Double initialize [message #1760508] |
Thu, 27 April 2017 15:30  |
Took me awhile to track down a really weird timing bug in a binding and just want to make sure that the situation I'm about to describe is what 'should' happen as opposed to a bug...
I have a binding that has a UPNP participant discovery process. If I have previously added the thing, the existing thing will have a 'thingUpdated' called on it when it's discovered again at startup.
Now the problem:
My existing item starts it's initialization process (via initialize()). The thing is 'discovered' again and thingUpdate is called. Let's say that thingUpdate is called BEFORE the existing initialize completes - then you'd have the following:
1) initialize() started
2) thingUpdate() called
2a) dispose called
2b) initialize called
3) original initialize() finishes (and goes online)
4) second initialize() finishes
So essentially I have TWO initialize()s running at the same time. (which, in my cases, causes issues because the first one finishes and goes online BEFORE the second one finishes - and that causes the second one various issues since the thing is online before it's done).
Now - is this an expected situation or bug?
FUDForum. Page generated in 0.10305 seconds
