JRE settings [message #1759547] |
Wed, 12 April 2017 16:13  |
I don't have any older Java Runtime Environments installed on my computer that I know of. However, Eclipse is always setting my JRE compatability to below 1.4, while I'm running 1.8. Obviously, this causes some problems. How do I change it so that for every project it will automatically set the JRE to 1.8?
Thank you.
Re: JRE settings [message #1759597 is a reply to message #1759560] |
Thu, 13 April 2017 11:53   |
I don't see Open Setup under the Navigate tab. The open options I have are Open: Type Hierarchy, Call Hierarchy, Hyperlink, Implementation, Super Implementation, Attached Javadoc, and Clipboard. Below are Open Type, Open Type in Hierarchy, and Open Resource, and Open Task. Am I in the wrong tab or something?
Re: JRE settings [message #1759603 is a reply to message #1759547] |
Thu, 13 April 2017 14:29  |
Please look at the Java settings in the general preferences menu, from Window -> Preferences (OS X: Eclipse -> Preferences).
From the preferences menu Java -> Compiler -> Compiler compliance level.
-TV
Re: JRE settings [message #1759608 is a reply to message #1759603] |
Thu, 13 April 2017 06:53  |
The Neon.3 update broke quite a few bundles, including Oomph, so maybe you have that update. But in that case, it's not applying your user preference either, so that leave me no theory why your workspace defaults to 1.4.
FUDForum. Page generated in 1.08803 seconds
