Home » Modeling » TMF (Xtext) » Reduce available JvmTypes
Reduce available JvmTypes [message #1759730] Mon, 17 April 2017 14:54 Go to next message
Hello everyone,
i am currently writing a beginner friendly OO-Language based on Xbase.
I decided to use Xbase for this purpose, hence most of my DSL concepts can easily be mapped to Java and it ships with a lot of nice features (like debugging).
My problem is, that Xbase provides too many types (e.g. StringBuilder etc...), which can be quiet overwhelming for beginners.
I only want to provide some primitive types (like int, String, boolean and double) and some datastructures like arrays and lists (and user-defined classes of course).
I tried to override the different Xbase grammarrules to achieve this, e.g:
JvmParameterizedTypeReference:
type=[JvmPrimitiveType] ;
But with no luck. : /
So my question is: How can i reduce the amount of available JvmTypes?
Where should i start / what is the best approach for that?
Thanks in advance and kind regards,
Marco
Re: Reduce available JvmTypes [message #1759790 is a reply to message #1759730] Tue, 18 April 2017 02:22 Go to previous messageGo to next message
I think you should make use of some filtering of the proposals e.g. as in https://kthoms.wordpress.com/2012/03/14/how-to-limit-proposed-java-types-to-implementors-of-an-interface/
Re: Reduce available JvmTypes [message #1759819 is a reply to message #1759730] Tue, 18 April 2017 04:47 Go to previous messageGo to next message
You can also restrict the types with JDT Type Filters preference setting. That does not require any customization, just preference configuration.
Re: Reduce available JvmTypes [message #1759829 is a reply to message #1759819] Tue, 18 April 2017 13:31 Go to previous messageGo to next message
Hello Christian and Karsten,
thank you for your fast reply!
I tried your approaches and they work well for the proposed types, but it wont prevent a user from using/writing types like StringBuilder in a program.
Is there a way to only allow the mentioned primitive types and collections on a grammar level?
Kind regards,
Marco
Re: Reduce available JvmTypes [message #1759830 is a reply to message #1759829] Tue, 18 April 2017 13:39 Go to previous messageGo to next message
That would be scoping not grammar
(See XbaseBatchScopeProvider for entry point
And
IJvmTypeProvider)
Re: Reduce available JvmTypes [message #1759897 is a reply to message #1759829] Wed, 19 April 2017 04:10 Go to previous messageGo to next message
Right. I would wrap the scope with a FilteringScope and only accept allowed types.
Re: Reduce available JvmTypes [message #1759911 is a reply to message #1759730] Wed, 19 April 2017 16:12 Go to previous messageGo to next message
Thank you both for your support, now I am back on track. Smile
I decided to extend and customize the JdtTypeProvider, hence it should only provide some types.
Now I have one question left:
The scope provider now uses my implementation of the type provider but all types are still proposed.
I thought the proposals were build depending on the content of of the scope, aren't they?
As a workaround, i could customize the proposals as mentioned in Karstens blog, but I wonder why it still proposes all types....
Here my solution so far ,just in case someone else has the same problem / requirement:
In the UI-Plugin add a factory...
@Singleton
class MyFilteredJdtTypeProviderFactory extends JdtTypeProviderFactory {
	@Inject
	IWorkingCopyOwnerProvider copyOwnerProvider;
	@Inject
	TypeResourceServices typeResourceServices;
	override protected IJdtTypeProvider createJdtTypeProvider(IJavaProject javaProject, ResourceSet resourceSet) {
		if (javaProject == null){
			return new NullJdtTypeProvider(resourceSet)
		var WorkingCopyOwner wco= null
		if(copyOwnerProvider==null)
			wco = DefaultWorkingCopyOwner.PRIMARY
		else
			wco = copyOwnerProvider.getWorkingCopyOwner(javaProject, resourceSet)
		return new MyFilteredJdtTypeProvider(javaProject, resourceSet, getIndexedJvmTypeAccess(), wco, typeResourceServices);
...and the provider...
class MyFilteredJdtTypeProvider extends JdtTypeProvider {
	public new(IJavaProject javaProject, ResourceSet resourceSet, IndexedJvmTypeAccess indexedJvmTypeAccess, WorkingCopyOwner workingCopyOwner, TypeResourceServices services) {
		super(javaProject, resourceSet, indexedJvmTypeAccess, workingCopyOwner, services)
	private val HashSet<String> supportedJdtTypes ={
		val hs = new HashSet()
		hs.add("int")
		hs.add("double")
		hs.add("boolean")
		hs.add("java.lang.String")
               // Required by the compiler to process method bodys right
                hs.add("void")
		// Required, otherwise operators do not work
		hs.add("org.eclipse.xtext.xbase.lib.StringExtensions")
		hs.add("org.eclipse.xtext.xbase.lib.IntegerExtensions")
		hs.add("org.eclipse.xtext.xbase.lib.DoubleExtensions")
		hs.add("org.eclipse.xtext.xbase.lib.BooleanExtensions")
		return hs
	public override JvmType findTypeByName(String name) {
		if(name.isTypeSupported){
			return doFindTypeByName(name, false)
		}else{
			return null
	public override JvmType findTypeByName(String name, boolean binaryNestedTypeDelimiter) {
			return super.findTypeByName(name,binaryNestedTypeDelimiter)
		}else{
			return null
	def isTypeSupported(String name){
		supportedJdtTypes.contains(name)
... and tell the framework (in UiModule.xtend) to use our factory instead of its default impl:
	override Class<? extends IJvmTypeProvider.Factory> bindIJvmTypeProvider$Factory() {
		return MyFilteredJdtTypeProviderFactory;
[Updated on: Thu, 20 April 2017 14:38] by Moderator
Re: Reduce available JvmTypes [message #1759914 is a reply to message #1759911] Wed, 19 April 2017 16:51 Go to previous messageGo to next message
No they are not. There is an exception for jvm types regard scope = content assist thus my first hint on ca filtering
Re: Reduce available JvmTypes [message #1759948 is a reply to message #1759730] Thu, 20 April 2017 06:01 Go to previous message
Okay, I See, thanks again. Smile
In case someone should be interested, this is my approach (iam filtering the types of the ITypesProposalProvider / JdtTypesProposalProvider):
class MyDslProposalProvider extends AbstractExpressionsProposalProvider {
    override protected completeJavaTypes(ContentAssistContext context, EReference reference, boolean forced,IValueConverter<String> valueConverter, ITypesProposalProvider.Filter filter,ICompletionProposalAcceptor acceptor) {
		val extendedFilter = TypeMatchFilters.and(filter,new SupportedTypesFilter())
		super.completeJavaTypes(context, reference, forced, valueConverter, extendedFilter, acceptor)
	private static class SupportedTypesFilter extends AbstractFilter {
		override boolean accept(int modifiers, char[] packageName, char[] simpleTypeName,char[][] enclosingTypeNames, String path) {
			// Add further predicates to filter for java types here
			packageName.join.equals("java.lang")&& simpleTypeName.join.equals("String")
Previous Topic:Is it possible to call @Check method only once in validation
Next Topic:Active Annotation Concept in a XBase and JvmModel based DSL
Current Time: Sat Sep 13 00:07:08 EDT 2025
Powered by FUDForum. Page generated in 0.03981 seconds
