Can't find the location for the compiler settings in "Nios II software build tools for eclipse& [message #1760007] |
Fri, 21 April 2017 04:23  |
In the Altera design flow there is so-called softcore processor "NIOS II", that allows to program FPGA as a real processor. For this purposes Altera developed some specific version of Eclipse, named "Nios II software build tools for Eclipse". Also it looks like as Eclipse, the interface is a little bit different. For example, after long search, I still didn't find where can I set compiler options (e.g. -std=C99). Obviously the default compiler setting is C90 because I can't declare loop variable inside loop.
Is some aware of this tool and specifically of "compiler settings" issue.
I've already posted my request on Altera forum, but had no response.
Thanks in advance.
Pavel.
[Updated on: Fri, 21 April 2017 04:26] by Moderator
FUDForum. Page generated in 0.10052 seconds
