Home » Eclipse Projects » GEF » Drag & drop in parent - child relation
Drag & drop in parent - child relation [message #1760572] Fri, 28 April 2017 09:36 Go to next message
Hi everybody,
I am trying to implement drag & drop functionality to my GEF4 application.
I have parent nodes (SWComponent) and child nodes (SWFunction). SWFunctions can be added to SWComponents.
Drag & drop works fine if I implement it for SWComponentPart or SWFunctionPart only. Therefore I use:
adapterMapBinder.addBinding(AdapterKey.defaultRole()).to(FXTransformPolicy.class);
adapterMapBinder.addBinding(AdapterKey.defaultRole()).to(FXTranslateSelectedOnDragPolicy.class);
But If I implement it for both SWComponent and SWFunction I get a lot of errors if I try to drag a SWFunction within a SWComponent.
(Draging a SWFunction or SWComponent within RootPart still works)
The first Error occures in AbstractTransactionPolicy -> checkUninitialized() and says "Already initialized"
I suppose this happens because I bind FXTransformPolicy to both SWComponentPart and SWFunctionPart?
Is this not allowed?
What do I have to do to enable drag and drop for SWFunctions within SWComponents while SWComponents can still be dragged.
Thomas
Re: Drag & drop in parent - child relation [message #1760595 is a reply to message #1760572] Fri, 28 April 2017 13:49 Go to previous messageGo to next message
You will need to replace the default ITargetPolicyResoler (GEF4) resp. IHandlerResolver (GEF 5.0) with a custom implementation that prevents that both parts are drag targets.
Your resolver will probably have to only resolve the function part as target when its located inside a component part (and exclude the component part).
Re: Drag & drop in parent - child relation [message #1760791 is a reply to message #1760595] Wed, 03 May 2017 02:01 Go to previous messageGo to next message
Thanks, that did the trick Smile
Re: Drag & drop in parent - child relation [message #1760792 is a reply to message #1760595] Wed, 03 May 2017 02:02 Go to previous messageGo to next message
Re: Drag & drop in parent - child relation [message #1760793 is a reply to message #1760595] Wed, 03 May 2017 02:02 Go to previous message
Previous Topic:Showing a Graph Zest inside of a Group widget
Next Topic:[GEF5] Click policies chain
Current Time: Fri Nov 07 04:49:26 EST 2025
Powered by FUDForum. Page generated in 0.08295 seconds
