Home » Modeling » Epsilon » How to get expression as string in Java?(This question is regarding the Epsilon back-end execution engine's AST)
How to get expression as string in Java? [message #1760592] Fri, 28 April 2017 13:14 Go to next message
I am trying to get the name of all of the dependencies in EVL through "satisfies" calls. However, I found that the type "Expression" does not provide any way to retrieve the expression as text. I have attached the relevant code.
Apologies if this is not a suitable place for asking this or there is insufficient detail.
Re: How to get expression as string in Java? [message #1760608 is a reply to message #1760592] Fri, 28 April 2017 15:24 Go to previous messageGo to next message
After examining the type hierarchy of "Expression", I managed to fix this by casting the Expression to a StringLiteral and calling getValue().
Re: How to get expression as string in Java? [message #1760615 is a reply to message #1760608] Fri, 28 April 2017 17:55 Go to previous messageGo to next message
Hi Sina,
The argument of "satisfies" may not always be a StringLiteral so it's probably a good idea to check before casting if you're not already doing this.
Dimitris
Re: How to get expression as string in Java? [message #1760619 is a reply to message #1760615] Fri, 28 April 2017 18:30 Go to previous messageGo to next message
Hi Dimitris,
Thanks for pointing that out. Would you happen to know what would be the expression type for multiple parameters? I presume that arguments to "satisfies" are always the names of the NamedRule to be checked.
Sina
Re: How to get expression as string in Java? [message #1760620 is a reply to message #1760619] Fri, 28 April 2017 18:32 Go to previous messageGo to next message
Hi Sina,
Calls to "satisfies" are OperationCallExpressions so getParameterExpressions() should return their parameters.
Dimitris
Re: How to get expression as string in Java? [message #1760621 is a reply to message #1760620] Fri, 28 April 2017 18:46 Go to previous messageGo to next message
Hi Dimitris,
In my code I already call getParameterExpressions(), and then cast every element of the resulting List<Expression> to List<StringLiteral>, so presumably this can never fail, since the parameters are guaranteed to be literals? Or could they be something else?
For reference, this is my current solution:
protected static Set<String> getDependencies(ModuleElement ast) {
	return ast.getChildren()
		.stream()
		.filter(me -> me instanceof ExecutableBlock)
		.map(eb -> (ExecutableBlock<?>) eb)
		.filter(EvlGraph::isDependencyWord)
		.map(eb -> eb.getChildren()
				.stream()
				.filter(bc -> bc instanceof OperationCallExpression)
				.map(oce -> (OperationCallExpression) oce)
				.filter(bc -> bc.getOperationName().equals("satisfies"))
				.collect(Collectors.toList()))
		.flatMap(List::stream)
		.map(OperationCallExpression::getParameterExpressions)
		.map(expr -> (StringLiteral) expr)
		.map(StringLiteral::getValue)
		.collect(Collectors.toSet());
Re: How to get expression as string in Java? [message #1760623 is a reply to message #1760621] Fri, 28 April 2017 19:32 Go to previous messageGo to next message
Apologies for the misunderstanding.
Having read section 4.4.1 of the Epsilon Book ("Capturing Dependencies Between Invariants"), the specification of "satisfies" operations take a string as parameter(s), however admittedly this may not be a StringLiteral. Therefore, I may have to resort to manually resolving all potential expressions to get the eventual string, or make an assumption that all parameters to "satisfies" operations will be StringLiterals. For example:
    //Stream<Expression> satisfiesParams
    .map(expr -> {
	if (expr instanceof StringLiteral)
             return ((StringLiteral) expr).getValue();
	if (expr instanceof NameExpression)
            return ((NameExpression) expr).getName();
        return expr.execute(context);
Sina
[Updated on: Fri, 28 April 2017 19:34] by Moderator
Re: How to get expression as string in Java? [message #1760632 is a reply to message #1760623] Sat, 29 April 2017 04:17 Go to previous messageGo to next message
Hi Sina,
This is correct. Bear in mind that the name of a constraint is not unique so in order to compute a precise dependency graph, in the general case you'd need to do full static analysis (including type inference etc.). To avoid going down that road at this stage you may want to limit your analysis to calls to satisfies() on the self built-in variable.
Dimitris
Re: How to get expression as string in Java? [message #1760637 is a reply to message #1760632] Sat, 29 April 2017 06:21 Go to previous message
Hi Dimitris,
Thank you for the insight and advice. I didn't know constraint names may be duplicated, though for the time being this approach should suffice.
Sina
Previous Topic:Code refactoring
Next Topic:EVL: Problem on configuring a UML model
Current Time: Fri Jul 25 23:49:59 EDT 2025
Powered by FUDForum. Page generated in 0.06090 seconds
