3.0.v200802051830) "EMF Template Code
Generator UI" [Starting]
org.eclipse.emf.common (2.3.2.v200802051830) "EMF Common" [Active]
org.eclipse.emf.common.ui (2.3.1.v200802051830) "EMF Common UI" [Active]
org.eclipse.emf.commonj.sdo (2.3.0.v200802051830) "CommonJ SDO" [Starting]
org.eclipse.emf.converter (2.3.0.v200802051830) "EMF Model Convert
Support" [Starting]
(EMF) Programmers Guide" [Starting]
org.eclipse.emf.ecore (2.3.2.v200802051830) "EMF Ecore" [Active]
org.eclipse.emf.ecore.change (2.3.0.v200802051830) "EMF Ecore Change
Model" [Active]
org.eclipse.emf.ecore.change.edit (2.3.0.v200802051830) "EMF Ecore
Change Edit Support" [Starting]
Support" [Active]
[Starting]
org.eclipse.emf.ecore.sdo (2.3.0.v200802051830) "EMF Service Data
Objects (SDO)" [Starting]
org.eclipse.emf.ecore.sdo.doc (2.3.1.v200802051830) "EMF Service Data
Objects (SDO) Programmers Guide" [Starting]
org.eclipse.emf.ecore.sdo.edit (2.3.0.v200802051830) "EMF Service Data
Objects (SDO) Edit Support" [Starting]
org.eclipse.emf.ecore.sdo.editor (2.3.0.v200802051830) "EMF Service Data
Objects (SDO) Editor" [Starting]
Objects (SDO) Source" [Resolved]
org.eclipse.emf.ecore.xmi (2.3.2.v200802051830) "EMF XMI" [Active]
org.eclipse.emf.edit (2.3.2.v200802051830) "EMF Edit" [Active]
org.eclipse.emf.edit.ui (2.3.1.v200802051830) "EMF Edit UI" [Active]
org.eclipse.emf.examples (2.3.0.v200802051830) "Eclipse Modeling
Framework (EMF) Examples" [Starting]
org.eclipse.emf.examples.generator.validator (1.0.0.v200802051830)
"Validator Generator Extension" [Starting]
org.eclipse.emf.examples.library (2.3.0.v200802051830) "Extended Library
Model" [Active]
org.eclipse.emf.examples.library.edit (2.3.0.v200802051830) "Extended
Library Edit" [Starting]
org.eclipse.emf.examples.library.editor (2.3.0.v200802051830) "Extended
Library Editor" [Starting]
Framework (EMF) Examples" [Resolved]
org.eclipse.emf.exporter (2.3.0.v200802051830) "EMF Model Export
Support" [Starting]
org.eclipse.emf.exporter.html (2.3.0.v200802051830) "HTML Exporter for
EMF models" [Starting]
org.eclipse.emf.importer (2.3.1.v200802051830) "EMF Model Import
Support" [Starting]
org.eclipse.emf.importer.ecore (2.3.1.v200802051830) "EMF Ecore
Importer" [Starting]
org.eclipse.emf.importer.java (2.3.1.v200802051830) "EMF Annotated Java
org.eclipse.emf.importer.rose (2.3.1.v200802051830) "EMF Rose Importer"
[Starting]
org.eclipse.emf.java (2.3.0.v200802051830) "EMF Java" [Starting]
org.eclipse.emf.java.edit (2.3.0.v200802051830) "EMF Java Edit" [Starting]
org.eclipse.emf.java.editor (2.3.0.v200802051830) "EMF Java Editor"
[Starting]
org.eclipse.emf.mapping (2.3.0.v200802051830) "EMF Mapping" [Starting]
org.eclipse.emf.mapping.ecore (2.3.0.v200802051830) "Eclipse Modeling
Framework (EMF) - org.eclipse.emf.mapping.ecore" [Starting]
org.eclipse.emf.mapping.ecore.editor (2.3.0.v200802051830) "Eclipse
Modeling Framework (EMF) - org.eclipse.emf.mapping.ecore.editor" [Starting]
org.eclipse.emf.mapping.ecore2ecore (2.3.0.v200802051830) "Ecore to
Ecore Mapping" [Starting]
org.eclipse.emf.mapping.ecore2ecore.editor (2.3.0.v200802051830) "Ecore
to Ecore Mapping Editor" [Starting]
org.eclipse.emf.mapping.ecore2xml (2.3.0.v200802051830) "Ecore to XML
Mapping" [Starting]
org.eclipse.emf.mapping.ecore2xml.ui (2.3.0.v200802051830) "Ecore to XML
Mapping UI" [Starting]
org.eclipse.emf.mapping.ui (2.3.0.v200802051830) "EMF Mapping UI" [Starting]
org.eclipse.emf.mapping.xsd2ecore (2.3.0.v200802051830) "XSD to Ecore
Mapping" [Starting]
org.eclipse.emf.mapping.xsd2ecore.editor (2.3.0.v200802051830) "XSD to
org.eclipse.emf.ocl (1.1.1.v200709121956) "Object Constraint Language
(OCL) 2.0 Compatibility API" [Starting]
org.eclipse.emf.ocl.doc (1.1.0.v200706071450) "Object Constraint
Language (OCL) 2.0 Compatibility API Documentation" [Starting]
org.eclipse.emf.ocl.examples (1.1.0.v200706071450) "Object Constraint
Language (OCL) 2.0 Examples" [Starting]
org.eclipse.emf.ocl.examples.interpreter (1.1.0.v200706071450) "Object
Constraint Language (OCL) 2.0 Interpreter Example" [Starting]
Constraint Language (OCL) 2.0 Examples Source" [Resolved]
"Object Constraint Language (OCL) 2.0 Compatibility Source" [Resolved]
org.eclipse.emf.query (1.1.1.v200711281714) "EMF Model Query" [Starting]
org.eclipse.emf.query.doc (1.1.0.v200706071712) "EMF Model Query
org.eclipse.emf.query.examples (1.1.0.v200706131231) "EMF Model Query
org.eclipse.emf.query.examples.ocl (1.1.0.v200706071712) "EMF Model
Query OCL Query Example" [Starting]
Query Examples Source" [Resolved]
org.eclipse.emf.query.examples.statements (1.0.100.v200706131231) "EMF
Model Query Example" [Starting]
org.eclipse.emf.query.ocl (1.1.0.v200706071712) "EMF Model Query OCL
Integration" [Starting]
"EMF Model Query OCL Integration Source" [Resolved]
"EMF Model Query Source" [Resolved]
(EMF) Source" [Resolved]
org.eclipse.emf.transaction (1.1.2.v200712061832) "EMF Model Transaction
Core" [Active]
org.eclipse.emf.transaction.doc (1.1.0.v200706071723) "EMF Model
Transaction Documentation" [Starting]
org.eclipse.emf.transaction.examples (1.0.100.v200706071723) "EMF Model
Transaction Examples" [Starting]
Model Transaction Examples Source" [Resolved]
[Resolved]
org.eclipse.emf.transaction.ui (1.0.100.v200706071723) "EMF Model
Transaction UI" [Starting]
org.eclipse.emf.validation (1.1.1.v200708161445) "EMF Validation
Framework Core" [Active]
org.eclipse.emf.validation.doc (1.1.0.v200706071520) "EMF Validation
Framework Documentation" [Starting]
org.eclipse.emf.validation.examples (1.1.0.v200706131235) "EMF
Validation Framework Example" [Starting]
org.eclipse.emf.validation.examples.adapter (1.0.100.v200706071520) "EMF
Validation Framework Adapter Example" [Active]
org.eclipse.emf.validation.examples.general (1.0.100.v200706071520) "EMF
Validation Framework Example" [Active]
org.eclipse.emf.validation.examples.ocl (1.1.0.v200706131235) "EMF
Validation Framework OCL Constraints Example" [Starting]
Validation Framework Examples Source" [Resolved]
org.eclipse.emf.validation.ocl (1.1.0.v200706071520) "EMF Validation
Framework OCL Integration" [Resolved]
Source" [Resolved]
org.eclipse.emf.validation.ui (1.1.0.v200706071520) "EMF Validation
Framework UI" [Active]
org.eclipse.emf.validation.ui.ide (1.0.100.v200706071520) "EMF
Validation Framework UI IDE" [Starting]
org.eclipse.emf.workspace (1.1.2.v200712061832) "EMF Model Transaction
Workbench Integration Core" [Active]
org.eclipse.emf.workspace.doc (1.1.0.v200706071723) "EMF Model
Transaction Workbench Integration Documentation" [Starting]
org.eclipse.emf.workspace.examples (1.0.100.v200706071723) "EMF Model
Transaction Workbench Integration Examples" [Starting]
org.eclipse.emf.workspace.examples.library.editor
(1.0.100.v200706071723) "EMF Workbench EXTLibrary Editor" [Starting]
Model Transaction Workbench Integration Examples Source" [Resolved]
Workbench Integration Source" [Resolved]
org.eclipse.emf.workspace.ui (1.0.100.v200706071723) "EMF Model
Transaction Workbench Integration UI" [Starting]
org.eclipse.eodm (0.9.1.v200710090302) "pluginName (Incubation)" [Starting]
[Starting]
org.eclipse.eodm.owl (0.9.1.v200710090302) "pluginName (Incubation)"
[Starting]
org.eclipse.eodm.rdf (0.9.1.v200710090302) "pluginName (Incubation)"
[Starting]
org.eclipse.eodm.source (0.9.1.v200710090302) "EODM Source" [Resolved]
org.eclipse.equinox.app (1.0.1.R33x_v20070828) "Equinox Application
Container" [Active]
org.eclipse.equinox.common (3.3.0.v20070426) "Common Eclipse Runtime"
[Active]
org.eclipse.equinox.http.jetty (1.0.1.R33x_v20070816) "Jetty Http
Service" [Starting]
org.eclipse.equinox.http.registry (1.0.0.v20070608) "Http Service
Registry Extensions" [Resolved]
org.eclipse.equinox.http.servlet (1.0.1.R33x_v20070816) "Http Services
Servlet" [Starting]
org.eclipse.equinox.jsp.jasper (1.0.1.R33x_v20070816) "Jasper Jsp
Support Bundle" [Starting]
org.eclipse.equinox.jsp.jasper.registry (1.0.0.v20070607) "Jasper Jsp
Registry Support Plug-in" [Starting]
org.eclipse.equinox.launcher (1.0.1.R33x_v20070828) "Equinox Launcher"
[Resolved]
org.eclipse.equinox.launcher.win32.win32.x86 (1.0.2.R331_v20071019)
"Equinox Launcher Win32 X86 Fragment" [Resolved]
org.eclipse.equinox.preferences (3.2.100.v20070522) "Eclipse Preferences
Mechanism" [Active]
org.eclipse.equinox.registry (3.3.1.R33x_v20070802) "Extension Registry
Support" [Active]
org.eclipse.gef (3.2.101.v20070814) "Graphical Editing Framework" [Active]
org.eclipse.gef.doc.isv (3.2.100.v20070529) "Graphical Editing Framework
org.eclipse.gef.examples.ui.pde (3.3.0.v20070529) "Graphical Editing
Framework Example Plug-ins" [Starting]
Developer Resources" [Resolved]
org.eclipse.gmf (1.0.0.v20070809-0000) "Graphical Modeling Framework"
[Starting]
org.eclipse.gmf.bridge (1.1.0.v20070809-0000) "GMF Models Bridging
Plug-in" [Starting]
org.eclipse.gmf.bridge.trace (1.0.100.v20070809-0000) "GMF Models Bridge
Tracing Plug-in" [Starting]
org.eclipse.gmf.bridge.ui (1.1.1.v20080207-0207) "GMF Tooling UI" [Starting]
org.eclipse.gmf.bridge.ui.dashboard (2.0.0.v20070809-0000) "GMF
Dashboard" [Starting]
org.eclipse.gmf.codegen (2.0.2.v20080207-0207) "GMF GenModel and Code
org.eclipse.gmf.codegen.edit (2.0.1.v20071124-0000) "GMF GenModel Edit
Support" [Starting]
org.eclipse.gmf.codegen.lite (1.1.1.v20070921-0000) "GMF Pure-GEF Code
Generation Plug-in" [Starting]
org.eclipse.gmf.codegen.lite.ui (1.1.0.v20070809-0000) "GMF Pure-GEF
Code Generation UI" [Starting]
org.eclipse.gmf.codegen.ui (1.1.0.v20070809-0000) "GMF Code Generation
UI" [Starting]
org.eclipse.gmf.common (1.1.0.v20070809-0000) "GMF Tooling Commons
Plug-in" [Active]
org.eclipse.gmf.doc (1.1.0.v20080114-2222) "Graphical Modeling Framework
org.eclipse.gmf.doc.ui (1.1.0.v20070809-0000) "GMF Documentation
Cheatsheets" [Starting]
org.eclipse.gmf.ecore.editor (2.0.2.v20080207-0207) "ECore Sample
Diagram Plugin" [Active]
org.eclipse.gmf.examples (1.0.0.v20070809-0000) "Graphical Modeling
Framework Examples" [Resolved]
org.eclipse.gmf.examples.mindmap (1.0.0) "Mindmap Model" [Active]
org.eclipse.gmf.examples.mindmap.diagram (1.0.0.200803051538) "Mindmap
Plugin" [Active]
org.eclipse.gmf.examples.mindmap.diagram.custom (1.0.0.200803051506)
"pluginName" [Resolved]
org.eclipse.gmf.examples.mindmap.edit (1.0.0) "Mindmap Edit Support"
[Active]
org.eclipse.gmf.examples.mindmap.editor (1.0.0) "Mindmap Editor" [Active]
org.eclipse.gmf.examples.ui.pde (1.0.100.v20070809-0000) "GMF Examples
Plug-in" [Starting]
org.eclipse.gmf.graphdef (2.0.1.v20080207-0207) "GMF Graphical
Definition" [Resolved]
org.eclipse.gmf.graphdef.codegen (2.0.1.v20080207-0207) "Graphical
Definition Code Generator" [Starting]
org.eclipse.gmf.graphdef.codegen.ui (1.0.100.v20070809-0000) "Graphical
Definition Code Generator UI Support" [Resolved]
org.eclipse.gmf.graphdef.edit (2.0.1.v20080207-0207) "GMFGraph Edit
Support" [Active]
org.eclipse.gmf.graphdef.editor (1.0.0.v20070809-0000) "gmfgraph Plugin"
[Active]
org.eclipse.gmf.map (2.0.0.v20070809-0000) "GMF Mapping Model" [Active]
org.eclipse.gmf.map.edit (2.0.0.v20070809-0000) "GMF Mapping Edit
Support" [Active]
org.eclipse.gmf.map.editor (1.0.0.v20070809-0000) "GMF Mapping Diagram
Plugin" [Active]
org.eclipse.gmf.runtime.common.core (1.0.101.v20080118-1415) "GMF Common
Core" [Active]
org.eclipse.gmf.runtime.common.ui (1.0.101.v20070921-0000) "GMF Common
UI" [Active]
org.eclipse.gmf.runtime.common.ui.action (1.0.100.v20070809-0000) "GMF
Common UI Action" [Active]
org.eclipse.gmf.runtime.common.ui.action.ide (1.0.1.v20070809-0000) "GMF
Common UI Action IDE" [Active]
org.eclipse.gmf.runtime.common.ui.printing (1.0.1.v20070809-0000) "GMF
Printing" [Starting]
org.eclipse.gmf.runtime.common.ui.printing.win32 (1.0.2.v20070809-0000)
"GMF Printing for Win32" [Resolved]
org.eclipse.gmf.runtime.common.ui.services (1.0.100.v20070809-0000) "GMF
Common UI Services" [Active]
org.eclipse.gmf.runtime.common.ui.services.action
(1.0.100.v20070809-0000) "GMF Common UI Action Services" [Active]
org.eclipse.gmf.runtime.common.ui.services.dnd (1.0.1.v20070809-0000)
"GMF Common UI DND Services" [Starting]
org.eclipse.gmf.runtime.common.ui.services.dnd.ide
(1.0.1.v20070809-0000) "GMF Common UI DND IDE Services" [Starting]
org.eclipse.gmf.runtime.common.ui.services.properties
(1.0.2.v20071124-0000) "GMF Common UI Properties Service Framework" [Active]
org.eclipse.gmf.runtime.diagram.core (1.0.101.v20070915-0000) "GMF
Diagram Core" [Active]
org.eclipse.gmf.runtime.diagram.ui (1.0.102.v20080201-0201) "GMF Diagram
UI" [Active]
org.eclipse.gmf.runtime.diagram.ui.actions (1.0.101.v20080118-1129) "GMF
Diagram Actions" [Active]
org.eclipse.gmf.runtime.diagram.ui.dnd (1.0.1.v20070809-0000) "GMF
Diagram Browse" [Starting]
org.eclipse.gmf.runtime.diagram.ui.geoshapes (1.0.1.v20070809-0000) "GMF
Geometric Shapes" [Active]
org.eclipse.gmf.runtime.diagram.ui.printing (1.0.100.v20070809-0000)
"GMF Diagram Printing" [Starting]
org.eclipse.gmf.runtime.diagram.ui.printing.render
(1.0.1.v20070809-0000) "GMF Diagram UI Printing Render Plug-In" [Starting]
org.eclipse.gmf.runtime.diagram.ui.properties (1.0.102.v20080118-1129)
"GMF Diagram UI Properties" [Active]
org.eclipse.gmf.runtime.diagram.ui.providers (1.0.101.v20080201-0201)
"GMF Diagram Providers" [Active]
org.eclipse.gmf.runtime.diagram.ui.providers.ide (1.0.1.v20070809-0000)
"GMF Diagram Providers IDE" [Active]
org.eclipse.gmf.runtime.diagram.ui.render (1.0.101.v20071124-0000) "GMF
Diagram UI Render Plug-In" [Active]
org.eclipse.gmf.runtime.diagram.ui.resources.editor
(1.0.3.v20070809-0000) "GMF Diagram UI Resources Editor Plug-In" [Active]
org.eclipse.gmf.runtime.diagram.ui.resources.editor.ide
(1.0.3.v20070809-0000) "GMF IDE Editor" [Starting]
org.eclipse.gmf.runtime.draw2d.ui (1.0.101.v20080215-1200) "GMF Draw2d
Additions" [Active]
org.eclipse.gmf.runtime.draw2d.ui.render (1.0.100.v20070809-0000) "GMF
Draw2d Image Rendering Additions" [Active]
org.eclipse.gmf.runtime.draw2d.ui.render.awt (1.0.100.v20070928-0000)
"GMF Draw2d Image AWT based Rendering Additions" [Starting]
org.eclipse.gmf.runtime.emf.clipboard.core (1.0.100.v20070809-0000) "GMF
EMF Clipboard Support" [Active]
org.eclipse.gmf.runtime.emf.commands.core (1.0.100.v20080114-2222) "GMF
Commands" [Active]
org.eclipse.gmf.runtime.emf.core (1.0.101.v20080201-0201) "GMF Modeling
Service Layer" [Active]
org.eclipse.gmf.runtime.emf.type.core (1.0.101.v20080114-2222) "GMF EMF
Type Core" [Active]
org.eclipse.gmf.runtime.emf.type.ui (1.0.1.v20070809-0000) "GMF EMF Type
UI" [Active]
org.eclipse.gmf.runtime.emf.ui (1.0.100.v20070809-0000) "GMF MSL UI"
[Active]
org.eclipse.gmf.runtime.emf.ui.properties (1.0.2.v20070809-0000) "GMF
EMF UI Properties Providers" [Active]
org.eclipse.gmf.runtime.gef.ui (1.0.1.v20070809-0000) "GMF GEF
Additions" [Active]
org.eclipse.gmf.runtime.lite (1.0.0.v20070921-0000) "GMF Pure-GEF
Runtime" [Starting]
org.eclipse.gmf.runtime.notation (1.0.101.v20080114-2222) "GMF Notation
Model Support" [Active]
org.eclipse.gmf.runtime.notation.edit (1.0.1.v20070809-0000) "GMF
Notation Edit Support" [Active]
org.eclipse.gmf.runtime.notation.providers (1.0.1.v20070809-0000) "GMF
Notation Metamodel" [Starting]
org.eclipse.gmf.sdk (1.0.0.v20070809-0000) "Graphical Modeling Framework
SDK" [Starting]
Framework SDK Developer Resources" [Resolved]
Modeling Framework Runtime Developer Resources" [Resolved]
org.eclipse.gmf.tests.experimental.source (1.0.0.v20080114-2222)
"Graphical Modeling Framework (Lite) Tests Sources" [Resolved]
org.eclipse.gmf.tests.lite (2.0.0.v20080114-2222) "pluginName" [Installed]
org.eclipse.gmf.tooldef (2.0.0.v20070809-0000) "GMF Tooling Model" [Active]
org.eclipse.gmf.tooldef.edit (2.0.0.v20070809-0000) "GMF Tooling Edit
Support" [Active]
org.eclipse.gmf.validate (1.1.0.v20070809-0000) "GMF Validation" [Active]
org.eclipse.gmf.xpand (1.0.2.v20071124-0000) "GMF Xpand Template Engine"
[Starting]
org.eclipse.gmf.xpand.editor (1.0.0.v20070809-0000) "GMF Xpand Editor
Plug-in" [Starting]
org.eclipse.help (3.3.1.v20070726_33x) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.200.v20070510) "Help Application Server"
[Starting]
org.eclipse.help.base (3.3.1.v20070813_33x) "Help System Base" [Starting]
org.eclipse.help.ui (3.3.1.v20070726_33x) "Help System UI" [Starting]
org.eclipse.help.webapp (3.3.1.v20070823_33x) "Help System Webapp"
[Starting]
org.eclipse.jdt (3.3.0.v20070607-1300) "Eclipse Java Development Tools"
[Resolved]
org.eclipse.jdt.apt.core (3.3.1.R33x_v20070831-0435) "Java Annotation
Processing Core" [Starting]
org.eclipse.jdt.apt.pluggable.core (1.0.1.R33x_v20070831-0435) "Java
Compiler Apt IDE" [Starting]
org.eclipse.jdt.apt.ui (3.3.1.R33x_v20070801-1930) "Java Annotation
Processing UI" [Starting]
org.eclipse.jdt.compiler.apt (1.0.1.R33x_v20070831-0435) "Java Compiler
Apt" [Resolved]
org.eclipse.jdt.compiler.tool (1.0.1.v_780_R33x) "Java Compiler Tool
Support" [Resolved]
org.eclipse.jdt.core (3.3.1.v_780_R33x) "Java Development Tools Core"
[Active]
org.eclipse.jdt.core.manipulation (1.1.0.v20070606-0010) "Java Code
Manipulation Functionality" [Active]
org.eclipse.jdt.debug (3.3.1.v20070719_r331) "JDI Debug Model" [Active]
org.eclipse.jdt.debug.ui (3.2.101.v20070718_r331) "JDI Debug UI" [Starting]
org.eclipse.jdt.doc.isv (3.3.1.r331_v20070913) "Eclipse JDT Plug-in
Developer Guide" [Starting]
org.eclipse.jdt.doc.user (3.3.1.r331_v20070912a) "Eclipse Java
Development User Guide" [Starting]
org.eclipse.jdt.junit (3.3.1.r331_v20070829) "Java Development Tools
JUnit support" [Starting]
org.eclipse.jdt.junit.runtime (3.3.0.v20070606-0010) "Java Development
Tools JUnit runtime support" [Resolved]
org.eclipse.jdt.junit4.runtime (1.0.100.v20070606-0010) "Java
Development Tools JUnit4 runtime support" [Resolved]
org.eclipse.jdt.launching (3.3.1.v20070808_r331) "Java Development Tools
Launching Support" [Active]
Development Tools SDK" [Resolved]
org.eclipse.jdt.ui (3.3.1.r331_v20070906) "Java Development Tools UI"
[Active]
org.eclipse.jem.util (2.0.1.v200709051030) "Java EMF Model Utilities"
[Starting]
org.eclipse.jet (0.8.1.v20070920) "Eclipse Modeling Framework
Technologies - JET (Incubation)" [Starting]
org.eclipse.jet.core (1.0.1.v20070920) "Eclipse Modeling Framework
Technologies - JET Core (Incubation)" [Starting]
org.eclipse.jet.doc (0.8.1.v20070920) "Eclipse Modeling Framework
Technologies - JET Documentation (Incubation)" [Starting]
org.eclipse.jet.examples (0.8.0.v20070913) "Eclipse Modeling Framework
Technologies - JET Examples (Incubation)" [Starting]
SDK" [Resolved]
org.eclipse.jet.ui (0.8.0.v20070913) "JET Transformations UI Plug-in
org.eclipse.jface (3.3.1.M20070910-0800b) "JFace" [Active]
org.eclipse.jface.databinding (1.1.1.M20070910-0800b) "JFace Data
Binding for SWT and JFace" [Resolved]
org.eclipse.jface.text (3.3.1.r331_v20070629) "JFace Text" [Resolved]
org.eclipse.jsch.core (1.0.0.I20070426) "JSch Core" [Active]
org.eclipse.jsch.ui (1.0.1.r33x_20070709) "JSch UI" [Starting]
org.eclipse.ltk.core.refactoring (3.3.1.r331_v20070829) "Refactoring
Core" [Active]
org.eclipse.ltk.ui.refactoring (3.3.1.r331_v20070829) "Refactoring UI"
[Active]
org.eclipse.mylyn (2.1.0.v20070927-0900) "Mylyn" [Starting]
org.eclipse.mylyn.bugzilla.core (2.1.0.v20070927-0900) "Mylyn Bugzilla
Connector Core" [Active]
org.eclipse.mylyn.bugzilla.ide (2.1.0.v20070927-0900) "Mylyn Bugzilla
Connector IDE" [Active]
org.eclipse.mylyn.bugzilla.ui (2.1.0.v20070927-0900) "Mylyn Bugzilla
Connector UI" [Active]
org.eclipse.mylyn.compatibility (2.1.0.v20070927-0900) "Java 5
Compatibility Checker" [Active]
org.eclipse.mylyn.context.core (2.1.0.v20070927-0900) "Mylyn Context
Core" [Active]
org.eclipse.mylyn.context.ui (2.1.0.v20070927-0900) "Mylyn Context UI"
[Active]
org.eclipse.mylyn.help.ui (2.1.0.v20070927-0900) "Mylyn Help" [Starting]
org.eclipse.mylyn.ide.ant (2.1.0.v20070927-0900) "Mylyn Ant UI Plug-in"
[Active]
org.eclipse.mylyn.ide.ui (2.1.0.v20070927-0900) "Mylyn IDE UI" [Active]
org.eclipse.mylyn.java.ui (2.1.0.v20070927-0900) "Mylyn Java" [Active]
org.eclipse.mylyn.monitor.core (2.1.0.v20070927-0900) "Mylyn Monitor
Core" [Resolved]
org.eclipse.mylyn.monitor.ui (2.1.0.v20070927-0900) "Mylyn Monitor UI"
[Active]
org.eclipse.mylyn.pde.ui (2.1.0.v20070927-0900) "Mylyn PDE UI Plug-in"
[Active]
org.eclipse.mylyn.resources.ui (2.1.0.v20070927-0900) "Mylyn Resources
UI" [Active]
org.eclipse.mylyn.tasks.core (2.1.0.v20070927-0900) "Mylyn Tasks Core"
[Active]
org.eclipse.mylyn.tasks.ui (2.1.0.v20070927-0900) "Mylyn Tasks UI" [Active]
org.eclipse.mylyn.team.cvs (2.1.0.v20070927-0900) "Mylyn Team CVS
Plug-in" [Resolved]
org.eclipse.mylyn.team.ui (2.1.0.v20070927-0900) "Mylyn Team UI" [Active]
org.eclipse.mylyn.web.core (2.1.0.v20070927-0900) "Mylyn Web Core
Plug-in" [Active]
org.eclipse.mylyn.web.ui (2.1.0.v20070927-0900) "Mylyn Web UI" [Starting]
org.eclipse.ocl (1.1.1.v200707131415) "Object Constraint Language (OCL)
2.0 Parser/Interpreter" [Active]
org.eclipse.ocl.doc (1.1.0.v200706071450) "Object Constraint Language
(OCL) 2.0 Documentation" [Starting]
org.eclipse.ocl.ecore (1.1.0.v200706071450) "OCL 2.0 Binding for Ecore"
[Active]
Constraint Language (OCL) 2.0 Source" [Resolved]
org.eclipse.ocl.uml (1.1.1.v200707131415) "OCL 2.0 Binding for UML"
[Starting]
2.0 Binding for UML Source" [Resolved]
org.eclipse.osgi (3.3.1.R33x_v20070828) "OSGi System Bundle" [Active]
org.eclipse.osgi.services (3.1.200.v20070605) "OSGi Release 4.0.1
Services" [Resolved]
org.eclipse.osgi.util (3.1.200.v20070605) "OSGi Release 4.0.1 Utility
Classes" [Resolved]
org.eclipse.pde (3.3.1.R33x_r20070920) "Eclipse Plug-in Development
Environment" [Active]
org.eclipse.pde.build (3.3.2.R331_v20071019) "Plug-in Development
Environment Build Support" [Starting]
org.eclipse.pde.core (3.3.1.v20070912-0800) "Plug-in Development Core"
[Active]
org.eclipse.pde.doc.user (3.3.0.v20070614-0800) "Eclipse Plug-in
Development User Guide" [Resolved]
org.eclipse.pde.junit.runtime (3.3.0.v20070608-1300) "PDE JUnit Plug-in
Test" [Resolved]
org.eclipse.pde.runtime (3.3.0.v20070608-1300) "Plug-in Development
Environment Runtime" [Starting]
"Eclipse Plug-in Development Environment Developer Resources" [Resolved]
org.eclipse.pde.ui (3.3.1.v20070912-0800) "Plug-in Development UI" [Active]
org.eclipse.pde.ui.templates (3.3.0.v20070608-1300) "PDE Templates"
[Starting]
org.eclipse.platform (3.3.2.R33x_v20071022) "Eclipse Platform" [Starting]
org.eclipse.platform.doc.isv (3.3.1.r331_v20070913) "Eclipse Platform
Plug-in Developer Guide" [Starting]
org.eclipse.platform.doc.user (3.3.0.M20070913-1400) "Eclipse Workbench
"Eclipse Platform Plug-in Developer Resources" [Resolved]
org.eclipse.platform.source.win32.win32.x86
(3.3.2.R33x_v20071022-_19UEksF-G8Yc6bUv3Dz) "Eclipse Platform Plug-in
org.eclipse.rcp (3.2.0.v20070612) "Eclipse RCP" [Starting]
"Eclipse RCP Plug-in Developer Resources" [Resolved]
org.eclipse.rcp.source.win32.win32.x86
(3.3.2.R33x_r20071022-8y8eE9CEV3FspP8HJrY1M2dS) "Eclipse RCP Plug-in
org.eclipse.sdk (3.3.2.R33x_v20071022) "Eclipse Project SDK" [Starting]
org.eclipse.search (3.3.1.r331_v20070831-0800) "Search Support" [Active]
org.eclipse.swt (3.3.2.v3347) "Standard Widget Toolkit" [Resolved]
org.eclipse.swt.win32.win32.x86 (3.3.2.v3347a) "Standard Widget Toolkit
org.eclipse.team.core (3.3.1.r33x_20070807) "Team Support Core" [Active]
org.eclipse.team.cvs.core (3.3.1.r33x_20070724) "CVS Team Provider Core"
[Active]
org.eclipse.team.cvs.ssh (3.2.100.I20061208) "CVS SSH Core" [Starting]
org.eclipse.team.cvs.ssh2 (3.2.100.I20070604) "CVS SSH2" [Active]
org.eclipse.team.cvs.ui (3.3.1.r33x_20070807) "CVS Team Provider UI"
[Active]
org.eclipse.team.ui (3.3.1.r33x_20070730) "Team Support UI" [Active]
org.eclipse.text (3.3.0.v20070606-0010) "Text" [Resolved]
org.eclipse.tomcat (4.1.230.v20070531) "Tomcat Wrapper" [Starting]
org.eclipse.ui (3.3.1.M20070910-0800b) "Eclipse UI" [Active]
org.eclipse.ui.browser (3.2.100.v20070524A) "Browser Support" [Active]
org.eclipse.ui.cheatsheets (3.3.0.v20070507) "Cheat Sheets" [Starting]
org.eclipse.ui.console (3.2.1.v20070824_r331) "Console" [Active]
org.eclipse.ui.editors (3.3.1.r331_v20070629) "Default Text Editor" [Active]
org.eclipse.ui.externaltools (3.1.200.v20070416) "External Tools" [Active]
org.eclipse.ui.forms (3.3.0.v20070511) "Eclipse Forms" [Active]
org.eclipse.ui.ide (3.3.1.M20070910-0800b) "Eclipse IDE UI" [Active]
org.eclipse.ui.ide.application (1.0.0.I20070530-0100) "Eclipse IDE UI
Application" [Resolved]
org.eclipse.ui.intro (3.2.101.v20070827_33x) "Welcome Framework" [Starting]
org.eclipse.ui.intro.universal (3.2.100.v20070530A) "Universal Welcome"
[Starting]
org.eclipse.ui.navigator (3.3.2.M20071022-1600a) "Common Navigator View"
[Active]
org.eclipse.ui.navigator.resources (3.3.1.M20070831-2000) "Navigator
Workbench Components" [Active]
org.eclipse.ui.net (1.0.0.I20070516) "Internet Connection Management UI"
[Active]
org.eclipse.ui.presentations.r21 (3.2.100.I20070605-0010) "R21
Presentation Plug-in" [Starting]
org.eclipse.ui.views (3.2.101.M20070910-0800b) "Views" [Active]
org.eclipse.ui.views.properties.tabbed (3.3.1.M20070831-0800) "Tabbed
Properties View" [Active]
org.eclipse.ui.win32 (3.2.100.I20070319-0010) "Eclipse UI Win32
Enhancements" [Resolved]
org.eclipse.ui.workbench (3.3.1.M20070921-1200) "Workbench" [Active]
org.eclipse.ui.workbench.compatibility (3.2.0.I20070319-0010) "Workbench
Compatibility" [Resolved]
org.eclipse.ui.workbench.texteditor (3.3.1.r331_v20070806) "Text Editor
Framework" [Active]
org.eclipse.uml2 (2.1.0.v200706251652) "UML2" [Resolved]
org.eclipse.uml2.codegen.ecore (1.3.0.v200708221323) "UML2 Ecore Code
org.eclipse.uml2.codegen.ecore.ui (1.3.0.v200706251652) "UML2 Ecore Code
org.eclipse.uml2.common (1.3.1.v200707311200) "UML2 Common" [Starting]
org.eclipse.uml2.common.edit (1.3.0.v200706251652) "UML2 Common Edit
Support" [Active]
Plug-in (Incubation)" [Starting]
org.eclipse.uml2.diagram.activity (0.7.101.v200802260712) "Activity
Diagram Plugin (Incubation)" [Active]
org.eclipse.uml2.diagram.clazz (0.7.101.v200802260712) "UML2 Class
Diagram Plug-in (Incubation)" [Active]
org.eclipse.uml2.diagram.codegen (0.7.101.v200802260712) "UML2Tools
Generation Helpers Model (Incubation)" [Starting]
org.eclipse.uml2.diagram.codegen.edit (0.7.101.v200802260712) "UML2Tools
Generation Helpers Edit (Incubation)" [Starting]
org.eclipse.uml2.diagram.common (0.7.101.v200802260712) "UML2 Diagram
Commons Plug-in (Incubation)" [Resolved]
org.eclipse.uml2.diagram.component (0.7.101.v200802260712) "UML2
Component Diagram Plug-in (Incubation)" [Active]
org.eclipse.uml2.diagram.csd (0.7.101.v200802260712) "UML Composite
Structures Diagram Plugin (Incubation)" [Active]
org.eclipse.uml2.diagram.def (0.7.101.v200802260712) "UML2 Diagram
Definitions Plug-in (Incubation)" [Starting]
org.eclipse.uml2.diagram.deploy (0.7.101.v200802260712) "Deployment
org.eclipse.uml2.diagram.examples.clazz (0.7.101.v200802260712) "UML2
Profile Definition Diagram Samples Plug-in (Incubation)" [Resolved]
org.eclipse.uml2.diagram.examples.profile (0.7.101.v200802260712) "UML2
org.eclipse.uml2.diagram.parser (0.7.1.v200802260712) "UML2 Diagram
Parser Plug-in (Incubation)" [Active]
org.eclipse.uml2.diagram.profile (0.7.1.v200802260712) "UML2 Profile
Definition Diagram Plug-in (Incubation)" [Active]
Diagramming Source" [Resolved]
org.eclipse.uml2.diagram.statemachine (0.7.101.v200802260712) "UML2
State Machine Diagram Plug-in (Incubation)" [Active]
org.eclipse.uml2.diagram.usecase (0.7.101.v200802260712) "Use Case
org.eclipse.uml2.doc (2.1.1.v200707181556) "UML2 Documentation" [Starting]
org.eclipse.uml2.examples (2.1.0.v200706251652) "UML2 Examples" [Resolved]
Source" [Resolved]
org.eclipse.uml2.examples.uml.ui (2.1.0.v200706251652) "UML2 UML
Examples UI" [Starting]
org.eclipse.uml2.source (2.1.1.v200708301222) "UML2 Source" [Resolved]
org.eclipse.uml2.uml (2.1.1.v200707311200) "UML2 UML Model" [Active]
org.eclipse.uml2.uml.ecore.exporter (2.1.0.v200706251652) "UML2 UML
Exporter for EMF" [Starting]
org.eclipse.uml2.uml.ecore.importer (2.1.0.v200706251652) "UML2 UML
Importer for EMF" [Starting]
org.eclipse.uml2.uml.edit (2.1.0.v200708301222) "UML2 UML Edit Support"
[Active]
org.eclipse.uml2.uml.editor (2.1.0.v200706251652) "UML2 UML Editor"
[Starting]
org.eclipse.uml2.uml.resources (2.1.0.v200706251652) "UML2 UML
Documentation Plug-in" [Starting]
org.eclipse.update.configurator (3.2.101.R33x_v20070810) "Install/Update
Configurator" [Active]
org.eclipse.update.core (3.2.101.R33x_v20070911) "Install/Update Core"
[Active]
org.eclipse.update.core.win32 (3.2.100.v20070615) "Install/Update Core
org.eclipse.update.scheduler (3.2.100.v20070615) "Automatic Updates
Scheduler" [Active]
org.eclipse.update.ui (3.2.100.v20070615) "Install/Update UI" [Active]
org.eclipse.wst.command.env (1.0.204.v200708202226) "Environment Command
Framework (headless)" [Starting]
org.eclipse.wst.command.env.core (1.0.203.v200707302047) "Environment
Command Framework (core)" [Resolved]
org.eclipse.wst.command.env.infopop (1.0.3.v200706110217) "Web services
UI" [Starting]
org.eclipse.wst.command.env.ui (1.0.203.v200709052219) "Environment
Command Framework (GUI)" [Starting]
org.eclipse.wst.common.core (1.1.101.v200706120315) "WST Common Core
Plug-in" [Starting]
org.eclipse.wst.common.emf (1.1.104.v200709131115) "EMF Utilities"
[Starting]
org.eclipse.wst.common.emfworkbench.integration (1.1.104.v200709122200)
"EMF Workbench Edit Plug-in" [Starting]
org.eclipse.wst.common.environment (1.0.200.v200705302225) "Enviornment
Plug-in" [Starting]
org.eclipse.wst.common.frameworks (1.1.102.v200706071630) "Common
Frameworks" [Starting]
org.eclipse.wst.common.frameworks.ui (1.1.101.v200709122200) "WTP UI
Plug-in" [Starting]
org.eclipse.wst.common.infopop (1.0.2.v200706110217) "Common WST
infopops" [Starting]
org.eclipse.wst.common.modulecore (1.1.103.v200709192345) "Modulecore
Plug-in" [Starting]
org.eclipse.wst.common.project.facet.core (1.2.1.v200708281831) "Project
Facet Core" [Starting]
org.eclipse.wst.common.project.facet.ui (1.2.1.v200708232226) "Project
Facet UI" [Starting]
org.eclipse.wst.common.snippets (1.1.101.v200705302225) "Snippets View"
[Starting]
org.eclipse.wst.common.ui (1.1.200.v200705302225) "Eclipse Base UI
extensions" [Starting]
org.eclipse.wst.common.ui.properties (1.0.102.v200706120315) "Common
Properties UI" [Starting]
org.eclipse.wst.common.uriresolver (1.1.201.v200705302225) "Common URI
Resolver Framework" [Starting]
org.eclipse.wst.dtd.core (1.1.101.v200705302225) "Structured Source DTD
Core" [Starting]
org.eclipse.wst.dtd.ui (1.0.201.v200705302225) "SSE DTD Source Editor"
[Starting]
org.eclipse.wst.dtd.ui.infopop (1.0.2.v200706110217) "DTD Editor
infopops" [Resolved]
org.eclipse.wst.dtdeditor.doc.user (1.0.300.v200705302225) "DTD Editor
documentation" [Resolved]
org.eclipse.wst.internet.cache (1.0.201.v200705302225) "Cache URI
Resolver Plug-in" [Starting]
org.eclipse.wst.sse.core (1.1.202.v200709061102) "Structured Text Model"
[Starting]
org.eclipse.wst.sse.doc.user (1.0.300.v200705302225) "Structured text
editor and snippets documentation" [Resolved]
org.eclipse.wst.sse.ui (1.0.303.v200709061102) "Structured Source
Editor" [Starting]
org.eclipse.wst.sse.ui.infopop (1.0.102.v200706110217) &quo
| Re: Problem : Audit constraints [message #176017 is a reply to message #175906] |
Thu, 06 March 2008 07:22   |
Typically, people forget to set the Validation Enabled property to true in
the Gen Diagram element of the gmfgen model. If you're successfully
invoking audits using the Diagram > Validate menu, then I suggest setting a
breakpoint in the validator to see what's going on.
- Rich
On 3/6/08 3:07 AM, in article fqo8n7$eel$1@build.eclipse.org, "Philippe
BLANC" <blanc.philippe83@gmail.com> wrote:
> I'm new with GMF.
> constraints.
> Any ideas ?
> Best regards,
> Philippe
> Configuration :
> Eclipse 3.3.1.1
> *** Features:
> Client"
> Generation"
> Generation UI"
> Generator UI"
> Objects (SDO)"
> Query"
> (EMF) Source"
> Examples"
> Integration Source"
> Binding for UML"
> "Eclipse Platform"
> RCP"
> Diagramming Source"
> Source"
> (Incubation)"
> (XSD) Source"
> [Resolved]
> [Resolved]
> LPG" [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> Plug-in" [Resolved]
> [Resolved]
> Plug-in" [Resolved]
> [Resolved]
> [Resolved]
> Mechanism" [Active]
> [Resolved]
> Language" [Active]
> [Active]
> [Active]
> Draw2d" [Active]
> [Starting]
> [Starting]
> Support" [Starting]
> Model" [Active]
> Support" [Active]
> [Starting]
> Model" [Active]
> Support" [Starting]
> Support" [Starting]
> [Starting]
> [Starting]
> Mapping" [Starting]
> Mapping" [Starting]
> Core" [Active]
> [Resolved]
> Source" [Resolved]
> [Starting]
> [Starting]
> [Starting]
> Container" [Active]
> [Active]
> Service" [Starting]
> Servlet" [Starting]
> [Resolved]
> Mechanism" [Active]
> Support" [Active]
> [Starting]
> Plug-in" [Starting]
> Support" [Starting]
> UI" [Starting]
> Plug-in" [Active]
> Plugin" [Active]
> [Active]
> Plug-in" [Starting]
> Support" [Active]
> [Active]
> Support" [Active]
> Plugin" [Active]
> Core" [Active]
> UI" [Active]
> UI" [Active]
> Additions" [Active]
> Commands" [Active]
> Type Core" [Active]
> UI" [Active]
> [Active]
> Additions" [Active]
> Runtime" [Starting]
> SDK" [Starting]
> Support" [Active]
> [Starting]
> Plug-in" [Starting]
> [Starting]
> [Starting]
> [Resolved]
> Apt" [Resolved]
> Support" [Resolved]
> [Active]
> [Active]
> [Starting]
> SDK" [Resolved]
> Core" [Active]
> [Active]
> Core" [Active]
> [Active]
> [Active]
> Core" [Resolved]
> [Active]
> [Active]
> UI" [Active]
> [Active]
> Plug-in" [Resolved]
> Plug-in" [Active]
> [Active]
> [Starting]
> Classes" [Resolved]
> [Active]
> Test" [Resolved]
> [Starting]
> [Active]
> [Active]
> [Starting]
> [Active]
> [Active]
> Framework" [Active]
> Support" [Active]
> Diagram Plu
| Re: Problem : Audit constraints [message #176068 is a reply to message #176017] |
Thu, 06 March 2008 09:08   |
The Validation Enabled and Validation Decorators properties are set to
true. However, there is no source code in my ...mindmap.diagram project.
Is it normal ?
The only place where my ocl constraint is displayed is in my plugin.xml
file :
<extension point="org.eclipse.emf.validation.constraintProviders">
<?gmfgen generated="true"?>
<category id="org.eclipse.gmf.examples.mindmap.audits"
mandatory="false" name="Mindmap Audits">
<![CDATA[Audits to detect problems in mindmap diagrams.]]>
</category>
<constraintProvider cache="true">
<package namespaceUri="http://www.example.org/mindmap"/>
<constraints
categories="org.eclipse.gmf.examples.mindmap.audits">
<constraint id="cycle"
lang="OCL"
name="Cyclic relationship check"
mode="Batch"
severity="ERROR" statusCode="200">
<![CDATA[self.relations->forAll(r1, r2 | r1.target =
r2.source and r1.type = r2.type implies r2.target <> r1.source)]]>
<description><![CDATA[This audit detects (simple) cycles
between Topic relationships]]></description>
<message><![CDATA[A cycle was found in relationships
between two Topic elements.]]></message>
<target class="org.eclipse.gmf.examples.mindmap.Map"/>
</constraint>
<constraint id="topic.name"
lang="OCL"
name="Topic name audit"
mode="Batch"
<![CDATA[name.size() > 0]]>
<description><![CDATA[A Topic must have a name
provided.]]></description>
<message><![CDATA[Topics must have a name]]></message>
<target class="org.eclipse.gmf.examples.mindmap.Topic"/>
</constraint>
</constraints>
</constraintProvider>
</extension>
> - Rich
>> Hi,
>> I'm new with GMF.
>> constraints.
>> Any ideas ?
>> Best regards,
>> Philippe
>> Configuration :
>> Eclipse 3.3.1.1
>> *** Features:
>> Client"
>> Generation"
>> Generation UI"
>> Generator UI"
>> Objects (SDO)"
>> Query"
>> (EMF) Source"
>> Examples"
>> Integration Source"
>> Binding for UML"
>> "Eclipse Platform"
>> RCP"
>> Diagramming Source"
>> Source"
>> (Incubation)"
>> (XSD) Source"
>> [Resolved]
>> [Resolved]
>> LPG" [Resolved]
>> [Resolved]
>> [Resolved]
>> [Resolved]
>> Plug-in" [Resolved]
>> [Resolved]
>> Plug-in" [Resolved]
>> [Resolved]
>> [Resolved]
>> Mechanism" [Active]
>> [Resolved]
>> Language" [Active]
>> [Active]
>> [Active]
>> Draw2d" [Active]
>> [Starting]
>> [Starting]
>> Support" [Starting]
>> Model" [Active]
>> Support" [Active]
>> [Starting]
>> Model" [Active]
>> Support" [Starting]
>> Support" [Starting]
>> [Starting]
>> [Starting]
>> Mapping" [Starting]
>> Mapping" [Starting]
>> Core" [Active]
>> [Resolved]
>> Source" [Resolved]
>> [Starting]
>> [Starting]
>> [Starting]
>> Container" [Active]
>> [Active]
>> Service" [Starting]
>> Servlet" [Starting]
>> [Resolved]
>> Mechanism" [Active]
>> Support" [Active]
>> [Starting]
>> Plug-in" [Starting]
>> Support" [Starting]
>> UI" [Starting]
>> Plug-in" [Active]
>> Plugin" [Active]
>> [Active]
>> Plug-in" [Starting]
>> Support" [Active]
>> [Active]
>> Support" [Active]
>> Plugin" [Active]
>> Core" [Active]
>> UI" [Active]
>> UI" [Active]
>> Additions" [Active]
>> Commands" [Active]
>> Type Core" [Active]
>> UI" [Active]
>> [Active]
>> Additions" [Active]
>> Runtime" [Starting]
>> SDK" [Starting]
>> Support" [Active]
>> [Starting]
>> Plug-in" [Starting]
>> [Starting]
>> [Starting]
>> [Resolved]
>> Apt" [Resolved]
>> Support" [Resolved]
>> [Active]
>> [Active]
>> [Starting]
>> SDK" [Resolved]
>> Core" [Active]
>> [Active]
>> Core" [Active]
>> [Active]
>> [Active]
>> Core" [Resolved]
>> [Active]
>> [Active]
>> UI" [Active]
>> [Active]
>> Plug-in" [Resolved]
>> Plug-in" [Active]
>> [Active]
>> [Starting]
>> Classes" [Resolved]
>> [Active]
>> Test" [Resolved]
>> [Starting]
| Re: Problem : Audit constraints [message #176100 is a reply to message #176068] |
Thu, 06 March 2008 09:30   |
Take a look at the generated *ValidationProvider and ValidateAction classes.
- Rich
On 3/6/08 9:08 AM, in article fqotsi$rji$1@build.eclipse.org, "Philippe
> Is it normal ?
> file :
> </category>
> <constraints
> lang="OCL"
> mode="Batch"
> </constraint>
> lang="OCL"
> mode="Batch"
> </constraint>
> </constraints>
> </extension>
>> - Rich
>>> Hi,
>>> I'm new with GMF.
>>> constraints.
>>> Any ideas ?
>>> Best regards,
>>> Philippe
>>> Configuration :
>>> Eclipse 3.3.1.1
>>> *** Features:
>>> Client"
>>> Generation"
>>> Generation UI"
>>> Generator UI"
>>> Objects (SDO)"
>>> Query"
>>> (EMF) Source"
>>> Examples"
>>> Integration Source"
>>> Binding for UML"
>>> "Eclipse Platform"
>>> RCP"
>>> Diagramming Source"
>>> Source"
>>> (Incubation)"
>>> (XSD) Source"
>>> [Resolved]
>>> [Resolved]
>>> LPG" [Resolved]
>>> [Resolved]
>>> [Resolved]
>>> [Resolved]
>>> Plug-in" [Resolved]
>>> [Resolved]
>>> Plug-in" [Resolved]
>>> [Resolved]
>>> [Resolved]
>>> Mechanism" [Active]
>>> [Resolved]
>>> Language" [Active]
>>> [Active]
>>> [Active]
>>> Draw2d" [Active]
>>> [Starting]
>>> [Starting]
>>> Support" [Starting]
>>> Model" [Active]
>>> Support" [Active]
>>> [Starting]
>>> Model" [Active]
>>> Support" [Starting]
>>> Support" [Starting]
>>> [Starting]
>>> [Starting]
>>> Mapping" [Starting]
>>> Mapping" [Starting]
>>> Core" [Active]
>>> [Resolved]
>>> Source" [Resolved]
>>> [Starting]
>>> [Starting]
>>> [Starting]
>>> Container" [Active]
>>> [Active]
>>> Service" [Starting]
>>> Servlet" [Starting]
>>> [Resolved]
>>> Mechanism" [Active]
>>> Support" [Active]
>>> [Starting]
>>> Plug-in" [Starting]
>>> Support" [Starting]
>>> UI" [Starting]
>>> Plug-in" [Active]
>>> Plugin" [Active]
>>> [Active]
>>> Plug-in" [Starting]
>>> Support" [Active]
>>> [Active]
>>> Support" [Active]
>>> Plugin" [Active]
>>> Core" [Active]
>>> UI" [Active]
>>> UI" [Active]
>>> Additions" [Active]
>>> Commands" [Active]
>>> Type Core" [Active]
>>> UI" [Active]
>>> [Active]
>>> Additions" [Active]
>>> Runtime" [Starting]
>>> SDK" [Starting]
>>> Support" [Active]
>>> [Starting]
>>> Plug-in" [Starting]
>>> [Starting]
>>> [Starting]
>>> [Resolved]
>>> Apt" [Resolved]
>>> Support" [Resolved]
>>> [Active]
>>> [Active]
>>> [Starting]
>>> SDK" [Resolved]
>>> Core" [Active]
>>> [Active]
>>> Core" [Active]
>>> [Active]
>>> [Active]
>>> Core" [Resolved]
>>> [Active]
>>> [Active]
>>> UI" [Active]
>>> [Active]
>>> Plug-in" [Resolved]
| Re: Problem : Audit constraints [message #176135 is a reply to message #176100] |
Thu, 06 March 2008 10:18   |
Ok, thanks for your help Richard.
There is an empty class JavaAudits in my MindmapValidationProviders.
So it seems that my audit constraint has not been implemented, but I
don't know why... My project is an CVS project : is there some problems
about generating source code with CVS projects ?
Philippe
> - Rich
>> Is it normal ?
>> file :
>> </category>
>> <constraints
>> lang="OCL"
>> mode="Batch"
>> </constraint>
>> lang="OCL"
>> mode="Batch"
>> </constraint>
>> </constraints>
>> </extension>
>>> - Rich
>>>> Hi,
>>>> I'm new with GMF.
>>>> constraints.
>>>> Any ideas ?
>>>> Best regards,
>>>> Philippe
>>>> Configuration :
>>>> Eclipse 3.3.1.1
>>>> *** Features:
>>>> Client"
>>>> Generation"
>>>> Generation UI"
>>>> Generator UI"
>>>> Objects (SDO)"
>>>> Query"
>>>> (EMF) Source"
>>>> Examples"
>>>> Integration Source"
>>>> Binding for UML"
>>>> "Eclipse Platform"
>>>> RCP"
>>>> Diagramming Source"
>>>> Source"
>>>> (Incubation)"
>>>> (XSD) Source"
>>>> [Resolved]
>>>> [Resolved]
>>>> LPG" [Resolved]
>>>> [Resolved]
>>>> [Resolved]
>>>> [Resolved]
>>>> Plug-in" [Resolved]
>>>> [Resolved]
>>>> Plug-in" [Resolved]
>>>> [Resolved]
>>>> [Resolved]
>>>> Mechanism" [Active]
>>>> [Resolved]
>>>> Language" [Active]
>>>> [Active]
>>>> [Active]
>>>> Draw2d" [Active]
>>>> [Starting]
>>>> [Starting]
>>>> Support" [Starting]
>>>> Model" [Active]
>>>> Support" [Active]
>>>> [Starting]
>>>> Model" [Active]
>>>> Support" [Starting]
>>>> Support" [Starting]
>>>> [Starting]
>>>> [Starting]
>>>> Mapping" [Starting]
>>>> Mapping" [Starting]
>>>> Core" [Active]
>>>> [Resolved]
>>>> Source" [Resolved]
>>>> [Starting]
>>>> [Starting]
>>>> [Starting]
>>>> Container" [Active]
>>>> [Active]
>>>> Service" [Starting]
>>>> Servlet" [Starting]
>>>> [Resolved]
>>>> Mechanism" [Active]
>>>> Support" [Active]
>>>> [Starting]
>>>> Plug-in" [Starting]
>>>> Support" [Starting]
>>>> UI" [Starting]
>>>> Plug-in" [Active]
>>>> Plugin" [Active]
>>>> [Active]
>>>> Plug-in" [Starting]
>>>> Support" [Active]
>>>> [Active]
>>>> Support" [Active]
>>>> Plugin" [Active]
>>>> Core" [Active]
>>>> UI" [Active]
>>>> UI" [Active]
>>>> Additions" [Active]
>>>> Commands" [Active]
>>>> Type Core" [Active]
>>>> UI" [Active]
>>>> [Active]
>>>> Additions" [Active]
>>>> Runtime" [Starting]
>>>> SDK" [Starting]
>>>> Support" [Active]
>>>> [Starting]
>>>> Plug-in" [Starting]
>>>> [Starting]
>>>> [Starting]
>>>> [Resolved]
>>>> Apt" [Resolved]
>>>> Support" [Resolved]
>>>> [Active]
>>>> [Active]
>>>> [Starting]
| Re: Problem : Audit constraints [message #176169 is a reply to message #176135] |
Thu, 06 March 2008 10:40   |
The JavaAudits class would be ppulated if you declared Java as the
language. You're using OCL, so try using this statement insead:
not self.name.oclIsUndefined()
Best,
Rich
On 3/6/08 10:18 AM, in article fqp20o$m9t$1build.eclipse.org, "Philippe
> So it seems that my audit constraint has not been implemened, but I
> about enerating source code with CVS projects ?
> Regards,
> Philippe
> Richard Gronback a écrt :
>> - Rich
>>> The alidation Enabled and Validation Decorators properties are set to
>>> Is it normal ?
>>> file :
>>> <extenion point="org.eclipse.emf.validation.constraintProviders">
>>> </category>
>>> <constrantProvider cache="true">
>>> <constraints
>>> lang="OCL"
>>> mode="Batch"
>>> </constraint>
>>> lang="OCL"
>>> mode="Batch"
>>> </constraint>
>>> </constraints>
>>> </extension>
>>>> - Rich
>>>>> Hi,
>>>>> I'm new with GMF.
>>>>> constraints.
>>>>> Any ideas ?
>>>>> Best regards,
>>>>> Philippe
>>>>> Configuration :
>>>>> Eclipse 3.3.1.1
>>>>> *** Features:
>>>>> Client"
>>>>> Generator"
>>>>> Generation"
>>>>> Generation UI"
>>>>> Generator UI"
>>>>> Support"
>>>>> Objects (SDO)"
>>>>> Query"
>>>>> (EMF) Source"
>>>>> Examples"
>>>>> Example"
>>>>> Integration Source"
>>>>> Binding for UML"
>>>>> "Eclipse Platform"
>>>>> RCP"
>>>>> Diagramming Source"
>>>>> Source"
>>>>> (Incubation)"
>>>>> (XSD) Source"
>>>>> [Resolved]
>>>>> [Resolved]
>>>>> LPG" [Resolved]
>>>>> [Resolved]
>>>>> [Resolved]
>>>>> [Resolved]
>>>>> Plug-in" [Resolved]
>>>>> [Resolved]
>>>>> Plug-in" [Resolved]
>>>>> [Resolved]
>>>>> [Resolved]
>>>>> Mechanism" [Active]
>>>>> [Resolved]
>>>>> Language" [Active]
>>>>> [Active]
>>>>> [Active]
>>>>> [Active]
>>>>> Draw2d" [Active]
>>>>> [Starting]
>>>>> [Starting]
>>>>> [Starting]
>>>>> Support" [Starting]
>>>>> Model" [Active]
>>>>> Support" [Active]
>>>>> [Starting]
>>>>> Model" [Active]
>>>>> Support" [Starting]
>>>>> Support" [Starting]
>>>>> [Starting]
>>>>> [Starting]
>>>>> [Starting]
>>>>> Mapping" [Starting]
>>>>> [Starting]
>>>>> Mapping" [Starting]
>>>>> Core" [Active]
>>>>> [Resolved]
>>>>> Source" [Resolved]
>>>>> [Starting]
>>>>> [Starting]
>>>>> [Starting]
>>>>> [Starting]
>>>>> Container" [Active]
>>>>> [Active]
>>>>> Service" [Starting]
>>>>> Servlet" [Starting]
>>>>> [Resolved]
>>>>> Mechanism" [Active]
>>>>> Support" [Active]
>>>>> [Starting]
>>>>> Plug-in" [Starting]
>>>>> [Starting]
>>>>> Support" [Starting]
>>>>> UI" [Starting]
>>>>> Plug-in" [Active]
>>>>> Plugin" [Active]
>>>>> [Active]
>>>>> Plug-in" [Starting]
>>>>> Support" [Active]
>>>>> [Active]
>>>>> Support" [Active]
>>>>> Plugin" [Active]
>>>>> Core" [Active]
>>>>> UI" [Active]
>>>>> [Active]
>>>>> UI" [Active]
>>>>> Additions" [Active]
>>>>> Commands" [Active]
>>>>> Type Core" [Active]
>>>>> UI" [Active]
>>>>> [Active]
>>>>> Additions" [Active]
>>>>> Runtime" [Starting]
>>>>> SDK" [Starting]
>>>>> [Active]
>>>>> Support" [Active]
>>>>> [Starting]
>>>>> Plug-in" [Starting]
| Re: Problem : Audit constraints [message #176201 is a reply to message #176169] |
Thu, 06 March 2008 11:06   |
If I use Java langage to implement my Audit constraint, it works
(Eclipse raises a NotImplementedExeption since my function is not yet
implemented).
But, have I only use Java constraints ? how can I use OCL constraints ?
(is there a problem in my eclipse plugin configuration ?)
Thanks.
Philippe
> Best,
> Rich
>> Regards,
>> Philippe
>>> - Rich
>>>> Is it normal ?
>>>> file :
>>>> </category>
>>>> <constraints
>>>> lang="OCL"
>>>> mode="Batch"
>>>> </constraint>
>>>> lang="OCL"
>>>> mode="Batch"
>>>> </constraint>
>>>> </constraints>
>>>> </extension>
>>>>> - Rich
>>>>>> Hi,
>>>>>> I'm new with GMF.
>>>>>> I've done the tutorial about mindmap model, and then downloaded the
>>>>>> source of the project. I have a problem when I try to test the audit
>>>>>> constraints.
>>>>>> I built a mindmap diagram with a null named Topic element. When I
>>>>>> validate the model, normally an error should be raised because of the
>>>>>> audit rule "name.size() > 0". However, nothing happens and the
>>>>>> validation completes successfully.
>>>>>> Any ideas ?
>>>>>> Thanks for your help.
>>>>>> Best regards,
>>>>>> Philippe
>>>>>> Configuration :
>>>>>> Eclipse 3.3.1.1
>>>>>> *** Features:
>>>>>> org.eclipse.cvs (1.0.1.R33x_r20070802-7C79_9_KKG-mDM9e3H5D) "Eclipse CVS
>>>>>> Client"
>>>>>> org.eclipse.cvs.source (1.0.1.R33x_r20070802-7C79_9_KKG-mDM9e3H5D)
>>>>>> org.eclipse.emf (2.3.2.v200802051830) "Eclipse Modeling Framework (EMF)"
>>>>>> org.eclipse.emf.codegen (2.3.1.v200802051830) "EMF Template Code
>>>>>> Generator"
>>>>>> org.eclipse.emf.codegen.ecore (2.3.2.v200802051830) "EMF Ecore Code
>>>>>> Generation"
>>>>>> org.eclipse.emf.codegen.ecore.ui (2.3.1.v200802051830) "EMF Ecore Code
>>>>>> Generation UI"
>>>>>> org.eclipse.emf.codegen.ui (2.3.1.v200802051830) "EMF Template Code
>>>>>> Generator UI"
>>>>>> org.eclipse.emf.common (2.3.1.v200802051830) "EMF Common"
>>>>>> org.eclipse.emf.converter (2.3.1.v200802051830) "EMF Model Convert
>>>>>> Support"
>>>>>> org.eclipse.emf.doc (2.3.2.v200802051830) "Eclipse Modeling Framework
>>>>>> org.eclipse.emf.ecore.edit (2.3.1.v200802051830) "EMF Ecore Edit Support"
>>>>>> org.eclipse.emf.ecore.editor (2.3.1.v200802051830) "Sample Ecore Editor"
>>>>>> org.eclipse.emf.ecore.sdo (2.3.1.v200802051830) "EMF Service Data
>>>>>> Objects (SDO)"
>>>>>> org.eclipse.emf.ecore.sdo.doc (2.3.2.v200802051830) "EMF Service Data
>>>>>> org.eclipse.emf.ecore.sdo.edit (2.3.1.v200802051830) "EMF Service Data
>>>>>> org.eclipse.emf.ecore.sdo.editor (2.3.1.v200802051830) "EMF Service Data
>>>>>> org.eclipse.emf.ecore.sdo.source (2.3.2.v200802051830) "EMF Service Data
>>>>>> org.eclipse.emf.examples (2.3.1.v200802051830) "Eclipse Modeling
>>>>>> org.eclipse.emf.examples.source (2.3.1.v200802051830) "Eclipse Modeling
>>>>>> org.eclipse.emf.mapping (2.3.1.v200802051830) "EMF Mapping "
>>>>>> org.eclipse.emf.mapping.ecore (2.3.1.v200802051830) "Eclipse Modeling
>>>>>> org.eclipse.emf.mapping.ecore.editor (2.3.1.v200802051830) "Eclipse
>>>>>> org.eclipse.emf.mapping.ui (2.3.1.v200802051830) "EMF Mapping UI"
>>>>>> org.eclipse.emf.ocl (1.1.1.v200709121956-1007w31181_232_67) "Object
>>>>>> Constraint Language (OCL) 2.0 Compatibility API"
>>>>>> org.eclipse.emf.ocl.doc (1.1.0.v200706071450-10-7w311817182561) "Object
>>>>>> Constraint Language (OCL) 2.0 Compatibility API Documentation"
>>>>>> org.eclipse.emf.ocl.examples (1.1.0.v200706071450-32-9oA55P5M5P8GJ5)
>>>>>> "Object Constraint Language (OCL) 2.0 Examples"
>>>>>> org.eclipse.emf.ocl.examples.source (1.1.0.v200706071450) "Object
>>>>>> org.eclipse.emf.ocl.source (1.1.1.v200709121956-1007w31181_232_67)
>>>>>> org.eclipse.emf.query (1.1.1.v200711281714-1007w311822392825) "EMF Model
>>>>>> Query"
>>>>>> org.eclipse.emf.query.doc (1.1.0.v200706071712-21-8s733G3E4C5B76) "EMF
>>>>>> Model Query Documentation"
>>>>>> org.eclipse.emf.query.examples (1.1.0.v200706071712-428Y_kE77Y7U9QAOEC)
>>>>>> "EMF Model Query Examples"
>>>>>> org.eclipse.emf.query.examples.source (1.1.0.v200706071712) "EMF Model
>>>>>> org.eclipse.emf.query.ocl (1.1.0.v200706071712-10-7w311817182823) "EMF
>>>>>> Model Query OCL Integration"
>>>>>> org.eclipse.emf.query.ocl.source (1.1.0.v200706071712-10-7w311817182823)
>>>>>> org.eclipse.emf.query.source (1.1.1.v200711281714-1007w311822392825)
>>>>>> org.eclipse.emf.source (2.3.2.v200802051830) "Eclipse Modeling Framework
>>>>>> (EMF) Source"
>>>>>> org.eclipse.emf.transaction (1.1.2.v200710151610-208a8s733G4A3F5H88)
>>>>>> "EMF Model Transaction Core"
>>>>>> org.eclipse.emf.transaction.doc (1.1.0.v200706071723-208Y8s733G3E3G5G79)
>>>>>> "EMF Model Transaction Documentation"
>>>>>> (1.0.100.v200706071723-3-Ag8x8FlRtR_NWNVFQ9QBE) "EMF Model Transaction
>>>>>> Examples"
>>>>>> org.eclipse.emf.transaction.examples.source (1.0.100.v200706071723) "EMF
>>>>>> org.eclipse.emf.transaction.source
>>>>>> (1.1.2.v200710151610-208a8s733G4A3F5H88) "EMF Model Transaction Source"
>>>>>> org.eclipse.emf.validation (1.1.1.v200708161445-318Z9oA55P5O6O8IC_) "EMF
>>>>>> Validation Framework Core"
>>>>>> org.eclipse.emf.validation.doc (1.1.0.v200706071520-21-8s733G3E4C5_88)
>>>>>> "EMF Validation Framework Documentation"
>>>>>> (1.1.0.v200706071520-52_7AgI99h9cAZDRKI) "EMF Validation Framework
>>>>>> Example"
>>>>>> org.eclipse.emf.validation.examples.source (1.1.0.v200706071520) "EMF
>>>>>> org.eclipse.emf.validation.ocl (1.1.0.v200706071520-10-7w311817182631)
>>>>>> "EMF Validation Framework OCL Integration"
>>>>>> org.eclipse.emf.validation.ocl.source
>>>>>> (1.1.0.v200706071520-10-7w311817182631) "EMF Validation Framework OCL
>>>>>> Integration Source"
>>>>>> org.eclipse.emf.validation.source
>>>>>> (1.1.1.v200708161445-318Z9oA55P5O6O8IC_) "EMF Validation Framework Source"
>>>>>> org.eclipse.emf.workspace (1.1.2.v200711281719-208a8s733G4A3F5H88) "EMF
>>>>>> Model Transaction Workbench Integration Core"
>>>>>> org.eclipse.emf.workspace.doc (1.1.0.v200706071723-10-7w311817182834)
>>>>>> "EMF Model Transaction Workbench Integration Documentation"
>>>>>> (1.0.100.v200706071723-3-Ag9oA55P5M5P8PAD) "EMF Model Transaction
>>>>>> org.eclipse.emf.workspace.examples.source (1.0.100.v200706071723) "EMF
>>>>>> org.eclipse.emf.workspace.source
>>>>>> (1.1.2.v200711281719-208a8s733G4A3F5H88) "EMF Model Transaction
>>>>>> org.eclipse.eodm.doc (0.9.1.v200710090302) "Plugin.name (Incubation)"
>>>>>> org.eclipse.gef (3.3.1.v20070814) "Graphical Editing Framework"
>>>>>> org.eclipse.gef.sdk (3.3.1.v20070814) "Graphical Editing Framework
>>>>>> org.eclipse.gef.source (3.3.1.v20070814) "Graphical Editing Framework
>>>>>> org.eclipse.gmf (1.0.101.v20080114-2222-7d-EVOEYjiMWaZ4YWeu3dCypkm71)
>>>>>> org.eclipse.gmf.doc (1.1.0.v20070809-0000-10-7w3119122503333) "Graphical
>>>>>> Modeling Framework Documentation"
>>>>>> org.eclipse.gmf.examples.pde (1.1.0.v20070809-0000-2-8Y8s733G3I3K13333)
>>>>>> "Graphical Modeling Framework Examples"
>>>>>> org.eclipse.gmf.sdk (2.0.1.v20070921-0000-7f79CSEMnY9yMVlrV-40M7vY1p8w)
>>>>>> "Graphical Modeling Framework SDK"
>>>>>> org.eclipse.gmf.sdk.source (2.0.1.v20070921-0000) "Graphical Modeling
>>>>>> org.eclipse.gmf.source
>>>>>> (1.0.101.v20080114-2222-7d-EVOEYjiMWaZ4YWeu3dCypkm71) "Graphical
>>>>>> org.eclipse.jdt (3.3.1.r331_v20070629-7o7jE72EDlXAbqAcnbmyg1rf8RIL)
>>>>>> org.eclipse.jdt.source
>>>>>> (3.3.1.r331_v20070629-7o7jE72EDlXAbqAcnbmyg1rf8RIL) "Eclipse Java
>>>>>> org.eclipse.jet (0.8.1.v20070913-17E19oA55P5V_8) "Eclipse Modeling
>>>>>> Framework Technologies - JET (Incubation)"
>>>>>> org.eclipse.jet.doc (0.8.0.v20070913-07707w31181_31) "Eclipse Modeling
>>>>>> Framework Technologies - JET Documentation (Incubation)"
>>>>>> org.eclipse.jet.examples (0.8.0.v20070913-077-7w31181_24) "Eclipse
>>>>>> Modeling Framework Technologies - JET Examples (Incubation)"
>>>>>> org.eclipse.jet.source (0.8.1.v20070913) "Eclipse Model to Text - JET SDK"
>>>>>> org.eclipse.mylyn_feature (2.1.0.v20070927-0900) "Mylyn"
>>>>>> org.eclipse.mylyn.bugzilla_feature (2.1.0.v20070927-0900) "Mylyn"
>>>>>> org.eclipse.mylyn.context_feature (2.1.0.v20070927-0900) "Mylyn"
>>>>>> org.eclipse.mylyn.ide_feature (2.1.0.v20070927-0900) "Mylyn"
>>>>>> org.eclipse.mylyn.java_feature (2.1.0.v20070927-0900) "Mylyn"
>>>>>> org.eclipse.mylyn.pde_feature (2.1.0.v20070927-0900) "Mylyn"
>>>>>> org.eclipse.ocl (1.1.1.v200707131415-3209oA55P5N7F8JDH) "Object
>>>>>> Constraint Language (OCL) 2.0 Parser/Interpreter"
>>>>>> org.eclipse.ocl.doc (1.1.0.v200706071450-21-8s733G3E3G5AC3) "Object
>>>>>> Constraint Language (OCL) 2.0 Documentation"
>>>>>> org.eclipse.ocl.source (1.1.1.v200707131415-3209oA55P5N7F8JDH) "Object
>>>>>> org.eclipse.ocl.uml (1.1.1.v200707131415-1007w311818242526) "OCL 2.0
>>>>>> Binding for UML"
>>>>>> org.eclipse.ocl.uml.source (1.1.1.v200707131415-1007w311818242526) "OCL
>>>>>> org.eclipse.pde (3.3.2.R33x_r20071022-7N7M4CYWLBCz-yHkMIuHN) "Eclipse
>>>>>> Plug-in Development Environment"
>>>>>> org.eclipse.pde.source (3.3.2.R33x_r20071022-7N7M4CYWLBCz-yHkMIuHN)
>>>>>> org.eclipse.platform (3.3.2.R33x_v20071022-_19UEksF-G8Yc6bUv3Dz)
>>>>>> "Eclipse Platform"
>>>>>> org.eclipse.platform.source (3.3.2.R33x_v20071022-_19UEksF-G8Yc6bUv3Dz)
>>>>>> org.eclipse.rcp (3.3.2.R33x_r20071022-8y8eE9CEV3FspP8HJrY1M2dS) "Eclipse
>>>>>> RCP"
>>>>>> org.eclipse.rcp.source (3.3.2.R33x_r20071022-8y8eE9CEV3FspP8HJrY1M2dS)
>>>>>> Diagramming Source"
>>>>>> Source"
>>>>>> (Incubation)"
>>>>>> (XSD) Source"
>>>>>> [Resolved]
>>>>>> [Resolved]
>>>>>> LPG" [Resolved]
>>>>>> [Resolved]
>>>>>> [Resolved]
>>>>>> [Resolved]
>>>>>> Plug-in" [Resolved]
>>>>>> [Resolved]
>>>>>> Plug-in" [Resolved]
>>>>>> [Resolved]
>>>>>> [Resolved]
>>>>>> Mechanism" [Active]
>>>>>> [Resolved]
>>>>>> Language" [Active]
>>>>>> [Active]
>>>>>> [Active]
>>>>>> [Active]
>>>>>> Draw2d" [Active]
>>>>>> [Starting]
>>>>>> [Starting]
>>>>>> [Starting]
>>>>>> Support" [Starting]
>>>>>> Model" [Active]
>>>>>> Support" [Active]
>>>>>> [Starting]
>>>>>> Model" [Active]
>>>>>> Support" [Starting]
>>>>>> Support" [Starting]
>>>>>> [Starting]
>>>>>> [Starting]
>>>>>> [Starting]
>>>>>> Mapping" [Starting]
>>>>>> [Starting]
>>>>>> Mapping" [Starting]
>>>>>> Core" [Active]
>>>>>> [Resolved]
>>>>>> Source" [Resolved]
>>>>>> [Starting]
>>>>>> [Starting]
>>>>>> [Starting]
>>>>>> [Starting]
>>>>>> Container" [Active]
>>>>>> [Active]
>>>>>> Service" [Starting]
>>>>>> Servlet" [Starting]
>>>>>> [Resolved]
>>>>>> Mechanism" [Active]
>>>>>> Support" [Active]
>>>>>> [Starting]
>>>>>> Plug-in" [Starting]
>>>>>> [Starting]
>>>>>> Support" [Starting]
>>>>>> UI" [Starting]
>>>>>> Plug-in" [Active]
>>>>>> Plugin" [Active]
>>>>>> [Active]
>>>>>> Plug-in" [Starting]
>>>>>> Support" [Active]
>>>>>> [Active]
>>>>>> Support" [Active]
>>>>>> Plugin" [Active]
>>>>>> Core" [Active]
>>>>>> UI" [Active]
>>>>>> [Active]
>>>>>> UI" [Active]
>>>>>> Additions" [Active]
| Re: Problem : Audit constraints [message #176237 is a reply to message #176201] |
Thu, 06 March 2008 11:26   |
I'm assuming you have alldependencies installed and that there are no
exceptions in the log... ?
On 3/6/08 11:06 AM, in artice fqp4r0$2vs$1@build.eclipse.org, "Philippe
> If I use Java langage to implemnt my Audit constraint, it works
> implemnted).
> (is there a prblem in my eclipse plugin configuration ?)
> Thanks.
> Philippe
> Richard Gronback écrit :
>> language. You'reusing OCL, so try using this statement insead:
>> Bet,
>> Rich
>>> Thereis an empty class JavaAudits in my MindmapValidationProviders.
>>> So it seems that my audit constraint ha not been implemened, but I
>>> don't know why... My project is an CVS project : is there some prblems
>>> Regards,
>>> Philippe
>>> Richard Gronback a écrt:
>>>> classes.
>>>> - Rich
>>>>> The alidaton Enabled and Validation Decorators properties are set to
>>>>> true. However, there is no source code in my ..mindmap.diagram project.
>>>>> Is it normal ?
>>>> The only place where my ocl constraint is displayed is in my plgin.xml
>>>>> file :
>>>>> <extenion point="org.eclipse.emf.validation.constraintroviders">
>>>>> <category id="org.eclipse.gm.examples.mindmap.audits
>>>>> <![CDATA[Audits to dtect problems in mindmap diagrams.]]>
>>>>> </category>
>>>>> <packagenamespaceUri="http://www.example.org/mindmap"/>
>>>>> <cnstraints
>>>>> lang="OCL"
>>>>> name="Cyclic relationshp check"
>>>>> mode="Batch"
>>>>> between Topic relationships]></description>
>>>>> beween two Topic elements.]]></message>
>>>> </constraint>
>>>>> lang="OCL"
>>>>> mode="Batch"
>>>>> </constraint>
>>>>> </constraints>
>>>> </extension>
>>>>>> Typically, people frget to set the Validation Enabled property to true
>>>>>> in
>>>>>> a
>>>>>> breakpoint i the validator to see what's going on.
>>>>>> - Rich
>>>>>> BLANC" blanc.philippe83@gmail.com> wrote:
>>>>>>> Hi,
>>>>>>> I'm new with GMF.
>>>>>>> I've done the tutoial about mindmap model, and then downloaded the
>>>>>>> constraints.
>>>>>>> I built a mndmap diagram with a null named Topic element. When I
>>>>>>> audit rule "name.size() > 0. However, nothing happens and the
>>>>>>> Any ideas ?
>>>>>>> Best regards,
>>>>>> Philippe
>>>>>>> Configuration :
>>>>>>> Eclipse 3.3.1.1
>>>>>>> *** Features:
>>>>>>> Client"
>>>>>>> Generator"
>>>>>>> Generation"
>>>>>>> Generation UI"
>>>>>>> Generator UI"
>>>>>>> Support"
>>>>>>> Support"
>>>>>>> Objects (SDO)"
>>>>>>> Query"
>>>>>>> (EMF) Source"
>>>>>>> Examples"
>>>>>>> Example"
>>>>>>> Integration Source"
>>>>>>> Source"
>>>>>>> SDK"
>>>>>>> Binding for UML"
>>>>>>> "Eclipse Platform"
>>>>>>> RCP"
>>>>>>> org.eclipse.sdk (3.3.2.R33x_r20071022-7M7J7C_Mu2gop0b_GAwplOBhyuKO)
>>>>>>> org.eclipse.uml2 (2.1.1.v200708301222) "UML2"
>>>>>>> org.eclipse.uml2.diagram (0.7.101.v200802260712) "UML2 Diagramming
>>>>>>> org.eclipse.uml2.diagram.source (0.7.101.v200802260712) "UML2
>>>>>>> Diagramming Source"
>>>>>>> org.eclipse.uml2.examples.source (2.1.0.v200706251652) "UML2 Examples
>>>>>>> Source"
>>>>>>> org.eclipse.uml2tools (0.7.101.v200802260712) "UML2 Tools Plug-in
>>>>>>> (Incubation)"
>>>>>>> org.eclipse.uml2tools.doc (0.7.0.v200802260712) "UML2 Tools
>>>>>>> org.eclipse.xsd (2.3.2.v200802051830) "XML Schema Infoset Model (XSD)"
>>>>>>> org.eclipse.xsd.doc (2.3.2.v200802051830) "XML Schema Infoset Model
>>>>>>> (XSD) Programmers Guide"
>>>>>>> org.eclipse.xsd.ecore.converter (2.3.2.v200802051830) "XML Schema
>>>>>>> Infoset Model (XSD) - org.eclipse.xsd.ecore.converter"
>>>>>>> org.eclipse.xsd.edit (2.3.0.v200802051830) "XML Schema Edit Framework"
>>>>>>> org.eclipse.xsd.editor (2.3.0.v200802051830) "XML Schema Editor"
>>>>>>> org.eclipse.xsd.mapping (2.3.0.v200802051830) "XML Schema Infoset Model
>>>>>>> (XSD) - org.eclipse.xsd.mapping"
>>>>>>> org.eclipse.xsd.mapping.editor (2.3.0.v200802051830) "XML Schema Infoset
>>>>>>> Model (XSD) - org.eclipse.xsd.mapping.editor"
>>>>>>> org.eclipse.xsd.source (2.3.2.v200802051830) "XML Schema Infoset Model
>>>>>>> (XSD) Source"
>>>>>>> org.topcased.modeler.sam (1.3.0.v200802191607) "SAM Editor"
>>>>>>> *** Plug-in Registry:
>>>>>>> com.ibm.icu (3.6.1.v20070906) "International Components for Unicode for
>>>>>>> Java (ICU4J)" [Active]
>>>>>>> com.ibm.icu.source (3.6.1.v20070906) "International Components for
>>>>>>> Unicode for Java (ICU4J) source plug-in" [Resolved]
>>>>>>> com.jcraft.jsch (0.1.31) "JSch" [Resolved]
>>>>>>> javax.servlet (2.4.0.v200706111738) "Servlet API Bundle" [Resolved]
>>>>>>> javax.servlet.jsp (2.0.0.v200706191603) "Java Server Pages API Bundle"
>>>>>>> [Resolved]
>>>>>>> javax.servlet.jsp.source (2.0.0.v200706191603) "Java Server Pages API
>>>>>>> Source Bundle" [Resolved]
>>>>>>> javax.servlet.source (2.4.0.v200706111738) "Servlet API Source Bundle"
>>>>>>> [Resolved]
>>>>>>> net.sourceforge.lpg.lpgjavaruntime (1.1.0.v200706111738) "SourceForge
>>>>>>> LPG" [Resolved]
>>>>>>> net.sourceforge.lpg.lpgjavaruntime.source (1.1.0.v200706111738)
>>>>>>> "SourceForge LPG Source Bundle" [Resolved]
>>>>>>> org.apache.ant (1.7.0.v200706080842) "Apache Ant" [Resolved]
>>>>>>> org.apache.ant.source (1.7.0.v200706080842) "Apache Ant Source"
>>>>>>> [Resolved]
>>>>>>> org.apache.batik.bridge (1.6.0.v200706111724) "Apache Batik
>>>>>>> Bridge/GVT/Scripting" [Resolved]
>>>>>>> org.apache.batik.bridge.source (1.6.0.v200706111724) "Apache Batik
>>>>>>> Bridge/GVT/Scripting Source Bundle" [Resolved]
>>>>>>> org.apache.batik.css (1.6.0.v200706111724) "Apache Batik CSS" [Resolved]
>>>>>>> org.apache.batik.css.source (1.6.0.v200706111724) "Apache Batik CSS
>>>>>>> org.apache.batik.dom (1.6.0.v200706111724) "Apache Batik DOM" [Resolved]
>>>>>>> org.apache.batik.dom.source (1.6.0.v200706111724) "Apache Batik DOM
>>>>>>> org.apache.batik.dom.svg (1.6.0.v200706111724) "Apache Batik SVG DOM"
>>>>>>> [Resolved]
>>>>>>> org.apache.batik.dom.svg.source (1.6.0.v200706111724) "Apache Batik SVG
>>>>>>> DOM Source Bundle" [Resolved]
>>>>>>> org.apache.batik.ext.awt (1.6.0.v200706111724) "Apache Batik AWT
>>>>>>> Utilities" [Resolved]
>>>>>>> org.apache.batik.ext.awt.source (1.6.0.v200706111724) "Apache Batik AWT
>>>>>>> Utilities Source Bundle" [Resolved]
>>>>>>> org.apache.batik.parser (1.6.0.v200706111724) "Apache Batik Parser"
>>>>>>> [Resolved]
>>>>>>> org.apache.batik.parser.source (1.6.0.v200706111724) "Apache Batik
>>>>>>> Parser Source Bundle" [Resolved]
>>>>>>> org.apache.batik.svggen (1.6.0.v200706111724) "Apache Batik SVG
>>>>>>> Generation" [Resolved]
>>>>>>> org.apache.batik.svggen.source (1.6.0.v200706111724) "Apache Batik SVG
>>>>>>> Generation Source Bundle" [Resolved]
>>>>>>> org.apache.batik.transcoder (1.6.0.v200706111724) "Apache Batik
>>>>>>> Transcoder" [Resolved]
>>>>>>> org.apache.batik.transcoder.source (1.6.0.v200706111724) "Apache Batik
>>>>>>> Transcoder Source Bundle" [Resolved]
>>>>>>> org.apache.batik.util (1.6.0.v200706111724) "Apache Batik Utilities"
>>>>>>> [Resolved]
>>>>>>> org.apache.batik.util.gui (1.6.0.v200706111724) "Apache Batik GUI
>>>>>>> org.apache.batik.util.gui.source (1.6.0.v200706111724) "Apache Batik GUI
>>>>>>> org.apache.batik.util.source (1.6.0.v200706111724) "Apache Batik
>>>>>>> org.apache.batik.xml (1.6.0.v200706111724) "Apache Batik XML" [Resolved]
>>>>>>> org.apache.batik.xml.source (1.6.0.v200706111724) "Apache Batik XML
>>>>>>> org.apache.commons.el (1.0.0.v200706111724) "Apache Commons JSP 2.0
>>>>>>> Expression Language Interpreter" [Resolved]
>>>>>>> org.apache.commons.el.source (1.0.0.v200706111724) "Apache Commons JSP
>>>>>>> 2.0 Expression Language Interpreter Source" [Resolved]
>>>>>>> org.apache.commons.logging (1.0.4.v200706111724) "Apache Commons Logging
>>>>>>> Plug-in" [Resolved]
>>>>>>> org.apache.commons.logging.source (1.0.4.v200706111724) "Apache Commons
>>>>>>> Logging Plug-in Source" [Resolved]
>>>>>>> org.apache.jasper (5.5.17.v200706111724) "Apache Jasper 2 Plug-in"
>>>>>>> [Resolved]
>>>>>>> org.apache.jasper.source (5.5.17.v200706111724) "Apache Jasper 2 Source
>>>>>>> Plug-in" [Resolved]
>>>>>>> org.apache.lucene (1.9.1.v200706111724) "Apache Lucene" [Resolved]
>>>>>>> org.apache.lucene.analysis (1.9.1.v200706181610) "Apache Lucene
>>>>>>> Analysis" [Resolved]
>>>>>>> org.apache.lucene.analysis.source (1.9.1.v200706181610) "Apache Lucene
>>>>>>> Analysis Source" [Resolved]
>>>>>>> org.apache.lucene.source (1.9.1.v200706111724) "Apache Lucene Source"
>>>>>>> [Resolved]
>>>>>>> org.apache.xerces (2.8.0.v200705301630) "Apache Xerces-J" [Resolved]
>>>>>>> org.apache.xml.resolver (1.1.0.v200705310020) "Apache XmlResolver"
>>>>>>> [Resolved]
>>>>>>> org.eclipse.ant.core (3.1.200.v20070522) "Ant Build Tool Core"
>>>>>>> [Starting]
>>>>>>> org.eclipse.ant.ui (3.2.200.v20070825_r331) "Ant UI" [Active]
>>>>>>> org.eclipse.compare (3.3.1.r33x_20070906) "Compare Support" [Active]
>>>>>>> org.eclipse.core.boot (3.1.100.v20060603) "Core Boot" [Starting]
>>>>>>> org.eclipse.core.commands (3.3.0.I20070605-0010) "Commands" [Resolved]
>>>>>>> org.eclipse.core.contenttype (3.2.100.v20070319) "Eclipse Content
>>>>>>> Mechanism" [Active]
>>>>>>> org.eclipse.core.databinding (1.0.1.M20070822-0800) "JFace Data Binding"
>>>>>>> [Resolved]
>>>>>>> org.eclipse.core.databinding.beans (1.0.1.M20070910-0800b) "JFace Data
>>>>>>> Binding for JavaBeans" [Resolved]
>>>>>>> org.eclipse.core.expressions (3.3.0.v20070606-0010) "Expression
>>>>>>> Language" [Active]
>>>>>>> org.eclipse.core.filebuffers (3.3.1.r331_v20070829) "File Buffers"
>>>>>>> [Active]
>>>>>>> org.eclipse.core.filesystem (1.1.0.v20070606) "Core File Systems"
>>>>>>> [Active]
>>>>>>> org.eclipse.core.filesystem.win32.x86 (1.1.0.v20070510) "Core File
>>>>>>> System for Windows" [Resolved]
>>>>>>> org.eclipse.core.jobs (3.3.1.R33x_v20070709) "Eclipse Jobs Mechanism"
>>>>>>> [Active]
>>>>>>> org.eclipse.core.net (1.0.1.r33x_20070709) "Internet Connection
>>>>>>> Management" [Active]
>>>>>>> org.eclipse.core.resources (3.3.0.v20070604) "Core Resource Management"
>>>>>>> [Active]
>>>>>>> org.eclipse.core.resources.compatibility (3.2.100.v20070502) "Core
>>>>>>> Resource Management Compatibility Fragment" [Resolved]
>>>>>>> org.eclipse.core.resources.win32 (3.3.0.v20070226) "Core Resource
>>>>>>> Management Win32 Fragment" [Resolved]
>>>>>>> org.eclipse.core.runtime (3.3.100.v20070530) "Core Runtime" [Active]
>>>>>>> org.eclipse.core.runtime.compatibility (3.1.200.v20070502) "Core Runtime
>>>>>>> Plug-in Compatibility" [Active]
>>>>>>> org.eclipse.core.runtime.compatibility.auth (3.2.100.v20070502)
>>>>>>> "Authorization Compatibility Plug-in" [Active]
>>>>>>> org.eclipse.core.runtime.compatibility.registry (3.2.100.v20070316)
>>>>>>> "Eclipse Registry Compatibility Fragment" [Resolved]
>>>>>>> org.eclipse.core.variables (3.2.0.v20070426) "Core Variables" [Starting]
>>>>>>> org.eclipse.cvs (1.0.0.v20070606) "Eclipse CVS Client" [Starting]
>>>>>>> "Eclipse CVS Client SDK" [Resolved]
>>>>>>> org.eclipse.debug.core (3.3.1.v20070731_r331) "Debug Core" [Active]
>>>>>>> org.eclipse.debug.ui (3.3.1.v20070731_r331) "Debug UI" [Active]
>>>>>>> org.eclipse.draw2d (3.2.100.v20070529) "Graphical Editing Framework
>>>>>>> Draw2d" [Active]
>>>>>>> org.eclipse.draw2d.doc.isv (3.2.100.v20070529) "Graphical Editing
>>>>>>> Framework Draw2d Documentation" [Starting]
>>>>>>> org.eclipse.emf (2.3.0.v200802051830) "Eclipse Modeling Framework (EMF)"
>>>>>>> [Starting]
>>>>>>> org.eclipse.emf.activities (2.3.0.v200802051830) "EMF Activities"
>>>>>>> [Starting]
>>>>>>> org.eclipse.emf.ant (2.3.1.v200802051830) "EMF Ant Tasks" [Starting]
>>>>>>> org.eclipse.emf.cheatsheets (2.3.0.v200802051830) "EMF Cheat Sheets"
>>>>>>> [Starting]
>>>>>>> Generation" [Starting]
>>>>>>> org.eclipse.emf.codegen.ecore.ui (2.3.0.v200802051830) "EMF Ecore Code
>>>>>>> org.eclipse.emf.codegen.ui (2.3.0.v200802051830) "EMF Template Code
>>>>>>> Generator UI" [Starting]
>>>>>>> org.eclipse.emf.common (2.3.2.v200802051830) "EMF Common" [Active]
>>>>>>> org.eclipse.emf.common.ui (2.3.1.v200802051830) "EMF Common UI" [Active]
>>>>>>> org.eclipse.emf.commonj.sdo (2.3.0.v200802051830) "CommonJ SDO"
>>>>>>> [Starting]
>>>>>>> org.eclipse.emf.converter (2.3.0.v200802051830) "EMF Model Convert
>>>>>>> Support" [Starting]
>>>>>>> (EMF) Programmers Guide" [Starting]
>>>>>>> org.eclipse.emf.ecore (2.3.2.v200802051830) "EMF Ecore" [Active]
>>>>>>> org.eclipse.emf.ecore.change (2.3.0.v200802051830) "EMF Ecore Change
>>>>>>> Model" [Active]
>>>>>>> org.eclipse.emf.ecore.change.edit (2.3.0.v200802051830) "EMF Ecore
>>>>>>> Change Edit Support" [Starting]
>>>>>>> Support" [Active]
>>>>>>> [Starting]
>>>>>>> org.eclipse.emf.ecore.sdo (2.3.0.v200802051830) "EMF Service Data
>>>>>>> Objects (SDO)" [Starting]
>>>>>>> org.eclipse.emf.ecore.sdo.doc (2.3.1.v200802051830) "EMF Service Data
>>>>>>> Objects (SDO) Programmers Guide" [Starting]
>>>>>>> org.eclipse.emf.ecore.sdo.edit (2.3.0.v200802051830) "EMF Service Data
>>>>>>> Objects (SDO) Edit Support" [Starting]
>>>>>>> org.eclipse.emf.ecore.sdo.editor (2.3.0.v200802051830) "EMF Service Data
>>>>>>> Objects (SDO) Editor" [Starting]
>>>>>>> Objects (SDO) Source" [Resolved]
>>>>>>> org.eclipse.emf.ecore.xmi (2.3.2.v200802051830) "EMF XMI" [Active]
>>>>>>> org.eclipse.emf.edit (2.3.2.v200802051830) "EMF Edit" [Active]
>>>>>>> org.eclipse.emf.edit.ui (2.3.1.v200802051830) "EMF Edit UI" [Active]
>>>>>>> org.eclipse.emf.examples (2.3.0.v200802051830) "Eclipse Modeling
>>>>>>> Framework (EMF) Examples" [Starting]
>>>>>>> org.eclipse.emf.examples.generator.validator (1.0.0.v200802051830)
>>>>>>> "Validator Generator Extension" [Starting]
>>>>>>> org.eclipse.emf.examples.library (2.3.0.v200802051830) "Extended Library
>>>>>>> Model" [Active]
>>>>>>> org.eclipse.emf.examples.library.edit (2.3.0.v200802051830) "Extended
>>>>>>> Library Edit" [Starting]
>>>>>>> org.eclipse.emf.examples.library.editor (2.3.0.v200802051830) "Extended
>>>>>>> Framework (EMF) Examples" [Resolved]
>>>>>>> org.eclipse.emf.exporter (2.3.0.v200802051830) "EMF Model Export
>>>>>>> Support" [Starting]
>>>>>>> org.eclipse.emf.exporter.html (2.3.0.v200802051830) "HTML Exporter for
>>>>>>> EMF models" [Starting]
>>>>>>> org.eclipse.emf.importer (2.3.1.v200802051830) "EMF Model Import
>>>>>>> Support" [Starting]
>>>>>>> org.eclipse.emf.importer.ecore (2.3.1.v200802051830) "EMF Ecore
>>>>>>> Importer" [Starting]
>>>>>>> org.eclipse.emf.importer.java (2.3.1.v200802051830) "EMF Annotated Java
>>>>>>> org.eclipse.emf.importer.rose (2.3.1.v200802051830) "EMF Rose Importer"
>>>>>>> [Starting]
>>>>>>> org.eclipse.emf.java (2.3.0.v200802051830) "EMF Java" [Starting]
>>>>>>> org.eclipse.emf.java.edit (2.3.0.v200802051830) "EMF Java Edit"
>>>>>>> [Starting]
>>>>>>> org.eclipse.emf.java.editor (2.3.0.v200802051830) "EMF Java Editor"
>>>>>>> [Starting]
>>>>>>> org.eclipse.emf.mapping (2.3.0.v200802051830) "EMF Mapping" [Starting]
>>>>>>> org.eclipse.emf.mapping.ecore (2.3.0.v200802051830) "Eclipse Modeling
>>>>>>> Framework (EMF) - org.eclipse.emf.mapping.ecore" [Starting]
>>>>>>> org.eclipse.emf.mapping.ecore.editor (2.3.0.v200802051830) "Eclipse
>>>>>>> Modeling Framework (EMF) - org.eclipse.emf.mapping.ecore.editor"
>>>>>>> [Starting]
>>>>>>> org.eclipse.emf.mapping.ecore2ecore (2.3.0.v200802051830) "Ecore to
>>>>>>> Ecore Mapping" [Starting]
>>>>>>> org.eclipse.emf.mapping.ecore2ecore.editor (2.3.0.v200802051830) "Ecore
>>>>>>> to Ecore Mapping Editor" [Starting]
>>>>>>> org.eclipse.emf.mapping.ecore2xml (2.3.0.v200802051830) "Ecore to XML
>>>>>>> Mapping" [Starting]
>>>>>>> org.eclipse.emf.mapping.ecore2xml.ui (2.3.0.v200802051830) "Ecore to XML
>>>>>>> Mapping UI" [Starting]
>>>>>>> org.eclipse.emf.mapping.ui (2.3.0.v200802051830) "EMF Mapping UI"
>>>>>>> [Starting]
>>>>>>> org.eclipse.emf.mapping.xsd2ecore (2.3.0.v200802051830) "XSD to Ecore
>>>>>>> Mapping" [Starting]
>>>>>>> org.eclipse.emf.mapping.xsd2ecore.editor (2.3.0.v200802051830) "XSD to
>>>>>>> org.eclipse.emf.ocl (1.1.1.v200709121956) "Object Constraint Language
>>>>>>> (OCL) 2.0 Compatibility API" [Starting]
>>>>>>> org.eclipse.emf.ocl.doc (1.1.0.v200706071450) "Object Constraint
>>>>>>> Language (OCL) 2.0 Compatibility API Documentation" [Starting]
>>>>>>> org.eclipse.emf.ocl.examples (1.1.0.v200706071450) "Object Constraint
>>>>>>> Language (OCL) 2.0 Examples" [Starting]
>>>>>>> org.eclipse.emf.ocl.examples.interpreter (1.1.0.v200706071450) "Object
>>>>>>> Constraint Language (OCL) 2.0 Interpreter Example" [Starting]
>>>>>>> Constraint Language (OCL) 2.0 Examples Source" [Resolved]
>>>>>>> "Object Constraint Language (OCL) 2.0 Compatibility Source" [Resolved]
>>>>>>> org.eclipse.emf.query (1.1.1.v200711281714) "EMF Model Query" [Starting]
>>>>>>> org.eclipse.emf.query.doc (1.1.0.v200706071712) "EMF Model Query
>>>>>>> org.eclipse.emf.query.examples (1.1.0.v200706131231) "EMF Model Query
>>>>>>> org.eclipse.emf.query.examples.ocl (1.1.0.v200706071712) "EMF Model
>>>>>>> Query OCL Query Example" [Starting]
>>>>>>> Query Examples Source" [Resolved]
>>>>>>> org.eclipse.emf.query.examples.statements (1.0.100.v200706131231) "EMF
>>>>>>> Model Query Example" [Starting]
>>>>>>> org.eclipse.emf.query.ocl (1.1.0.v200706071712) "EMF Model Query OCL
>>>>>>> Integration" [Starting]
>>>>>>> "EMF Model Query OCL Integration Source" [Resolved]
>>>>>>> "EMF Model Query Source" [Resolved]
>>>>>>> (EMF) Source" [Resolved]
>>>>>>> org.eclipse.emf.transaction (1.1.2.v200712061832) "EMF Model Transaction
>>>>>>> Core" [Active]
>>>>>>> org.eclipse.emf.transaction.doc (1.1.0.v200706071723) "EMF Model
>>>>>>> Transaction Documentation" [Starting]
>>>>>>> org.eclipse.emf.transaction.examples (1.0.100.v200706071723) "EMF Model
>>>>>>> Transaction Examples" [Starting]
>>>>>>> Model Transaction Examples Source" [Resolved]
>>>>>>> [Resolved]
>>>>>>> org.eclipse.emf.transaction.ui (1.0.100.v200706071723) "EMF Model
>>>>>>> Transaction UI" [Starting]
>>>>>>> org.eclipse.emf.validation (1.1.1.v200708161445) "EMF Validation
>>>>>>> Framework Core" [Active]
>>>>>>> org.eclipse.emf.validation.doc (1.1.0.v200706071520) "EMF Validation
>>>>>>> Framework Documentation" [Starting]
>>>>>>> org.eclipse.emf.validation.examples (1.1.0.v200706131235) "EMF
>>>>>>> Validation Framework Example" [Starting]
>>>>>>> org.eclipse.emf.validation.examples.adapter (1.0.100.v200706071520) "EMF
>>>>>>> Validation Framework Adapter Example" [Active]
>>>>>>> org.eclipse.emf.validation.examples.general (1.0.100.v200706071520) "EMF
>>>>>>> Validation Framework Example" [Active]
>>>>>>> org.eclipse.emf.validation.examples.ocl (1.1.0.v200706131235) "EMF
>>>>>>> Validation Framework OCL Constraints Example" [Starting]
>>>>>>> Validation Framework Examples Source" [Resolved]
>>>>>>> org.eclipse.emf.validation.ocl (1.1.0.v200706071520) "EMF Validation
>>>>>>> Framework OCL Integration" [Resolved]
>>>>>>> Source" [Resolved]
>>>>>>> org.eclipse.emf.validation.ui (1.1.0.v200706071520) "EMF Validation
>>>>>>> Framework UI" [Active]
>>>>>>> org.eclipse.emf.validation.ui.ide (1.0.100.v200706071520) "EMF
>>>>>>> Validation Framework UI IDE" [Starting]
>>>>>>> org.eclipse.emf.workspace (1.1.2.v200712061832) "EMF Model Transaction
>>>>>>> Workbench Integration Core" [Active]
>>>>>>> org.eclipse.emf.workspace.doc (1.1.0.v200706071723) "EMF Model
>>>>>>> Transaction Workbench Integration Documentation" [Starting]
>>>>>>> org.eclipse.emf.workspace.examples (1.0.100.v200706071723) "EMF Model
>>>>>>> Transaction Workbench Integration Examples" [Starting]
>>>>>>> org.eclipse.emf.workspace.examples.library.editor
>>>>>>> (1.0.100.v200706071723) "EMF Workbench EXTLibrary Editor" [Starting]
>>>>>>> Model Transaction Workbench Integration Examples Source" [Resolved]
>>>>>>> Workbench Integration Source" [Resolved]
>>>>>>> org.eclipse.emf.workspace.ui (1.0.100.v200706071723) "EMF Model
>>>>>>> Transaction Workbench Integration UI" [Starting]
>>>>>>> org.eclipse.eodm (0.9.1.v200710090302) "pluginName (Incubation)"
>>>>>>> [Starting]
>>>>>>> [Starting]
>>>>>>> org.eclipse.eodm.owl (0.9.1.v200710090302) "pluginName (Incubation)"
>>>>>>> [Starting]
>>>>>>> org.eclipse.eodm.rdf (0.9.1.v200710090302) "pluginName (Incubation)"
>>>>>>> [Starting]
>>>>>>> org.eclipse.eodm.source (0.9.1.v200710090302) "EODM Source" [Resolved]
>>>>>>> org.eclipse.equinox.app (1.0.1.R33x_v20070828) "Equinox Application
>>>>>>> Container" [Active]
>>>>>>> org.eclipse.equinox.common (3.3.0.v20070426) "Common Eclipse Runtime"
>>>>>>> [Active]
>>>>>>> org.eclipse.equinox.http.jetty (1.0.1.R33x_v20070816) "Jetty Http
>>>>>>> Service" [Starting]
>>>>>>> org.eclipse.equinox.http.registry (1.0.0.v20070608) "Http Service
>>>>>>> Registry Extensions" [Resolved]
>>>>>>> org.eclipse.equinox.http.servlet (1.0.1.R33x_v20070816) "Http Services
>>>>>>> Servlet" [Starting]
>>>>>>> org.eclipse.equinox.jsp.jasper (1.0.1.R33x_v20070816) "Jasper Jsp
>>>>>>> Support Bundle" [Starting]
>>>>>>> org.eclipse.equinox.jsp.jasper.registry (1.0.0.v20070607) "Jasper Jsp
>>>>>>> Registry Support Plug-in" [Starting]
>>>>>>> org.eclipse.equinox.launcher (1.0.1.R33x_v20070828) "Equinox Launcher"
>>>>>>> [Resolved]
>>>>>>> org.eclipse.equinox.launcher.win32.win32.x86 (1.0.2.R331_v20071019)
>>>>>>> "Equinox Launcher Win32 X86 Fragment" [Resolved]
>>>>>>> org.eclipse.equinox.preferences (3.2.100.v20070522) "Eclipse Preferences
>>>>>>> Mechanism" [Active]
>>>>>>> org.eclipse.equinox.registry (3.3.1.R33x_v20070802) "Extension Registry
>>>>>>> Support" [Active]
>>>>>>> org.eclipse.gef (3.2.101.v20070814) "Graphical Editing Framework"
>>>>>>> [Active]
>>>>>>> org.eclipse.gef.doc.isv (3.2.100.v20070529) "Graphical Editing Framework
>>>>>>> org.eclipse.gef.examples.ui.pde (3.3.0.v20070529) "Graphical Editing
>>>>>>> Framework Example Plug-ins" [Starting]
>>>>>>> org.eclipse.gmf (1.0.0.v20070809-0000) "Graphical Modeling Framework"
>>>>>>> [Starting]
>>>>>>> org.eclipse.gmf.bridge (1.1.0.v20070809-0000) "GMF Models Bridging
>>>>>>> Plug-in" [Starting]
>>>>>>> org.eclipse.gmf.bridge.trace (1.0.100.v20070809-0000) "GMF Models Bridge
>>>>>>> Tracing Plug-in" [Starting]
>>>>>>> org.eclipse.gmf.bridge.ui (1.1.1.v20080207-0207) "GMF Tooling UI"
>>>>>>> [Starting]
>>>>>>> org.eclipse.gmf.bridge.ui.dashboard (2.0.0.v20070809-0000) "GMF
>>>>>>> Dashboard" [Starting]
>>>>>>> org.eclipse.gmf.codegen (2.0.2.v20080207-0207) "GMF GenModel and Code
>>>>>>> org.eclipse.gmf.codegen.edit (2.0.1.v20071124-0000) "GMF GenModel Edit
>>>>>>> Support" [Starting]
>>>>>>> org.eclipse.gmf.codegen.lite (1.1.1.v20070921-0000) "GMF Pure-GEF Code
>>>>>>> Generation Plug-in" [Starting]
>>>>>>> org.eclipse.gmf.codegen.lite.ui (1.1.0.v20070809-0000) "GMF Pure-GEF
>>>>>>> Code Generation UI" [Starting]
>>>>>>> org.eclipse.gmf.codegen.ui (1.1.0.v20070809-0000) "GMF Code Generation
>>>>>>> UI" [Starting]
>>>>>>> org.eclipse.gmf.common (1.1.0.v20070809-0000) "GMF Tooling Commons
>>>>>>> Plug-in" [Active]
>>>>>>> org.eclipse.gmf.doc (1.1.0.v20080114-2222) "Graphical Modeling Framework
>>>>>>> org.eclipse.gmf.doc.ui (1.1.0.v20070809-0000) "GMF Documentation
>>>>>>> Cheatsheets" [Starting]
>>>>>>> org.eclipse.gmf.ecore.editor (2.0.2.v20080207-0207) "ECore Sample
>>>>>>> Diagram Plugin" [Active]
>>>>>>> org.eclipse.gmf.examples (1.0.0.v20070809-0000) "Graphical Modeling
>>>>>>> Framework Examples" [Resolved]
>>>>>>> org.eclipse.gmf.examples.mindmap (1.0.0) "Mindmap Model" [Active]
>>>>>>> org.eclipse.gmf.examples.mindmap.diagram (1.0.0.200803051538) "Mindmap
>>>>>>> Plugin" [Active]
>>>>>>> org.eclipse.gmf.examples.mindmap.diagram.custom (1.0.0.200803051506)
>>>>>>> "pluginName" [Resolved]
>>>>>>> org.eclipse.gmf.examples.mindmap.edit (1.0.0) "Mindmap Edit Support"
>>>>>>> [Active]
>>>>>>> org.eclipse.gmf.examples.mindmap.editor (1.0.0) "Mindmap Editor"
>>>>>>> [Active]
>>>>>>> org.eclipse.gmf.examples.ui.pde (1.0.100.v20070809-0000) "GMF Examples
>>>>>>> Plug-in" [Starting]
>>>>>>> org.eclipse.gmf.graphdef (2.0.1.v20080207-0207) "GMF Graphical
>>>>>>> Definition" [Resolved]
>>>>>>> org.eclipse.gmf.graphdef.codegen (2.0.1.v20080207-0207) "Graphical
>>>>>>> Definition Code Generator" [Starting]
>>>>>>> org.eclipse.gmf.graphdef.codegen.ui (1.0.100.v20070809-0000) "Graphical
>>>>>>> Definition Code Generator UI Support" [Resolved]
>>>>>>> org.eclipse.gmf.graphdef.edit (2.0.1.v20080207-0207) "GMFGraph Edit
>>>>>>> Support" [Active]
>>>>>>> org.eclipse.gmf.graphdef.editor (1.0.0.v20070809-0000) "gmfgraph Plugin"
>>>>>>> [Active]
>>>>>>> org.eclipse.gmf.map (2.0.0.v20070809-0000) "GMF Mapping Model" [Active]
>>>>>>> org.eclipse.gmf.map.edit (2.0.0.v20070809-0000) "GMF Mapping Edit
>>>>>>> Support" [Active]
>>>>>>> org.eclipse.gmf.map.editor (1.0.0.v20070809-0000) "GMF Mapping Diagram
>>>>>>> Plugin" [Active]
>>>>>>> org.eclipse.gmf.runtime.common.core (1.0.101.v20080118-1415) "GMF Common
>>>>>>> Core" [Active]
>>>>>>> org.eclipse.gmf.runtime.common.ui (1.0.101.v20070921-0000) "GMF Common
>>>>>>> UI" [Active]
>>>>>>> org.eclipse.gmf.runtime.common.ui.action (1.0.100.v20070809-0000) "GMF
>>>>>>> Common UI Action" [Active]
>>>>>>> org.eclipse.gmf.runtime.common.ui.action.ide (1.0.1.v20070809-0000) "GMF
>>>>>>> Common UI Action IDE" [Active]
>>>>>>> org.eclipse.gmf.runtime.common.ui.printing (1.0.1.v20070809-0000) "GMF
>>>>>>> Printing" [Starting]
>>>>>>> org.eclipse.gmf.runtime.common.ui.printing.win32 (1.0.2.v20070809-0000)
>>>>>>> "GMF Printing for Win32" [Resolved]
>>>>>>> org.eclipse.gmf.runtime.common.ui.services (1.0.100.v20070809-0000) "GMF
>>>>>>> Common UI Services" [Active]
| Re: Problem : Audit constraints [message #176267 is a reply to message #176237] |
Thu, 06 March 2008 11:43   |
Arf, finally it works (it seems i had a problem with a dependency).
Thanks for your help Richard.
An other question : is it possible to generate a dialog window with
errors that have occured when users validate the model (same window as
when you validate ecore model)?
>> implemnted).
>> Thanks.
>> Philippe
>>> Bet,
>>> Rich
>>>> Regards,
>>>> Philippe
>>>>> classes.
>>>>> - Rich
>>>>>> Is it normal ?
>>>>>> file :
>>>>>> </category>
>>>>>> <cnstraints
>>>>>> lang="OCL"
>>>>>> mode="Batch"
>>>>> </constraint>
>>>>>> lang="OCL"
>>>>>> mode="Batch"
>>>>>> </constraint>
>>>>>> </constraints>
>>>>> </extension>
>>>>>>> in
>>>>>>> a
>>>>>>> - Rich
>>>>>>>> Hi,
>>>>>>>> I'm new with GMF.
>>>>>>>> constraints.
>>>>>>>> Any ideas ?
>>>>>>>> Best regards,
>>>>>>> Philippe
>>>>>>>> Configuration :
>>>>>>>> Eclipse 3.3.1.1
>>>>>>>> *** Features:
>>>>>>>> Client"
>>>>>>>> Generator"
>>>>>>>> Generation"
>>>>>>>> Generation UI"
>>>>>>>> Generator UI"
>>>>>>>> Support"
>>>>>>>> Support"
>>>>>>>> Objects (SDO)"
>>>>>>>> Query"
>>>>>>>> (EMF) Source"
>>>>>>>> Examples"
>>>>>>>> Example"
>>>>>>>> Integration Source"
>>>>>>>> Source"
>>>>>>>> Framework SDK Developer Resources"
>>>>>>>> Modeling Framework Runtime Developer Resources"
>>>>>>>> SDK"
>>>>>>>> Binding for UML"
>>>>>>>> "Eclipse Platform"
>>>>>>>> RCP"
>>>>>>>> Diagramming Source"
>>>>>>>> Source"
>>>>>>>> (Incubation)"
>>>>>>>> (XSD) Source"
>>>>>>>> [Resolved]
>>>>>>>> [Resolved]
>>>>>>>> LPG" [Resolved]
>>>>>>>> [Resolved]
>>>>>>>> [Resolved]
>>>>>>>> [Resolved]
>>>>>>>> [Resolved]
>>>>>>>> Plug-in" [Resolved]
>>>>>>>> [Resolved]
>>>>>>>> Plug-in" [Resolved]
>>>>>>>> [Resolved]
>>>>>>>> [Resolved]
>>>>>>>> [Starting]
>>>>>>>> Mechanism" [Active]
>>>>>>>> [Resolved]
>>>>>>>> Language" [Active]
>>>>>>>> [Active]
>>>>>>>> [Active]
>>>>>>>> [Active]
>>>>>>>> [Active]
>>>>>>>> Draw2d" [Active]
>>>>>>>> [Starting]
>>>>>>>> [Starting]
>>>>>>>> [Starting]
>>>>>>>> [Starting]
>>>>>>>> Support" [Starting]
>>>>>>>> Model" [Active]
>>>>>>>> Support" [Active]
>>>>>>>> [Starting]
>>>>>>>> Model" [Active]
>>>>>>>> Support" [Starting]
>>>>>>>> Support" [Starting]
>>>>>>>> [Starting]
>>>>>>>> [Starting]
>>>>>>>> [Starting]
>>>>>>>> [Starting]
>>>>>>>> Mapping" [Starting]
>>>>>>>> [Starting]
>>>>>>>> Mapping" [Starting]
>>>>>>>> Core" [Active]
>>>>>>>> [Resolved]
>>>>>>>> Source" [Resolved]
>>>>>>>> [Starting]
>>>>>>>> [Starting]
>>>>>>>> [Starting]
>>>>>>>> [Starting]
>>>>>>>> Container" [Active]
>>>>>>>> [Active]
>>>>>>>> Service" [Starting]
>>>>>>>> Servlet" [Starting]
>>>>>>>> [Resolved]
>>>>>>>> Mechanism" [Active]
>>>>>>>> Support" [Active]
>>>>>>>> [Active]
>>>>>>>> [Starting]
>>>>>>>> Plug-in" [Starting]
>>>>>>>> [Starting]
>>>>>>>> Support" [Starting]
>>>>>>>> UI" [Starting]
>>>>>>>> Plug-in" [Active]
>>>>>>>> Plugin" [Active]
>>>>>>>> &quo
| Re: Problem : Audit constraints [message #176303 is a reply to message #176267] |
Thu, 06 March 2008 12:41   |
Sure, it's possible if you modify the code generation templates, or add yor
own code to what's generated. The "live" mode will present a dialog now to
inform the user,and there's a preference setting to disable.
- Rich
On 3/6/08 11:43 AM, in article fqp6ve$p0k$1@build.eclpse.org, "Philippe
> Arf, finally it works (it seems i had a roblem with a dependency).
> An other question : is it possible to generate dialog window with
> erros that have occured when users validate the model (same window as
>> excetions in the log... ?
>> implemnted).
>>> (is there a prblem in my eclipse plugin configurtion ?)
>>> Thanks.
>>> Philippe
>>>> The JavaAudits class would be pplated if you declared Java as the
>>>> not self.ame.oclIsUndefined()
>>>> Bet,
>>>> Rich
>>>> On 3/6/08 10:18 AM, in article fqp20o$m9t$1build.eclipse.org,"Philipp
>>>>> So i seems that my audit constraint hanot been implemened, but I
>>>>> about eneating source code with VS projects ?
>>>>> Regards,
>>>>> Philippe
>>>>>> Take a loo at the generated *ValidationProvider and ValidateAction
>>>>>> classes.
>>>>>> - Rich
>>>>>>>>>> "Philippe
>>>>>>> Is it normal ?
>>>>>>> file :
>>>>>>> <extenion point="org.clipse.emf.validation.constraintroviders">
>>>>>>> </category>
>>>>>>> <constranProvider cache="true">
>>>>>>> <pckage namespaceUri="http://www.example.org/mindmap"/>
>>>>>>> <cnstraints
>>>>>>> categories="org.eclips.gmf.examples.mindmap.audits">
>>>>>>> lang="OCL"
>>>>>>> mode="Batch"
>>>>>>> <description><![CDAT[This audit detects (simple) cycles
>>>>>>> <messae><![CDATA[A cycle was found in relationships
>>>>>>> <taret class="org.eclipse.gmf.examples.mindmap.Map"/>
>>>>>> </constraint>
>>>>>>> <constraint id="topic.nae"
>>>>>>> lang="OCL"
>>>>>>> mode="Bath"
>>>>>>> <![CDATA[name.siz() > 0]]>
>>>>>>> <target class="org.ecipse.gmf.examples.mindmap.Topic"/>
>>>>>>> </constraint>
>>>>>>> </constraints>
>>>>>>> </onstraintProvider>
>>>>>> </extension>
>>>>>>>> Typicall, people frget to set the Validation Enabled property to true
>>>>>>>> in
>>>>>>>> the Gen Diagram element of the gmgen model. If you're successfully
>>>>>>>> invoking audits using the Diagram > Validate menu, thenI suggest
>>>>>>>> setting
>>>>>>>> a
>>>>>>>> breakpoint i the validator to see what's going o.
>>>>>>>> - Rich
>>>>>>>> On 3/6/08 3:07 AM, in article fqo8n7$eel$1@build.eclipse.org "Philippe
>>>>>>>>> Hi,
>>>>>>>>> 'm new with GMF.
>>>>>>>>> constraints.
>>>>>>>>> validate the model, norally an error should be raised because of the
>>>>>>>>> Any ideas ?
>>>>>>>>>Best regards,
>>>>>>>> Philippe
>>>>>>>>> Configuration :
>>>>>>>>> Eclipse 3.3.1.1
>>>>>>>>> *** Featres:
>>>>>>>>> CVS
>>>>>>>>> Client
>>>>>>>>> (EMF)"
>>>>>>>>> og.eclipse.emf.codegen (2.3.1.v200802051830) "EMF Template Code
>>>>>>>>> Generator"
>>>>>>>>> orgeclipse.emf.codegen.ecore (2.3.2.v200802051830) "EMF Ecore Code
>>>>>>>>> Generation"
>>>>>>>>> org.eclipse.emf.codegen.ecoe.ui (2.3.1.v200802051830) "EMF Ecore Code
>>>>>>>>> Generation UI"
>>>>>>>> Generator UI"
>>>>>>>>> Support"
>>>>>>>>> (EMF)Programmers Guide"
>>>>>>>>> Support"
>>>>>>>>> Editor">>>>>>>>> org.eclipse.emf.ecore.sdo (2.3.1.v200802051830) "EMF Service Data
>>>>>>>>> Objects (SDO)"
>>>>>>>>> org.eclips.emf.ecore.sdo.doc (2.3.2.v200802051830) "EMF Service Data
>>>>>>>>> Objects (SDO Edit Support"
>>>>>>>>> Data
>>>>>>>>> Objects (DO) Editor"
>>>>>>>> Data
>>>>>>>>> org.eclpse.emf.edit.ui (2.3.1.v200802051830) "EMF Edit UI"
>>>>>>>>> Modeling
>>>>>>>>> org.eclipse.emf.mapping (2.3.1.v200802051830) "EMF Mappig "
>>>>>>>>> Framewor (EMF) - org.eclipse.emf.mapping.ecore"
>>>>>>>>> org.eclipse.emf.mapping.ui (2.3.1.v200802051830) "EM Mapping UI"
>>>>>>>>> org.eclipse.emf.cl.doc (1.1.0.v200706071450-10-7w311817182561)
>>>>>>>>> "Object
>>>>>>>>> Constraint Language (OCL) 2.0 Compatbility API Documentation"
>>>>>>>>> org.eclipse.emf.ocl.source (1.1.1.v200709121956-1007w31181_22_67)
>>>>>>>>> Model
>>>>>>>> Query"
>>>>>>>>> Framework
>>>>>>>>> (EMF) Source"
>>>>>>>>> Examples"
>>>>>>>>> "EMF
>>>>>>>>> Source"
>>>>>>>>> "EMF
>>>>>>>>> Example"
>>>>>>>>> Integration Source"
>>>>>>>>> Source"
>>>>>>>>> "EMF
>>>>>>>>> "Graphical
>>>>>>>>> org.eclipse.gmf.sdk
>>>>>>>>> "Eclipse Java Development Tools"
>>>>>>>>> Development Tools SDK"
>>>>>>>>> SDK"
>>>>>>>>> Binding for UML"
>>>>>>>>> "OCL
>>>>>>>>> "Eclipse Platform"
>>>>>>>>> "Eclipse
>>>>>>>>> RCP"
>>>>>>>>> Diagramming Source"
>>>>>>>>> Source"
>>>>>>>>> (Incubation)"
>>>>>>>>> Model
>>>>>>>>> Infoset
>>>>>>>>> (XSD) Source"
>>>>>>>>> for
>>>>>>>>> [Resolved]
>>>>>>>>> [Resolved]
>>>>>>>>> LPG" [Resolved]
>>>>>>>>> [Resolved]
>>>>>>>>> [Resolved]
>>>>>>>>> [Resolved]
>>>>>>>>> [Resolved]
>>>>>>>>> SVG
>>>>>>>>> AWT
>>>>>>>>> [Resolved]
>>>>>>>>> [Resolved]
>>>>>>>>> GUI
>>>>>>>>> [Resolved]
>>>>>>>>> Logging
>>>>>>>>> Plug-in" [Resolved]
>>>>>>>>> Commons
>>>>>>>>> [Resolved]
>>>>>>>>> Source
>>>>>>>>> Plug-in" [Resolved]
>>>>>>>>> [Resolved]
>>>>>>>>> [Resolved]
>>>>>>>>> [Starting]
>>>>>>>>> Mechanism" [Active]
>>>>>>>>> Binding"
>>>>>>>>> [Resolved]
>>>>>>>>> Language" [Active]
>>>>>>>>> [Active]
>>>>>>>>> [Active]
>>>>>>>>> [Active]
>>>>>>>>> Management"
>>>>>>>>> [Active]
>>>>>>>>> Runtime
>>>>>>>>> [Starting]
>>>>>>>>> Draw2d" [Active]
>>>>>>>>> (EMF)"
>>>>>>>>> [Starting]
>>>>>>>>> [Starting]
>>>>>>>>> [Starting]
>>>>>>>>> [Active]
>>>>>>>>> [Starting]
>>>>>>>>> Support" [Starting]
>>>>>>>>> Model" [Active]
>>>>>>>>> Support" [Active]
>>>>>>>>> Editor"
>>>>>>>>> [Starting]
>>>>>>>>> Data
>>>>>>>>> Data
>>>>>>>>> Library
>>>>>>>>> Model" [Active]
>>>>>>>>> "Extended
>>>>>>>>> Modeling
>>>>>>>>> Support" [Starting]
>>>>>>>>> Support" [Starting]
>>>>>>>>> Java
>>>>>>>>> Importer"
>>>>>>>>> [Starting]
>>>>>>>>> [Starting]
>>>>>>>>> [Starting]
>>>>>>>>> [Starting]
>>>>>>>>> "Ecore
>>>>>>>>> Mapping" [Starting]
>>>>>>>>> XML
>>>>>>>>> [Starting]
>>>>>>>>> Mapping" [Starting]
>>>>>>>>> [Starting]
>>>>>>>>> Framework
>>>>>>>>> Transaction
>>>>>>>>> Core" [Active]
>>>>>>>>> Model
>>>>>>>>> "EMF
>>>>>>>>> Source"
>>>>>>>>> [Resolved]
>>>>>>>>> "EMF
>>>>>>>>> "EMF
>>>>>>>>> Source" [Resolved]
>>>>>>>>> [Starting]
>>>>>>>>> [Starting]
>>>>>>>>> [Starting]
>>>>>>>>> [Starting]
| Re: Problem : Audit constraints [message #176345 is a reply to message #176303] |
Fri, 07 March 2008 02:42  |
Ok, thank you very much !
> - Rich
>>> implemnted).
>>>> Thanks.
>>>> Philippe
>>>>> Bet,
>>>>> Rich
>>>>>> Regards,
>>>>>> Philippe
>>>>>>> classes.
>>>>>>> - Rich
>>>>>>>>>>> "Philippe
>>>>>>>> Is it normal ?
>>>>>>>> file :
>>>>>>>> </category>
>>>>>>>> <cnstraints
>>>>>>>> lang="OCL"
>>>>>>>> mode="Batch"
>>>>>>> </constraint>
>>>>>>>> lang="OCL"
>>>>>>>> mode="Bath"
>>>>>>>> </constraint>
>>>>>>>> </constraints>
>>>>>>> </extension>
>>>>>>>>> in
>>>>>>>>> setting
>>>>>>>>> a
>>>>>>>>> - Rich
>>>>>>>>>> Hi,
>>>>>>>>>> 'm new with GMF.
>>>>>>>>>> constraints.
>>>>>>>>>> Any ideas ?
>>>>>>>>>> Best regards,
>>>>>>>>> Philippe
>>>>>>>>>> Configuration :
>>>>>>>>>> Eclipse 3.3.1.1
>>>>>>>>>> *** Featres:
>>>>>>>>>> CVS
>>>>>>>>>> Client
>>>>>>>>>> (EMF)"
>>>>>>>>>> Generator"
>>>>>>>>>> Generation"
>>>>>>>>>> Generation UI"
>>>>>>>>> Generator UI"
>>>>>>>>>> Support"
>>>>>>>>>> Support"
>>>>>>>>>> Objects (SDO)"
>>>>>>>>>> Data
>>>>>>>>> Data
>>>>>>>>>> Modeling
>>>>>>>>>> "Object
>>>>>>>>>> Model
>>>>>>>>> Query"
>>>>>>>>>> Framework
>>>>>>>>>> (EMF) Source"
>>>>>>>>>> Examples"
>>>>>>>>>> "EMF
>>>>>>>>>> Source"
>>>>>>>>>> "EMF
>>>>>>>>>> Example"
>>>>>>>>>> Integration Source"
>>>>>>>>>> Source"
>>>>>>>>>> "EMF
>>>>>>>>>> "Graphical
>>>>>>>>>> org.eclipse.gmf.sdk
>>>>>>>>>> SDK"
>>>>>>>>>> Constraint Language (OCL) 2.0 Source"
>>>>>>>>>> Binding for UML"
>>>>>>>>>> "OCL
>>>>>>>>>> 2.0 Binding for UML Source"
>>>>>>>>>> "Eclipse Plug-in Development Environment Developer Resources"
>>>>>>>>>> "Eclipse Platform"
>>>>>>>>>> "Eclipse
>>>>>>>>>> RCP"
>>>>>>>>>> Diagramming Source"
>>>>>>>>>> Source"
>>>>>>>>>> (Incubation)"
>>>>>>>>>> Model
>>>>>>>>>> Infoset
>>>>>>>>>> (XSD) Source"
>>>>>>>>>> for
>>>>>>>>>> [Resolved]
>>>>>>>>>> [Resolved]
>>>>>>>>>> LPG" [Resolved]
>>>>>>>>>> [Resolved]
>>>>>>>>>> [Resolved]
>>>>>>>>>> [Resolved]
>>>>>>>>>> [Resolved]
>>>>>>>>>> SVG
>>>>>>>>>> AWT
>>>>>>>>>> [Resolved]
>>>>>>>>>> [Resolved]
>>>>>>>>>> GUI
>>>>>>>>>> [Resolved]
>>>>>>>>>> Logging
>>>>>>>>>> Plug-in" [Resolved]
>>>>>>>>>> Commons
>>>>>>>>>> [Resolved]
>>>>>>>>>> Source
>>>>>>>>>> Plug-in" [Resolved]
>>>>>>>>>> [Resolved]
>>>>>>>>>> [Resolved]
>>>>>>>>>> [Starting]
>>>>>>>>>> Mechanism" [Active]
>>>>>>>>>> Binding"
>>>>>>>>>> [Resolved]
>>>>>>>>>> Language" [Active]
>>>>>>>>>> [Active]
>>>>>>>>>> [Active]
>>>>>>>>>> [Active]
>>>>>>>>>> Management"
>>>>>>>>>> [Active]
>>>>>>>>>> Runtime
>>>>>>>>>> [Starting]
>>>>>>>>>> Draw2d" [Active]
>>>>>>>>>> (EMF)"
>>>>>>>>>> [Starting]
>>>>>>>>>> [Starting]
>>>>>>>>>> [Starting]
>>>>>>>>>> [Active]
>>>>>>>>>> [Starting]
>>>>>>>>>> Support" [Starting]
>>>>>>>>>> Model" [Active]
>>>>>>>>>> Support" [Active]
>>>>>>>>>> Editor"
>>>>>>>>>> [Starting]
>>>>>>>>>> Data
>>>>>>>>>> Data
>>>>>>>>>> Library
>>>>>>>>>> Model" [Active]
>>>>>>>>>> "Extended
>>>>>>>>>> Modeling
>>>>>>>>>> Support" [Starting]
>>>>>>>>>> Support" [Starting]
>>>>>>>>>> Java
>>>>>>>>>> Importer"
>>>>>>>>>> [Starting]
>>>>>>>>>> [Starting]
>>>>>>>>>> [Starting]
>>>>>>>>>> [Starting]
>>>>>>>>>> "Ecore
>>>>>>>>>> Mapping" [Starting]
>>>>>>>>>> XML
>>>>>>>>>> [Starting]
>>>>>>>>>> Mapping" [Starting]
>>>>>>>>>> [Starting]
>>>>>>>>>> Framework
>>>>>>>>>> Transaction
>>>>>>>>>> Core" [Active]
>>>>>>>>>> Model
>>>>>>>>>> "EMF
>>>>>>>>>> Source"
>>>>>>>>>> [Resolved]
>>>>>>>>>> "EMF
>>>>>>>>>> "EMF
>>>>>>>>>> Source" [Resolved]
Current Time: Tue Nov 04 23:33:42 EST 2025
Powered by FUDForum. Page generated in 0.49241 seconds
