Counting objects slow after Neon 3 update [message #1759392] |
Tue, 11 April 2017 04:10  |
I recently updated to Neon 3 from Neon 2.
Current eclipse version:
Version: Neon.3 Release (4.6.3)
Build id: 20170314-1500
Egit version: 4.6.1.201703071140-r
It doesn't happen on all repos and it doesn't seem to be connected to the size of the repo either.
Normally a push goes quickly in a second or so, now it can take up to a minute, slowly "Counting objects".
I'm pushing to a gerrit server but I doubt that matters, from command line it goes quickly and only thing I updated was eclipse & egit.
Anyone else seen this?
Re: Counting objects slow after Neon 3 update [message #1759476 is a reply to message #1759461] |
Tue, 11 April 2017 18:10   |
The stats:
Number of objects, loose objects: 12, packed objects: 7973
Number of packfiles, loose objects: -, packed objects: 5
Number of refs, loose objects 5, packed objects 71
Space needed, loose objects 9.08 kB, packed objects 4.93MB
Running GC does not have any affect.
It's slow even if I don't have any changes and plainly does a push to upstream.
On the other hand this repo show no slowness whatsoever:
Number of objects, loose objects: 489, packed objects: 42673
Number of packfiles, loose objects: -, packed objects: 32
Number of refs, loose objects 26, packed objects 94
Space needed, loose objects 407.41 kB, packed objects 15.93 MB
Which is another repo from same gerrit server, checked out about at the same time so it's a bit weird.
FUDForum. Page generated in 0.05021 seconds
