TargetDefinitionGenerator with platform-specific dependencies [message #1759201] |
Fri, 07 April 2017 11:38  |
Hi everyone,
we are using Oomph to setup up our developer IDE and we're also using Oomph targlets to generate the target platform for our IDE product. This product has a plugin dependency that only works with MacOS , therefore we only want to include it in the Mac version of the product.
I specified the p2 repository of the plugin in the targlet part of our setup and also declared an operating-system-dependent feature dependency for our product. When performing the setup on MacOS everything works as intended. However, when performing the setup on a non-MacOS (in my case, Windows) machine, Oomph doesn't include the p2 repository of this plugin in the generated target definition.
This makes sense so far, as the dependency doesn't exit on that platform, which makes the corresponding repository obsolete. However, it leaves me with two problems:
1. The developer IDE will report a validation warning for the operating-system-dependent plugin dependency, as the feature identifier can't be resolved. (because of the missing p2 repository in the active target platform)
2. The generated target definition file (.target) will always show up as a change in git, as this file is checked in in our VCS. We do this, so that maven can pick up the target definition when running on the build servers.
It would be interesting to hear, if anybody else has experienced a similar situation or if there is a proper way to deal with that situation.
Kind regards
Luca Beurer-Kellner
Re: TargetDefinitionGenerator with platform-specific dependencies [message #1760062 is a reply to message #1759201] |
Fri, 21 April 2017 11:08   |
Hello Ed,
thank you for your response. Sorry for the delay, I haven't been at work for a little while.
As you suggested, I enabled includeAllPlatforms. However, this still doesn't resolve the issue.
I am trying to integrate the OS X eclipse launcher: https://github.com/turesheim/eclipse-launcher.
Previously I included the launcher feature, which resulted in the mentioned situation.
To experiment, I tried to directly integrate the two contained plugins. In my feature.xml I added them like so:
<plugin
id="net.resheim.eclipse.launcher.core"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="net.resheim.eclipse.launcher.macosx"
os="macosx"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
As you can see, only the second plugin is declared platform-dependent. When running the Setup Task on a Windows machine, this dependency results in the following target definition entry:
<location includeAllPlatforms="true" includeConfigurePhase="true" includeMode="planner" includeSource="true" type="InstallableUnit">
<unit id="net.resheim.eclipse.launcher.core" version="3.0.0.201509271854"/>
<repository location="https://resheim.net/p2/eclipse-launcher/"/>
</location>
On a Mac machine however, the following target definition entry is generated:
<unit id="net.resheim.eclipse.launcher.macosx" version="3.0.0.201509271854"/>
</location>
After experimenting a bit, I could use the extraUnits detail of the TargetDefinitionGenerator to make the ".macosx" variant appear at that point, even on a Windows machine.
<detail
key="extraUnits">
<value>net.resheim.eclipse.launcher.macosx</value>
</detail>
However, I am quite unsure about this approach, as I couldn't find any documentation about this extraUnits detail.
Also, I can't really see, how to specify multiple "extra units". Unfortunately our existing configuration already defines an extraUnits value and, if possible, both should be specified.
After all, isn't the includeAllPlatforms option supposed to take care of this anyway?
I am looking forward to hear from you and to learn how this works.
Luca
FUDForum. Page generated in 0.34001 seconds
