Home » Eclipse Projects » Eclipse Scout » Eclipse neon error(I have an issue with running a project, that had done for me. My developer was in an accident, and I am trying to keep project going)
icon12.gif  Eclipse neon error [message #1759800] Tue, 18 April 2017 10:47 Go to next message
The lines that are getting error's are marked by an X. I do not have a problem of sending whole project to make sure i get this up and running again quickly.
X package com.advantagemobilepos;
X public class AdminSetting {
public static boolean enabled;
X public static String password = "";
X public static String hint = "";
X protected static String override = "2003";
public static boolean isEnabled() {
return enabled;
public static void clear() {
enabled = false;
X password = "";
X hint = "";
Re: Eclipse neon error [message #1759809 is a reply to message #1759800] Tue, 18 April 2017 12:08 Go to previous messageGo to next message
Can you tell what the Error Message in the Error Marker is?
Re: Eclipse neon error [message #1759811 is a reply to message #1759809] Tue, 18 April 2017 12:22 Go to previous messageGo to next message
attached are a copy of error windows. I can send more if needed. Thanks
Re: Eclipse neon error [message #1759814 is a reply to message #1759811] Tue, 18 April 2017 12:30 Go to previous messageGo to next message
Thank you for any help you can give..
Re: Eclipse neon error [message #1759815 is a reply to message #1759811] Tue, 18 April 2017 12:30 Go to previous messageGo to next message
Re: Eclipse neon error [message #1759833 is a reply to message #1759815] Tue, 18 April 2017 14:33 Go to previous messageGo to next message
Please notice that this forum is about the Eclipse Scout framework.
For your Problem:
The type java.lang.String cannot be resolved. It is indirectly referenced from the required .class files
I recommend you to check this thread on StackOverflow:
http://stackoverflow.com/q/18075343/91497
Re: Eclipse neon error [message #1759884 is a reply to message #1759833] Wed, 19 April 2017 02:40 Go to previous message
Thank you...
Previous Topic:How can i retrieve a byte[] field from database?
Next Topic:[neon] Enable HTML Selectors for Selenium
Current Time: Sun Aug 31 00:49:36 EDT 2025
Powered by FUDForum. Page generated in 0.05264 seconds
