Home » Eclipse Projects » Mylyn » Best way to export task list to a document?
Best way to export task list to a document? [message #600376] Wed, 06 January 2010 19:03 Go to next message
Bit of a noob question - I haven't been using mylynn that long.
I've done up the majority of tasks for an upcoming project and would like to export it to a document to use as functional specs for the client.
The only option I can see is the XML import.
Does someone either:
- Have an xls file to tranform the task list into nested lists in a word processor
- A way to export directly to a document
Re: Best way to export task list to a document? [message #1750420 is a reply to message #600376] Tue, 20 December 2016 16:20 Go to previous messageGo to next message
Him
I see you've been flooded with response. Unfortunately I cant help I have the same issue. I assumed (before trying) that this would be trivial.
Apparently not, I tried the export to Mylyn xml and got a file with nothing in it.
Re: Best way to export task list to a document? [message #1759467 is a reply to message #1750420] Tue, 11 April 2017 18:22 Go to previous message
I'm not exactly sure what you want here, however I couldn't find a way to print anything Mylyn related and an export just gave me a blank file with an XML header. Like you I'm new to Mylyn and right now only using local files, it looks like you are a step or two ahead of the authors. You might want to go looking for the data storage area to see if the files are easily parsable. This may require a post to a developers forum as this message has no positive response yet.
Previous Topic:Mylyn 3.22 is now available
Next Topic:Unable to synchronize GitHub issue to Mylyn task
Current Time: Sun Jun 08 23:59:46 EDT 2025
Powered by FUDForum. Page generated in 0.03096 seconds
